Question about GE (GTS16BCS) Top Freezer Refrigerator
Defrost timer I work in a hotel, and the guest complaine about the ref. being to loud at night. I was wondering if you can change the time it defrost to day's insted of nights.
  • 291 Answers
The timer has a rotation 24/7 every 6 to 8 hrs. depending on timmer set up it goes into defrost... there is No way to adjust when it will defrost.
Posted on Sep 19, 2007
SOURCE:
Why does The freezer side stays cold but the refrigerator side gets warm
Your problem is more than likely a defrost issue. There is ice building up in the freezer coils and when it gets blocked with ice the cold air cant blow into the fresh food section. When you shut it off the ice melts and it gets cold again for a few days. remove the freezer back panel and check the defrost heater and defrost thermostat. if they check OK then check the defrost timer. It is best to replace all three components at the same time. This way you will be starting out with new components rather than one failing then the other.
Jul 16, 2014 | Kenmore Side by Side Refrigerator
Ice maker make noise and back of freezer is frozen
THE DEFROST CONTROL IS OUT MAY BE THE DEFROST BYMETAL OR A TIMER OD DEFROST HEATER WHAT BRAND AND SIDE BY SIDE OR TOP AND BUTTEM REF. AND AGE. WILL HELP
Feb 21, 2012 | LG LSC27910 (265 cu ft) Side by Side...
REFRIGERATOR IS NOT COLD
If the freezer side is working and the refrigerator is not, its either your evaporator fan motor in the freezer side isn't running, or a defrost system problem. Open the freezer door to listen for the fan, and at the same time look to see if you have a build of ice on the back freezer wall. If you do, there is no circulation from the freezer side to cool the ref. The defrost system consist of a defrost timer, defrost thermostat and defrost heaters. The heaters rarely go out, so if you have to change the timer change the defrost thermostat as well since its a cheap part anyway. timer part number is 2188159 and the thermostat part number is 2196155.(called a bi-metal thermostat.)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Oct 31, 2010 | KitchenAid Superba KSRG25FK Side by Side...
My samsung ref rt30mass ref compartment is not working properly even with adjustments made from its temperature however the freezer is working properly
The defrost thermostat is not working and the evaporator compartment is blocked with ice. That will stop cold air from entering into the fresh food compartment.
Move your food to another refrigerator, then unplug and open the Samsung refrigerator for 24 hours and allow the ice to melt.
Then remove the freezer panel inside and locate and replace the little plastic tube like part that is zip tied to the expansion tubing. It should have 2 brown wires coming out of the plastic sealed tube/ thermostat part. Write down your model number and go to Samsung's website or searspartsdirect and buy a new thermostat.
I believe the operating range for said thermostat is 20 C to -5 C. you'll most probably have to cut the wires and splice in the new thermostat. You can also use a generic thermostat with the same or nearly the same ratings of 20/-5 C temp.
All the thermostatic switch does is control the defrost heating element that melts the ice off the evaporator every 10 to 12 hour cycle via the defrost timers switch located at the bottom rear of the refrigerator. You can turn the clock counter clock wise until the first loud click to force the machine into defrost as well. Although if the defrost heating element, thermistor, THERMOSTAT, or defrost timer switch has malfunctioned there will not be a defrost cycle and ice will form inside the ducting and evaporator compartment and block the cold air circulation and the fresh food compartment will not cool and the freezer section will barely freeze water.
May 19, 2010 | Refrigerators
Frezzer working,freshfood side not,ok I stopped motor several times and it work four days and agin the problem. Is there a sensor in the freshfood side? or a little fan inside?Pls Help me
Hi, you got a defrost problem, when to much ice build up after few days,cooling decreases. it could either be your defrost heaters are burnt out, faulty defrost timer, or faulty defrost thermodisc, which are usually at back of freezer, you will have to remove back panel of freezer, and cary out continuity test, to see which ones are defected. the defrost timer sometimes could be found inside of refrigerator compartment or at back of ref. different models, different location, you didn't say what made ref. you got, surely you got a defrost problem, you will need a mechanic to get it check, if your days are hot, or if you got door gasket problem, or someone forgot door half open for few hrs, or excessive hot air getting into ref, could cause that too. before calling mechanic, you will need to empty ref. and unplug for few hrs, clean out all ice, surely it will work, but if problem continues, call mechanic.
Aug 07, 2009 | Refrigerators
The freezer is working but the ref is not
dani, your defrost system is not working. Call the mechanic back and tell him to go through the defrost cycle. Since you have this listed as a generic problem, I can only tell you what to look for. You are going to have a defrost timer, either adaptive or mechanical. A bi-metal and a heater. He needs to put the refer into defrost and go from there. Tell him to ohm out the heating element on the evaporator to see if it is good. If that's good, then he needs to see if it is getting voltage while in defrost. If it's not getting voltage, its either the bi-metal or the defrost timer. Simple process of elimination. If the bi-metal checks out, then it's the defrost timer. If he charged you for changing out the thermostat, tell him to apply the wrong diagnosis to the right solution. Tenbears. If its a GE, let us know because you have a whole differnt ballgame there.
Dec 24, 2008 | Refrigerators
Frigidaire Model number frs26znh defrost not working?
The defrost systems is:
218169802 HEATER-DEFROST
5303917954 THERMOSTAT-DEFROST
5303917954 TIMER-DEFROST
Start with the timer. It is just under the front kick plate. there is a knob you can turn it slowly.until it clicks off the compressor. then open the freezer and listen . You should hear the heater come on .. it will sizzle when it comes on ...
You will have to remove the back panel of the freezer to check the heater for and thermostat for continuity. Heater are the lease likely part to go bad... I always change thermostat and timers together.
let me know if this helps or we can chat if you need more help.
Jul 23, 2008 | Frigidaire FRS26R4A Side by Side...
Defrost thermostat connector
Where is the defrost heater? If it is below the problem area, I don't think it is a defrost problem. This sounds like low freon. The symptoms of this are heavy frost on only part of the coils. Try deforsting with a hair dryer and putting it back together. Wait about 3 hours and look again. If there is frost only on part of the coils that is bad. The most this unit could defrost is every 4 hours, most are on 8 or 12 hour cycles. On most units the defrost timer shuts off the compressor and gives current to the defrost heater/s through the defrost thermostat. This thermostat is closed below 15 degrees and opens at a much higher temp after sensing the heat. This shuts off the heat usually before the timer and lets the water drip down where it should go. Then the timer turns the compressor back on and removes current from the defrost system. A common defrost problem is if the doors are left open for a LONG time or not shut all the way. Sometimes it causes so much ice that it can't melt with just one defrost cycle. This problem builds as if air flow is restricted it causes even more frost and gets worse. If this ever happens , just find the defrost timer and turn it very slowly click by click just until the compressor stops. Let it defrost , then do it again in about 2 hours. If it is a low freon problem there may still be a partial warrenty left sometimes the sealed system is guarenteed ror 5 - 10 years. Sometimes if it is not covered it is not worth fixing.
Jul 04, 2008 | Refrigerators
Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Jun 20, 2008 | Refrigerators
GE (GTS16BCS) Top Freezer Refrigerator Logo
85 people viewed this question
Top Refrigerators Experts
Brad Goodale
R.A. Ellis
R.A. Ellis
Darrin P. De May
