Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
No brakes on craftsman dl 3000 riding mower - Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
  • COUGHY_MAN May 11, 2010
    On the rear wheels, usually the right, there is a brake on one of the sides, the nut on the adjuster is 1/2 inch, try screwing it in a little, put the mower in neutral and apply the brake. Keep making small turns until the mower will not move, release the brake and it should move...this adjusts the brake
  • 86 Answers
Check to make sure brake rod spring is connected,also pads could be bad if older mower,there are two nuts that lock into one another turn in oppisite directions to seperate then adjust back one then tighten other one .
Posted on May 10, 2009
Replacing a mower brake tension spring
Mower Brake Return Spring Replacement - Craftsman ...
? 2:15
www.youtube.com/watch?v=kyuE5NBR5xU
Jul 31, 2014 - Uploaded by RepairClinic.com
This video provides step-by-step instructions for replacing abrake return spring on Craftsman riding lawn ...
Oct 27, 2015 | Craftsman Garden
Have a craftsman model # 917.272121 riding mower . stalls when brake is released
Craftsman mowers generally have a safety switch under the seat. This most likely is your culprit. You disconnect the switch, or find the switch terminals on the side of the seat and stick a business card between the contact points... either method.
Oct 02, 2015 | Craftsman Garden
What do I need to be able to use my Snowblower attachment Craftsman 2 stage blower 486.24839 933 on my Craftsman Riding lawnmower YTS 3000
Michael Brady,
Here is a customer contact reference for your records. For help and evolvement. Sears Customer Phone Number Shortest Wait Best Support .
Here is a review and site you can navigate for your decision Craftsman Dual Stage Snow Blower Tractor Attachment .
This second link shows a Husqvarna as an option to your rider Sears com. If it does not apply. The following will guide you to success
I have best results in the past by utilizing this link Craftsman Riding Mower Tractor Parts Repair Parts . Repair help and ask an expert in their arena.
Open any manual, there, are options for contact and assistance. Here is a phone number in the meantime for customer service 1-800-252-1698. You will see this example.
Fare well
Sep 30, 2014 | Craftsman Garden
How to fix my craftsman riding mower, whcih dies after engaging blade
make sure blades not jammed. with mower off, try turning blades by hand.
it could either be a safety switch in the seat or for the reverse paddle.
make sure its not in reverse when you attempt to engage blades.
you should be able to bypass both switches with a jumper wire for testing purposes. if it works with jumper, replace the switch(s).
Sep 01, 2014 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Why doesn't craftsman mower tractor yt 3000 charge?
If the battery is below around 11.8 volts it never will charge. The charging systems on these mowers are made to "maintain" the charge. Check the battery, if below 11.8 volts charge the battery with a battery charger. Then see if the mower will maintain the level. If not, you may have a bad battery. Your local automotive store can check it for you.
Jul 08, 2014 | Craftsman YT 3000 42" Briggs & Stratton 21...
I have a Craftsman YT 3000 cutter. The top belt ( drive train ) belt slipped off how can i get it back on
If you could supply the number under the seat like the following I can answer your question with a diagram.4_10_2012_8_58_29_pm.jpg
Apr 10, 2012 | Craftsman YT 3000 42" Kohler 22 hp Gas...
My riding mower won't start. It's a Craftsman
Check your seat switch and brake switch for loose wires.Most likely brake switch do to no spark at plugs,see if PTO switch/lever isnt on.
Nov 22, 2009 | Craftsman Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
624 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
