SOURCE: i have a nordic track a2350,and the incline wont
I've seen this problem several times, but many things can cause it. It's most likely the motor control board, but it could be a number of things. I'd have it looked at.
SOURCE: I have a Nordic track summit 5500 and the front
sounds like a bad console. Look for a used one on ebay, but don't buy a new console, you're so much better off buying a new treadmill
SOURCE: I have a Nordic Track EXP1000i Treadmill. The
I know it's been months, but, if you still have this problem try this: 1. remove the philips screws holding the motor/belt/electronics cover on: you can lay the whole thing on it's side and remove them from the bottom. there's two in the front and two on the sides.
2. Obviously, unplug the unit! before doing anything. lay the unit back on it's feet (normal position)
3. Find the incline motor assembly. it will be int he middle of everything. black tube thingy.
4. take a cordless drill with a flat head screw driver bit, and turn the incline motor CCW. until the bed is flat.
5. what what I have read, you should shop for a new incline sensor. these fail before the motor does.
SOURCE: I have a Nordic Track EXP 1000X treadmill and the
Probably 85% of the time, it's the sensor.
1. remove the screws from the bottom of the enclosure case. 2 or 3 in the front and 1 on each side
lay it back down, and power it up, and actuate your incline. watch the end of the motor, to see if the shaft is moving. It probably IS turning but only a little bit. NOT enough. In this case I'd say it is the sensor.
2. Unplug the unit of course.
3. the incline motor is in the middle of the pack,..you'll see a black tube looking thing sticking up.
4. on the bottom side of this, you will see,..or feel for a black square sensor attached to bottom of the motor casing.
5. follow the wires and unplug this.
6. pry it off with a screw driver. Remove incline assembly, if you cannot reach it.
7. replace sensor and try it again.
if the MOTOR does NOT turn when using the incline buttons, the problem backs up to possibly a bad control board. or a bad motor on your incliner, however, i'd say that's the last thing to go.
Order of failure: 1. sensor 2. control board 3. motor.
good luck
SOURCE: manual for a Nordic Track Personal Performance
Go to iconservice.com click on to manual Input manufacturer : Nordic Track then model # NTL349050 and you manual await you.
o The Nordic Track C2050 allows users to change the incline of the treadmill with a simple touch of a button. This treadmill features both increase and decrease buttons for the incline. The incline of the machine will change by .5 percent every time the buttons are pressed. With each press on the incline buttons, the machine will take a moment to actually reach the incline setting that was just selected.
Capacity of Weight
o Users who are larger than or weigh more than the average person will be pleased with the added capacity of weight that the Nordic Track C2050 allows. Unlike most treadmills in its economy class that only allow a weight limit of 200 to 250 pounds, this model lets users who weigh as much as 300 pounds use the machine safely. Larger people can get the benefits of a cardiovascular workout on this treadmill without worrying about damaging it.
Heart Rate Measurement
o This Nordic Track model allows users to measure their heart rate. All the machine requires is for users to place their feet on its foot rails and grasp the metal contacts with their hands. The Nordic Track C2050 then works to determine your pulse, and the symbol of a heart will eventually show up in the display. After a couple of dashes show up, your heart rate will be displayed. Users who want to be certain of getting an accurate reading should ensure their hands are clean when gripping the metal contacts.
sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
