Question about Canon FAXPHONE L80 Laser
Will not receive faxes
The machine was working until yesterday. There is a dial tone when the handset is lifted. Our regular office phones are working. When you call the fax number, it rings instead of offering the fax tone.
  • 163 Answers
Put your fax at auto receive it is now on mannual receive
Posted on Sep 21, 2007
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
I have a Brother 775 intelli fax machine. I can't send a fax. After loading the document, when I go to push in the fax number, the numbers do not register. I unplugged the machine from the power and the...
Hi there!
For you to send a fax with the Brother Fax 775 you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still connect it to another working outlet. If you don't have a dial tone still connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
Thanks!
Mar 30, 2011 | Brother IntelliFAX 775 Plain Paper Thermal...
Multifunction phone/fax/copier machine
Hi sythonk
1. Make sure you have a telephone cable connected the jack labelled "LINE" on your brother machine.
Go through the Menu on the LCD, Initial setup, dial tone, choose the correct dial tone PULSE or TONE.
Exit from the menu.
Pick up the handset on the fax machine, and dial your nuber to make a phone call. (To send a fax, dial the number without lifting the handset.)
Hope this will work for you. If it solved your problem, give a please rating
Cheers
luciana44
Sep 06, 2009 | Brother Office Equipment & Supplies
Phillips magic5 problem
Hi, I had this problem and spoke to sagem at www.sagem.com/support.
the solution is simple, turn off your fax machine at the wall, take out your batteries from the handset and leave both off for 15 minutes. then turn on the fax machine and replace the batteries back in to your handset, at it will work.....
Jun 15, 2008 | Philips Magic5 Voice DECT Duo - Fax /...
FAX function stopped working
honestly, it sounds like you have the phone cord and the fax jack swapped backwards, make sure you have the fax line plugged into the correct jack on the machine. 1 is for the handheld phone and the other is for the telephone line... give this a shot...
Mar 10, 2008 | Brother MFC-7220 All-In-One Laser Printer
HISSS on line; no dial-tone; no fax in or out
it sounds like you may not have any dial tone. the hiss [white noise] you are hearing is from the dsl modem.try plugging a regular corded phone into the jack to check for dial tone.if there is none,call your phone company.also try plugging the fax machine into another jack where you know there is dial tone.
good luck
wg
Feb 02, 2008 | Brother FAX-2920 Plain Paper Laser
Outgoing fax never goes
Do you have the same problem with different numbers that you fax to? Are you usinga voip phone service? I use Vonage and have a lot of trouble with faxing. Call the number you are faxing to with a different phone and listen for a fax tone.
Aug 16, 2007 | Brother IntelliFAX 2800 Laser Fax
Canon FAXPHONE L80 Laser Logo
108 people viewed this question
old marine
old marine
