Recently the indiglo light on my Timex Ironman Triathlon watch started to malfunction. When pressed, the light made the actual display unreadable. After the 5 seconds or so, the display would reappear. Now the display can not be read at all if I look directly at it. In order to read the time (or anything on the display), I must look at the watch from a very steep angle. The date and time function properly, but the view isn't working right. It is almost as if the contrast angle has been changed. Any help here would be apreciated. I have had this watch for a number of years and have not changed the battery. Would that be the place to start?
Thanks!
2 Other Users Have The Same Problem
Comment by Guest, posted on Apr 02, 2008
I have the same problem..all other watch functions work perfectly except the indigo light function..it is a very handy function esp in the middle of the night or early am..should I have the battery replaced?
Best,
Pat
Comment by JazSox, posted on Dec 02, 2007
I've been having a similar problem with my T53771 (see image). When I press the indiglo button, the indiglo comes on, weaker than before, but the display disappears for the whole time indiglo is on. Then the display comes back when indiglo turns off. Any thoughts? I haven't tried the battery yet...
Rating: 0%, 0 votes
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
Once the back is off the next step is to remove the old battery.
There is another screw about the size of the screws holding the back on that holds the metal ring that the battery fits into to a part of the circuit board. Remove that screw. Now you can lift the entire battery and metal ring completely out of the watch.
The next step is to get the old battery loose from the metal ring that it is mounted to. The 2 pieces attach together firmly so that
it almost looks to be one piece but it really is 2 pieces... the battery and the metal ring. Carefully remove the old battery from the metal ring, put the new one in in the same direction you took the old one out, set the new battery and ring back into place in the watch, replace that once screw that holds the battery to the circuit board, then put the watch back back on, being careful to put it back on in the correct direction. Make sure the printing on the back of the lid is facing up... if you put the back on upside down it will still fit, and the watch will still work, but you will loose all your beeps and the alarm will not work - well it still works but you can't hear it because the beeps don't work. This was another item I found out about on the net and someone else posted the solution. Then, put the 4 screws back in the back of the watch, tighten them down, then reattach your band (putting the pins in is tedious - this part took almost as long as the whole rest of the battery replacement, but the second time I did it it went faster...yes I put the back on upside down the first time and had to go back and flip it around so I got to play with the band pins twice).
Anyway, hope this helps. You can do the repair yourself and possibly save yourself some money if you are careful, don't get in a hurry, and have the proper tools. You might need to buy a small screwdriver set to get the screws loose and to pry the pins loose from the band.
As the watch was on guarantee i returned it to Timex who amazingly returned the same watch and a new replacement with indiglo working.I was amazed,atleast i expected only one watch but two for the price of one was amazing.
I cannot remember the reason behind it but for customer service Timex must rank as one of the friendliest and most professional companies ive dealt with over the years.
Whether it still remains company policy to return the original watch plus a replacement im not sure but write to them you never know.
Now if the watch had been a Casio it would have been a different outcome.Their customer service was on the other end of the scale to Timex,a very expensive repair bill and poor customer relations.
Contact Timex by letter first explaining your problem,i doubt their superb customer service will have changed.
I still own both the watches and still look back with amazement at how i was treated by this superb company.
Ps I donot work for them honest.
Good luck
Peter
Though having said that - Watch batteries of the standard type are go/no go- they do not fade as such.
The illumination is another thing- if this were a standard LCD screen - such a camera then what you describe is a sure sign the backlight has failed.
But a wath with a backlight- I dunno
Only a Watch /Jeweler maker could tell you.
And you know what they say about tika tika Timex
Its true- They don#t get fixed.
But try the battery route first- pe haps in a in store so that if it does not do the business you wont have to buy a fresh battery to dump with the dud watch.
Other than that, I admit I really like the Ironman, so easy to use and set.
Good Luck
Comment by mark05162008, posted on May 16, 2008
Rating: 0%, 0 votes
Can you Help with these Watches problems?
Swatch Chronograph Watch
timex expedition compass...
Radio Frequency
