Question about Mitsubishi VS-55705 55" Rear Projection Television
Keeps scrolling through device menu rapidly
Mitsuishi rear projection 65" when I turn it on it just keeps scrolling through the device menu rapidly
  • 1 more comment
  • mjibd Apr 19, 2009
    Not usually but as of now the tv will not respond to the remote or the buttons on front of the tv the only button that works on the front is the power button what happens is when I turn on the tv the device menu is displayed and it just keeps scrolling the highlight device continually
  • mjibd Apr 20, 2009
    Thanks, for now I unplugged the small connector plug behind front grille cover that goes to that button
  • ZaneD
    ZaneD May 11, 2010
    do you ever use the buttons on the front of the unit?
  • 41 Answers
The device button on the front panel is being held open. This is something that would happen over time, nothing that you can do to prevent it. I would recommend getting a button and soldering it on to the front panel.
Posted on Apr 19, 2009
  • ZaneD
    ZaneD Apr 20, 2009
    Glad to hear it.
WHY DOES IT KEEP TURNING OFF
Yes. Rear-proj.with 3 picture tubes. These, like most newer tvs have self-checks that shut the tv off if the fault could worsen problems for the TV (such as damage picture tubes.) or it's not able to put a picture up.
After it shuts off, you can press menu and input/device together for 5 secs, and it will flash a 2-digit code (such as "23" or "24", etc.)(vertical or horizontal error.) Though you will need to call a repair shop for repair. It's usually better if they are Mits. factory authorized, as they'll likely have more exper. on Mits.
Apr 24, 2014 | Mitsubishi WS-65511 65" Rear Projection...
Adjusting screen size
there should be a menu function on the tv remote push that to bring you to options and scroll around for picture
May 31, 2012 | Mitsubishi WS-65315 65" Rear Projection...
65" mitsubishi rear projection tv won't turn
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Oct 09, 2011 | Mitsubishi WS-65611 65" Rear Projection...
I have a Mitsubishi WS-65513 65 in. rear projection HDTV. I recently hooked up a DVD player to the Component 2 cable inputs but I cannot find the Component 2 selection on the 'Device menu' to tell the TV...
If one or more of the inputs is "missing" or not there you may need to do a hard reset of the TV with the original remote.
If you want to try this confirm the actual model number and I will tell you how to do it.
SD TECH
Dec 11, 2010 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 65' The red keeps going out
It could be a loose component video cable, check your TV menu or another device when it goes out. If you have red in the menu or other device, it cannot be your CRT. The Crt is somewhat hard to replace but if everything goes great it isn't too bad. I usually mark all the yokes and magnets with a marker so I can put them right back in the same place and the picture should be about the same. Sometimes you need to do a lot of adjustment and that is when it can get tricky, kind of depends on how "identical" the new CRT is to your old one.
Let me know how I can help
Jun 09, 2010 | Mitsubishi WS-65513 65" Rear Projection...
Picture slightly too big
To reset the convergence EEPROM, press "menu 0359 to enter the convergence menu, then press "8970" to reset.
Sep 08, 2007 | Mitsubishi WS-65613 65" Rear Projection...
Device menu continously selecting input devices
Did you try resetting using the RESET button on the front of the TV? Also what "input" card are you pulling?
Mar 09, 2007 | Mitsubishi WS-65611 65" Rear Projection...
Open Questions:
Mitsubishi VS-55705 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
