Question about Kodak Ektagraphic III ATS Slide Projector
I live in nyc where can i get replacement bulbs for the ektagraphic
    President:
  • Kodak Master
  • 412 Answers
The KODAK Ektagraphic ATS uses a 82volt, 300 watt ANSI code "EXR" lamp. You can order "EXR" lamps from Bulbman (www.bulbman.com)
Posted on Nov 04, 2010
I have a Kodak Ektagraphic with no model listed on it at all. How can I find a replacement bulb, all I can find look wrong.
Supplied with 82V, 300W EXR lamp Projection Lamps Quartz-halogen 82 V projection lamps- Here is service manual link http://resources.kodak.com/support/pdf/en/manuals/slideProj/manual/ektagraphic_sm.pdf Several different Models all say EXR 300W As CORRECT Bulb : EXR, 300 W (35-hour lamp life at full lamp/medium-brightness) Sampling of other lamps: EXY (200 hours/less brightness) EXW (15 hours/maximum brightness) FHS (70 hours/medium brightness) Use combinations of lamp brightness, plus half- and full-lamp settings to approximate image brightness in multi-projector presentations. Lamp Tips • Projector operation on line voltages above 125 volts greatly reduces the lamp life. • Unplug the projector before changing the lamp. • Allow for unrestricted flow of air to the exhaust vent to prolong lamp life. • Gently wipe off any fingerprints with a soft cloth moistened with rubbing alcohol.
Jun 27, 2016 | Kodak ATS Ektagraphic Slide Projector
Blower comes on but the bulb won't come on.
Hello, Appears that the bulb is burned out, This is normal for these projectors due to high heat that the bulb produces. These bulb assemblies are very expensive.
Best Regards, Russell
Dec 29, 2012 | Kodak Ektagraphic E-2 Slide Projector
I'm having trouble changing the bulb in a Kodak Ektagraphic AF-1 slide projector. The bulb doesn't fit easily into the housing and I don't want to force it.
First of all, verify you are using the correct lamp: it should be a 120volt, 300watt, ANSI Code "ELH" lamp. (This may seem too basic, but you'd be surprised at the number of people who try the incorrect lamp).
If the lamp is correct and you can not insert it by pushing the base of the lamp into the terminal connector relatively easily, then chances are you have a build-up of material on one or both of the lamp contacts caused by arcing (arcing is caused by loose lamp terminal contacts). If this is the case, then you need to replace the lamp terminal assembly (the ceramic-like white piece the lamp terminals should slide into). You should still be able to buy a lamp terminal assembly for your Ektagraphic AF-1 from: www.micro-tools.com
Good Luck !!
May 20, 2010 | Kodak Ektagraphic III E Plus Slide...
Does bulb need replacement?
I had same problem.
You have to load the slides so there is something to be projected.
Dec 15, 2008 | Kodak Ektagraphic III ATS Slide Projector
126 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
