Question about NorStar Polycom Soundstation ( Phone System Direct Compatible Unit) - Refurbished (NSPOLYCOM)
Polycom Sound Station
I have an older Polycom Soundstation (7 years old) For some reason, on the keyboard, I can only get a rotary tone, instead of a pulse tone, and I can't find out to get to pulse. I've punched about every button I can think of, have taken the phone apart, and there is no switch for me to choose....I think it's got to be some password on the keyboard that I have to program.....any thoughts
  • jmdolan Jan 09, 2008
    My problem is exactly the same as Gregston's.
SoundStation: Changing dialing from Tone to Pulse
Polycom Sound Station - sp.gif sp.gif There are three ways that a SoundStation can be changed from tone to pulse, which depends on when the unit was manufactured.
1. Pressing the Keys 3&Vol + simultaneously, will toggle between Pulse and Tone while the unit is in On Hook Mode (off).
2. Pressing the Keys *&MUTE simultaneously, will toggle between Pulse and Tone while the unit is in On Hook Mode (off).
3. Operation done by DIP switches. Dipswitch Configuration On the bottom of the SoundStation, in the lower left hand corner of the large sticker may be a small silver sticker. Underneath that sticker are 4 DIP Switches. Switch number 4 is for tone and pulse,ON being tone, and OFF being pulse. Do not change the other three swithces as this could render the phone inoperable.
Posted on Mar 09, 2009
  • George Bates Dec 15, 2011
    thank you tschimo! it worked; option 1, very appreciative!
Polycom soundstation 2 does not have a dial tone
That Polycom runs off of Analog dial tone.
Either a dedicated line or in most cases from an ATA off the phone system.
You should be calling your vendor/tech in that handles the phone system to check programming, cabel, jack and the Polycom itself too.
Dec 11, 2012 | Polycom Soundstation 2 Full Duplex...
What is the station type to use when hooking this polycom sound station premier EX to an Avaya S8300 on a digital port card?
The Polycon Sound Station Premier coference phone is an analog device. You need to connect it to an analog port on your phone system.
Dec 13, 2010 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
We have an old polycom sound station which is not wireless and does not have the screen. We need to conference with 2 people. I know we can do it with the soundstation 2w but can we do it with the old...
It would depend on if this is going through the phone system, or just a phone line all by itself.
If on the phone system, there should be a conference button, that is like a "flash" button on your home phone.....
Sep 01, 2010 | Polycom SoundStation
How to reboot soundstation 2w polycom if you forgot the password
egistering Base Station on Polycom SoundStation 2W
Hold down 1,4 and 9 until green & red lights flash. Then hold down the page on the base station.
You can register the base station to the console by:
1. press menu key
2. Select Admin Setup
3. Select Registration
4. You will see "Register with Base Station" in display. Press the Register softkey.
5. You will see "Power cycle base station then press ok". Unplug base and plug back in and press OK softkey.
6. You will see "Press and hold the paging button on the base for 10 seconds"
7. You will see Registering in the display on the console and then it should go to ready mode.
Mar 05, 2010 | Polycom SoundStation 2W (2200-07800-001)...
Polycom Sound station - help it won't work!
what line have you connected to the polycom? you will need to connect a single line circuit line.
Apr 06, 2009 | Polycom SoundStation
Polycom Soundstation 2 disconnects during calls
this does not appear to be the sound station problem it appears u ve connected this system behind an epabx extension .if yes the extension is programmed for a call disconnection time of 15 mins.ask ur epabx programmer to change it to infinite
Feb 02, 2009 | Lands Phones
Polyspan soundstation power supply schematic diagram
My Polycom sound station power unit malfunction. I found that AC transformer broke. If I try to get substitute transformer, what is the required ac output (Vac) and Amp that I need to find?
Nov 23, 2008 | Polycom SoundStation
Conference problem
repeat you setup for all station you want to connect to it.
Sep 18, 2008 | Polycom SoundStation
Flash timing setting for polycom sound station
You need to update the flash timing on your Soundstation to match what is on your PBX.
Check out and
Jun 06, 2008 | Polycom SoundStation Premier EX Audio...
Adding person to a teleconference group
How can I add 3 other people on the conference call using a Polycom Soundstation?
Jan 08, 2008 | Polycom SoundStation
Lands Phones Logo
1,235 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
