Question about Fuji FinePix F460 Digital Camera
I have a fuji finepix F460 which displays 'zoom error' and the lens is not retracting fully. I have removed and refitted the battery and tried all buttons but the lens doesn't move. Is there a reset procedure please? Thanks David
  • 244 Answers
Either the focus mechanism has jammed or the drive gear has sustained damage. Only way to be sure is to open it up and have a look. I have photos if you want to have a go yourself. my email is listed in "THE ONLY WAY I KNOW HOW..." In the tips & tricks section. Dave
Posted on Apr 21, 2009
My f460 says zoom error
Here are some troubleshooting steps for Fuji "zoom errors".
Dec 09, 2012 | Fuji FinePix F460 Digital Camera
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
I have got a zoom error on my fuji Finepix V10. When you turn the camera on the zoom starts to come out and then quickly retracts. How can I fix it?
Sounds like the timing for the sensors on the lens are out and will need to be reset.
lens unit will need to be removed and reset
Jan 02, 2010 | Fuji FinePix V10 Digital Camera
How do I fix the Zoom Error for Fuji Finepix F47fd? I can't even extend the lens fully like what previous posts stated
Hi Jasmine,
With fresh batteries inserted in your camera, try to do this little trick:
1. Hold the camera on your right hand with the lens facing the ground.
2. As you press the power on button, tap or hit the camera's base to your left palm. Do this several times.
Chances are, there could be a sand or granule of dust that got stuck on the sides of the lens, preventing it to retract properly.
Hope this helps.
Dec 13, 2009 | Fuji FinePix S304 Digital Camera
Zoom error ( stuck) fujifilm finepix s2000 hd
The lens is having a hard time retracting out that is why it is giving you that error. Make sure that your battery is fully charged and if it is, but still does not do any good, then do this little trick:
Hope this helps.
Nov 27, 2009 | FUJIFILM Finepix A200 Digital Camera
Lense won't close
Does it make a noise when trying to close? Does the lens zoom ok or is it just stuck firm?
Possible solution and/or email help available in "THE ONLY WAY I KNOW HOW..." In tips & tricks. Thanks
Apr 12, 2009 | Fuji FinePix F460 Digital Camera
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Error message now showing
Does the lens extend and retract as normal?
If so then the internal drive gear for the zoom / focus has been damaged and will need to be repaired/ replaced.
If the whole lens will not move or is stuck then it needs to be removed, stripped and re-assembled.
Feb 18, 2008 | Fuji FinePix F45FD Digital Camera
Usually down to the lens block assy being faulty.Is the lens retracting and opening properly?.It usually turns out to be worn gears in the lens drive assy or the result of a fall.Either way will be expensive repair!My advise is check and see whether camera is covered by insurance for accidental knocks.,
May 09, 2007 | Fuji FinePix A400 Digital Camera
Fuji FinePix F460 Digital Camera Logo
337 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
