Question about Kenwood 104AR Receiver
No sound on right side
Using one speaker, sound is present on the left side both A and B. Using same speaker, sound is NOT present on the right side both A and B. A solution would be appreciated. I am suspecting the power amps for the right side. What do you think?
  • Borrower78 Oct 04, 2007
    Dukic,
    Not sure what caused this problem. Should I replace both Amps,(left and right)? Did not find fuse on right side. Can you be more specific?
The 104ar don,t have fusees for right and left chanels there are two
in the unit one is on the power supply broad it,s where the line cord
is wired to and the other one is on the other side of the transformer
the two relays protec the outputs the 104ar has 4 outputs the curcit
is push pull. you have npn and pnps the drivers are between the
outputs. the drivers are the small ones the outputs are the big ones
there on the heat sink on the front of the maine broad the output
relays are in the maine broad in the back there are two of then and
they are black in color the power supply one is blue.use a dvm or
a vtvm when working on the 104ar DO NOT use a vom
Posted on Feb 25, 2008
  • 93 Answers
I think you are right. What cause this problem?
Posted on Sep 21, 2007
  • Mico Dukic Oct 04, 2007
    Did you check fuse on right side?
  • Mico Dukic Oct 05, 2007
    Well, I'm not familiar with this particular amp, that's why I gave suggestion about fuse. If you have integrated amp (preamp + amp in same unit), you should check with multimeter, step by step, where is signal interruption, and what cause it. Then you can figure out what to do. Wish you luck.
Speakers,only one side working
check the right channel connector (the metal bit) for any bad contact.
also try using the earth off the other channel while using the possative off the right
Jun 17, 2013 | Marathon Audio Players & Recorders
Hello, I just bought a BEHRINGER MS40 from an authorized dealer "SENIA" from Romania, I'm from Romania by the way, the woofer speaker from the right side is making noises when the frequency is...
Have you connected the Left speaker to the right speaker using the supplied cable? If not, connect the cable to the socket on the back of the right speaker labelled "to left speaker" and on the left speaker, to the socket labelled "from right speaker"
If this still doesn't solve the problem, try swapping the input cables (put the white plug in the red socket and vice versa) to see if this makes the left speaker produce sound, if it does, check the connection at the source to check the plug(s) are in all the way. If there is still no sound in the left speaker, unplug everything and do the following:
connect the left and right speakers with the supplied phono lead (Probably black) between sockets labelled "to left speaker" and "from right speaker"
then connect the source to any of the inputs on the back of the right speaker (ensure if using the red and white phono inputs that both are connected)
finally plug in power source.
Hope this helps
May 04, 2011 | Behringer Ms40 Digital Monitor 40watts
The right side of the speaker is low, you can hear it but it's like there is no bass to it like the left side, sounds like the right side is like whispering to you but the left side is talking normally,...
If your subwoofer is placed to the left side try moving it to the right side or try to move it in the center. Otherwise if you are using a PC go to the control panel and click the sounds and audio devices icon. a little window will pop up and the button labeled speaker volum click on and reduce the volume for the left speaker and then turn up the volume on your speakers and see if that helps.
Nov 30, 2010 | Logitech Z-2300 Computer Speakers
Unable to connect surround sound with a stero player
There is a obvious difficulty here. If you have a stereo receiver then it can't produce surround sound. You must have a surround sound receiver to present true surround sound. If you already do have that then on the back of your Phillips set there are audio outputs. The left and right audio out will be decoded in your surround sound receiver and they will automatically play from your speakers. You should have seven speakers, center channel, left and right front speakers, left and right rear speakers and left and right mid or side speakers. A sub-woofer would be nice too. Best bet is to speak with the store you purchased the set from. They will have that information.
Zashiban
Jun 23, 2010 | Philips Televison & Video
One of my DJ turntables = only left side stereo sound
need to narrow it down, using 1 turn table ONLY with the mixer on channel 1 (the chanel that is working) to test reciever is working properly and sound working on both side of the speakers, this eliminate the first turn table. Next, disconnect the working turn table (1) and connect your second turn table to the same chanel and see if you getting the sound coming chanel 1 just as your first turn table did. If you getting sound coming out from turn table on ch1 than is not the turn table issue. It will be you mixer having problems. You cant solve the problems having everything connected. Testing one turn table at a time using working chanel on the mixer to see if both turn table working properly. If you use the same chanel testing both turn table and the second one does not work than it will be one of your turn table is faulty. Note: if you find and test both of your turn table is working properly than it will be your mixer. good luck and hope that help..
Aug 06, 2009 | Technics SL-1200MK2 Turntable
Sony STR-DE635, Sound from left surround speaker but not right
first turn the actual volume up on that channel on the reciver then make sure your speaker wires in the rear are using the same lenght each
May 18, 2009 | Sony STR-DE635 Receiver
No sound from the right speaker
Check the speaker if its okay, disconnect the left side one and connect the right side one and play. If it does not then the speaker is bad.
Jan 11, 2008 | Altec Lansing VS4121 Speaker
Right speaker jack
Are you using the same cord for the mp3 player as you are for the cd and radio? There could be a patch cord problem or it could be the output jack of the mp3 player. If using headphones with the mp3 player works both right and left then it must be the patch cord. Try using a different patch cord.
Dec 26, 2007 | GPX HM3817DT Shelf System
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Kenwood 104AR Receiver Logo
188 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
rigger094
Mike Duncan
Mike Duncan
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
