Question about Craftsman Garden
Sears tiller/shifted to reverse and it stuck.it trams in reverse,but it's stuck. I would be willing to teardown the trans. if i had to. tiller model 917-293480 Thanks, Yucon
  • Anonymous Mar 24, 2014
    850 series model no. 917.297041. tiller will not shift to neutral or forward, why ?
    Problem Solver:
  • 15 Answers
It sounds like to me then gears or of in tiller you will probably have to tear it down to get to it. I had to do that once on a sears tiller it is a pain but can be done when u tear it down u mine as well change the chain or belt inside while u have it apart u can go on sears web site and get a diagram that shows how everything goes together might want to have it handy when u tera it down
Posted on Apr 19, 2009
Where can i get teardown info on a gx75 transaxle
Check your electronic shift solenoid first before ripping apart axles and gearboxes.
Mar 07, 2016 | Garden
Transmission will not come out of reverse
what year is it does it have Belt Driven or chain drive ? do you put it gear with lever does it have handle to put it in gear ?is ther something stuck on the blades ? does it turn either Way ?
May 26, 2014 | Garden
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
I need to change the gear shift that broke off in the transmission do i have to split it open all the way to change it
Craftsman tillers usually use a chain drive transmission. Sears does not usually offer individual parts for these transmission. They want you to replace the entire trans assembly. If the gear shaft is available (www.searspartsdirect.com) , then yeas, you would have to split the case all the way open to replace it. This is not an easy job. Most major repair shops would charge 4 or 5 hours of shop time for this repair. It generally requires complete dissassembly of the tiller to remove the transmission.
You did not give a model # for your tiller, so I am only giving you general solutions. Please look up the parts. Many times it is more cost effective to replace your tiller than it is to repair it. Remember that all of the other gear shafts are the same age as the one that broke and have been through the same stresses.
Jan 04, 2011 | Craftsman Garden
1969 sears 319cc 8hp 2 speed stick shift w/power reverse front tine roto tiller.starts ok but does not idle well and starts to backfire as it warms up.
What does the spark plug look like? might be running ritch. too much fuel in the mixture. is the choke open ? How is the air filter?
Mar 06, 2010 | Garden
Were is the shift solenoid located on the trams. 1998 caravan
It can found on the right front of the tran's case. Look down between trans and radiator ( there will a large electrical connector attach to it.)
Mar 05, 2010 | 1998 Dodge Caravan
Tiller goes For./Rev. but wont drive forward with tines engaged
check the sher bolt on the tine to drive shaft. ill need model and ser number off the unit before i can go further with helping you thy changed them around a lot
Oct 09, 2009 | Mtd Garden
Transmission is stuck in neural.
Possibly just linkage problem.
Mar 28, 2009 | Husqvarna Garden
The trans. stays reverse no matter what gear you put it in
It may be a shift fork or a synchronizer stuck Try running it around alittle in reverse and see if iy helps. good luck
Mar 27, 2009 | kawasaki W 400 Motorcycles
Garden Logo
389 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
