Question about Nikon Coolpix 3700 Digital Camera
Zoom and Shutter not working..
I just returned from visiting Niagra Falls. The camera was working fine till then and I clicked some awesome pictures, some of them in the spray. However a few hours later, the shutter refused to work. I dried it using a hand drier. But it still refuses to work. The zoon and the shutter both refuse to work. Any suggestions on how I can rectify the problem? Thanks in advance.
    Genius:
  • 2,985 Answers
Well you probably wont, but try this find a suiutable zip shut poly bag and place in it a a quantity of uncooked rice or salk wrapped in a cloth tied in a knot.-or some silica gel sachets if you can find them. Take the batteries and card out leave the chambers open- and put the whole lot in a warm dry place for a couple of days.The ides is to draw out moisture. But going back to my original comment - moisture is death to digicams especially if there are operated in those conditions with out suitable protection.
Posted on Sep 19, 2007
My S800 has been amazing, however since Thursday when I take a pic and zoom in, the image is very bright, or white and has lines all over it (looks like a bad canvass painting, non zoomed images are fine!...
Hi, the problem is in the shutter that you can found inside of the lens unit and maybe the shutter not work properly or damage. you will notice also once you take picture during night time the pictue is good but if you zoom in you will find the lines all over the picture.
tryo to open your camera and check the lens unit. First try to disconnect the the lens cable and connect then check. if the problem still occur, you need to do is open the lens unit and adjust the shutter if working fine or not.also check the flat cable if its not broken.
if you can't do this bring to service center
goodluck and thank you my friend
Jul 17, 2010 | Samsung Digimax S800 Digital Camera
Why do some pic's I take blurr and I'm not moving the camera.
Hello. I have the same camera as well as the z712 and the P880. They are all top notch cameras. If your setting is auto focus be sure to hold the shutter button HALF WAY down till you get "a green'' signal then shoot. If you don't get a green shoot signal your zoom may be too high. It's very hard to shoot at high zoom at close range without a tripod.My best results have been put it on auto and shoot like crazy with low zoom till you know what your camera can do . Just take pictures,lots of them. Best wishes. superg
Jan 05, 2010 | Kodak EasyShare Z710 Digital Camera
Fuji E900
Try the video function.
If this works fine then it is most probably the shutter sticking.
To confirm the shutter is sticking turn the camera on, put the zoom to full optical and turn it to face you so you can see into the lens. Watch the inner part of the lens when you take a picture. You should see the shutter fire across the lens. Lines on pictures or over exposed pictures are caused by gaps in the shutter or the shutter failing to fire altogether.
Moisture residue on the shutter leafs is the common cause for this problem.
Some people on here have their own views about what causes lines on photo's. Someone even said digital cameras do not have a shutter and problems were due to software issues....
I have dealt with 100's of different models, including Fuji's E900 and always have found moisture residue to be the cause.
Dec 11, 2009 | Fuji FinePix E900 Zoom Digital Camera
The lens cover won't close when powered off
I am loath to suggest hitting it hard (which is what I usually do to mine!) but one solution that tends to work well on the TZ3 is to pop the end of a shop-vac over it when it's turned on. This will **** out any gunk that has got in there that may be blocking it.
Jul 06, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
No picture in view screens ? appeture
Hi
First check whether lcd mode is one...
Thank you
Dec 21, 2008 | Fuji FinePix S20 Pro Digital Camera
Olympus mju zoom 140 35mm camera. shutter has started clicking as if taking when zooming (in or out)even when not pressing the shutter button...?
This is like to be the zoom motor playing up.
If the camera is new[1 year or less] return it.
A repair is not a likely option.
Jul 23, 2008 | Olympus Cameras
Blank Screen
ok casio luver you have eather a broke lcd or a damaged main board. visit www.digitalcamrepair.com for more help.
May 05, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Picture quality has become terrible
Ed, The shutter on your camera has become stuck open. This causes the lines across your pictures. If you take the camera outside or shoot in bright lighting conditions the pictures will come out over exposed. The fix for this problem requires complete disassembly of the camera to access the shutter assembly inside the lens. It is a fairly common issue due to the fact that the shutter is such a delicate component. Check with your manufacturer for warranty support or recalls. If they are unable to help you for free, there are repair providers which you can find online who will repair your camera for a reasonable rate. David Millier Advance Camera Repair
Mar 22, 2007 | Samsung Digimax i5 Digital Camera
Camera only half operates: preview mode OK, picture-taking mode not working
Mine shuts off when I press the shutter button. I put in new batteries and I can get the lens in then. But it shuts off when I try to take a picture. These cameras are notorious for having a zoom problem. They say the Zoom error appears and the camera dies. There is a fix of gently pulling the lens out all the way till the cover open then twisting it gently clock wise till it clicks. They say this fixes this problem but I don't think that is what is wrong with mine. Do a search on Fuji E550 zoom problem fix. It should show up.
Feb 16, 2007 | Fuji FinePix E550 Digital Camera
No picture
it seems that the flex ribbion cable from the camera body to the lense assembly is damaged. A good repairer can replace it.
Oct 28, 2006 | Samsung Maxima 120Ti 35mm Point and Shoot...
Nikon Coolpix 3700 Digital Camera Logo
50 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
