Question about Maytag Atlantis MDE7400AY Electric Dryer
Belt too big?
The belt is too big for the drum. is there a way to tighten it, or is there somewhere that i can get the diagrams for the belt.
    Genius:
  • 1,198 Answers
Sometimes instructions are on the new belt package. You can google your unit for support. Check Repairclinic.com. Keep in mind the belt must go at least a half turn around the motor pulley( grooves down on the pulley), then the tensioner is pulled toward the motor and the belt goes a half turn around that pulley, with the grooves up. That should take up all the slack.
Posted on Apr 28, 2009
How to replace belt on washing machine
hi take the back and lid off the washer usually on the top part of washer you should see the motor there should be 3 bolts 2 keeping it to the drum and another for ajustments losen this one untill the motor goes limp put new belt around the big wheel on the drum and on the small cog on the motor get a log heavy screw driver put it on the motor as a lever and take up the slack dont tighten the belt to much as it will end up snaped again just so you can poke the belt and it moves in and out slightley then tighten up the nut on the motor and thats it hope this helps ivan
Sep 25, 2012 | Indesit Washing Machines
I changed the belt, it sounds like it works now but drum does not roll????
Hi and welcome to FixYa. I am Kelly.
Things to check..
1. Belt and ilder pulley properly positioned?
Use this link to make sure you have it correct:
http://www.repairclinic.com/Dryer-Belt-Diagrams
2. Make sure the drum felt seals are not rolled / folded over. If it is folded / rolled slide the shanke of a screwdriver under the felt and rotate the drum 360 deg until it straightens out. (Front and rear seals.)
3. Make sure the drum rollers are resting in the drum groove and not behind the drum
These manuals will be a big help: (page 25)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794
and
(Page 10 below link)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/3ffad75038c96fe4852571ca006cb80a/$FILE/L-58.pdf
Thanks for choosing FixYa,
Kelly
Apr 01, 2011 | Whirlpool Dryers
The tensioner is not tightening the belt tight enough,new belt is still very loose any ideas??
Order a slightly shorter belt or put another idler pulley in somewhere (assuming the machine is in a condition to make one).
Nov 04, 2010 | Ammco Combination Disc/Drum Brake Lathe
How do i install a belt on a whirlpool LHE5700 dryer
This instruction works for most any dryer--- it should for yours too:
1) The big trick for a dryer belt is getting it around the drum... the rest is easy. You'll either take the top off and work with the drum to ease the belt around the drum- the front of the drum simply rests on slides/rollers depending on the model
You may need to remove some piece from the front to make this happen too-
2) re-fit the belt then by first taking the inspection cover off (or the whole back of the unit) and working the belt to the back of the drum, near to the pulley and the motor...
3) then, work to unload the spring, place the belt around the pulleys (it should be pretty obvious how to do this) and then release the spring mechanism--- this will tighten the belt between the drum and the drive pulleys.
Good luck!!!
Dec 15, 2009 | Dryers
How do I change the belt on a model 68701 Kenmore washer
Good luck!!!
Dec 14, 2009 | Dryers
How to replace dryer belt
Good luck!!!
Dec 14, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Can't get belt on dryer properly
The routing for the belt should be on a diagram somewhere inside the dryer. It sounds like the belt is not properly routed around the idler/tensioner pulley -- this is a very tricky routing -- without a diagram, it's a bunch of trial and error. Can you find the routing diagram?
Apr 22, 2009 | Dryers
Timing belt
what sort of noise is it a rubbing noise?
Dec 30, 2008 | 2000 Toyota RAV4
Replace belt
Remove lid UN PLUG MACHINE FROM WALL SOCKET Undo motor bollts so it can be moved towards drum, GET OLD BELT AND LOWER IN YOUR HAND TOWARDS DRUM THEM MOVE BACKWARDS TILL CLEAR OF DRUM PULLEY ,get new belt and lower so it goes over rear of drum pulley (big wheel)make sure nothing is in drum,put one bolt of motor in loosely and roll belt over motor pulley wheel slowly forcing towards you if working from front a bit until ribs on belt are in grooves on both pulley wheels,Tighten up all motor bolts job done test it
Sep 15, 2008 | Hotpoint WMA64 Front Load Washer
Trying to put belt back on dryer have know diagram
Follow the link to the belt diagram page and it will show you how to route the drum belt for your particular dryer.
http://www.repairclinic.com/0079.asp#DiagramK
Jun 08, 2008 | Roper Dryers
Maytag Atlantis MDE7400AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
