Question about Amana DLE330RAW Electric Dryer
Replacing a pigtail
I have a purchased a used Amana dryer, and am tying to attach a new pigtail. I dont know how, and there is no wiring diagram to help me. I also dont have the manuel for reference. How do I attach it?
  • 709 Answers
You hook the Red and Black wires to the gold colored screws on the dryer, and the white wire goes to the siolver colored screw. The Green wire goes to the Body.
Posted on Sep 28, 2007
SOURCE:
I need wiring diagram for rear abs on a 12 ram 1500
why dont you wait till part comes in
Sep 03, 2018 | Dryers
Amana dryer wiring diagram model4655ew
Request the wiring diagram directly from Amana.
Aug 20, 2018 | Amana Dryers
I am reasambaling dryer I have 4 wires to attach two small blue wires and a thicker pair gray and blue where do they attach
where you took them off.
you shouldve marked each wire or had a wiring diagram,now you are here giving no info and wanting help,you dont tell us make or model or s/n etc,how do you think that there is even a manual for your dryer?
Mar 21, 2015 | Amana Dryers
Changing dryer plug
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Oct 07, 2009 | Amana NDE2335AY Electric Dryer
I just bought a used amana dryer that is 1 year old. it has a 3 wire pigtail and i have a 4 wire plug in and need to change out the pigtail. need some direction on if possible to change it out or will i...
go to the local hardware store and buy the male plug for the female plug that you have in the wall just hook up the three plugh in place of the 4 wire plug. The 4 wire has a netural and a ground which is the same thing and two 110 hot wires that are 110 v each, hook up the copper colored wires to the copper colered wires and the one ground on silver. screw or white to silver wire. this is Ground you only need one ground and if the plug on the wall is three prong it is go to use a three wire plug the third wire is for a backup ground on new systems
Oct 04, 2009 | Amana NDE2330AY Electric Dryer
It came with no instructions and i need the wrirng diagram for the new pigtail that needs to be tied into the wiring...
Usually Wires are color coded, and if you have multiples of the same color you will most likely need the old pigtail to identify which wire goes where in the pigtail. If you don't have the wiring diagram handy that's the best way to do things. Haynes and Chilton manuals have those with wire color information if you don't have the original pigtail to use as a reference. Without more information on what area you're working on, I can't be of any more help than that as some sensors have multiple voltages that go to and leave them from the computer it's connected to.
Aug 08, 2009 | 2004 Chevrolet Malibu
Used maytag electric dryer installation question
First off, you should be wiring your power cord directly to the terminal block inside the dryer. If someone just cut off the cord that is terminated inside the dryer, and you are attempting to splice the new cord onto the old one.. you are making a mistake.. take the new cord and bond it directly to the terminal block inside the dryer. If you have a new 4-wire power cord, you are probably dealing with a red/black/white and green wire. ( assuming it is a four prong plug).. The black and red wires are the power lines themselves and should mate with the red and black wires inside the dryer. The green ( is frame ground) and is normally bonded to a stud near the terminal block or the dryer frame. The white is the neutral line and is normally tied to the terminal in the middle and between the red and black tie points.. In line splices should not be done on this appliance.. Hope this helps..
Sep 06, 2008 | Dryers
I just purchased a new home and the pigtail of my Amana dryer is different than the electrical outlet and the dryer does not have a schematic to install a new 4 wire pigtail. Is there an adapter to change...
There are no adapters. But a dryer will accept a 3 prong or 4 prong cord. The extra green wire just needs to be connected to any screw on the dryer casing. Some newer dryers have a screw there for it..or u can just use the closest screw avalable......usually the screw for the cover works good.
Apr 20, 2008 | Dryers
Amana DLE330RAW Electric Dryer Logo
599 people viewed this question
Top Amana Dryers Experts
Marvin
Marvin
jdthefixer
Android Man
Android Man
Are you an Amana Dryer Expert? Answer questions, earn points and help others
