Question about Philips Magnavox 27MS343S 27" TV
27 inch tube tv won't stay on
Hi i have a 27 inch maganavox tube tv and it keeps shutting off and sometimes very hard to come on. Sometimes when it comes on it makes a whinning high pitched noise and stays on for about and hour or so. It has nothing to do with the timer, it just cuts off. It starts off by the picture on the tv starts to pull and stretch away from the corners of the tv and then i hear this click noise and it shuts off. what is the problem?
  • 1,139 Answers
You have a problem is in your horizontal section which also is part of your power supply. The high pitched whine is from the Intergrated High voltage transformer (also called the flyback transformer). This sound occurs when the freuency of the transformer changes and or the voltage gets too high. The click occurs as a result of the drawing of excessive current by the HOT Horizontal output transistor. This is repairable, but requires the correct equipment and a schematic.
Posted on Sep 20, 2007
Ok my 2001 Grand Cherokee Laredo wont stay in park
Transmission sticks in reverse- won't go into park. - JeepsUnlimited
Jun 14, 2013 - 12 posts - ‎5 authors 2003 6 cyl 4x4 Grand Cherokee Laredo automatic- Occaionally, when shifting from REVERSE TO PARK, my Jeep will stay in reverse. Typically its ... '2001 WJ'4,0L'42RE'NV 242'380000 km'ECE Compliant' ??????????? ??? ...
2001 jeep grand Cherokee laredo - CarGurus > Questions > Jeep > Grand Cherokee
CarGurusJan 27, 2014 - 2001 jeep grand Cherokee laredo - Just purchased a 2001 Jeep GrandCherokee Laredo and ... It starts in PARK sometimes and sometimes it won't and I have to start it in Neutral. ... Hatch shuts flush, but won't stay shut. help!
Oct 22, 2015 | Cars & Trucks
Water won't shut off on my Estate washer
check clear tube that is inside machine.1st take off shell of machine look for clear tube about 1/4 inch sometimes comes off,it pushes over nipple to load size water fill knob.if it came off the water will keep on flowing and over flow.if that's the problem just put a dab of silicon on nipple and push tube back on.
Feb 20, 2012 | Estate TAWS800JQ Top Load Washer
TV keeps shutting off.... won't stay on, any ideas?????
Check for bad capacitors in the power supply. Check for voltages. You can get a board at Encompas Parts.,
Nov 19, 2011 | RCA TruFlat 27F520T 27" TV
Maganavox turns on and then off
did you solve this problem? i have the same thing, what did u do?
Jun 26, 2009 | Philips 27MT3305 27" TV
RCA TV, model number 32V550T. No picture but sound is fine.
this sometimes is quite simple to fix as it cud be a dry joint on the circuit board where the tube motor sits.
or it cud be the tube is on its way out, which wud be cheaper to buy a new tv rather than have it fixed
Feb 24, 2009 | RCA 32V550T 32" TV
Flickering image
I have a vcr and dvr combination emerson tv a 27 inch and sometimes while playing it will flicker and these horzion lines come in while a program is runing, and then the sound goes way down then comes back up to normal.
can you give me a answer?
Is it my picture tube it is about to go out?
It is close to five years old
Feb 23, 2008 | Emerson EWF2703 27" TV
27" GE TV with loud Popping sound
Could be a possible flyback. yes.. for a 27inch i would not think it would be worth it... 27 inch tvs are realativly cheap.. the lowest price to repair would be about 200 if you got lucky.
Dec 18, 2007 | GE 27GT271 TV
My TV keeps shutting off
Tvtek is on the right track. The remote will not solve the problem. Sounds like a voltage regulator in HV circuit if it only lasts a few seconds. If it stays on for a couple of minutes, beam limiter cicuit is pushing to overload and shutting unit down. Magnavox set not hard to repair, but a 27" set is not cost effective to repair either.
Jun 06, 2007 | Philips Magnavox 27MS343S 27" TV
Sony 27"TV will not turn on
The picture tube on your tv is dead, you need to replace it. It probably will be worthing just purchasing a new set, because the cost of repairing it will be close to the purchase of a new one.
Apr 07, 2007 | Sony KV-27FV16 TV
Philips Magnavox 27MS343S 27" TV Logo
180 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
