Question about John Deere 6300,6300l,6400,6400l Tractor Radiator
Where do I find a starter switch for an AMT 600?
Starter switch is burned out.
    President:
  • 1,627 Answers
The starter solenoid is either bolted to the back of your starter or it's just behind the alternator-depending on you serial number.John deere calls it the starter relay.If you actually need the starter solenoind on the starter then it's easier to find,see your dealer.
Posted on Oct 20, 2009
My yamaha fazer won't start 600 1999 plate
Hi, Anonymous before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid or starter circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Fazer 600 won start
FAZER won start
Yamaha FZS600 98 Service Manual
OEM parts for Yamaha
Yamaha FAZER FZS600 Owner Manual
Apr 22, 2012 | 1999 Yamaha FZS 600 Fazer
1996 fzr 600 wont start
Hi, Anonymous and the usual suspects are:
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
10. Starter control circuit, relay, or solenoid faulty.
11. Main fuse or circuit breaker may be blown or faulty.
12. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
13. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
96 fzr 600 wont start pleeeze help me
My 1993 Yamaha FZR 600 Won Start
Yamaha FZR 600 Service Manual
http://www.journey.cz/moto/navody/Yamaha%20FZR%20600%201999%20owners%20manual.pdf
Mar 06, 2012 | 1995 Yamaha FZR 600
93 shadow VLX 600, insert key, turn on ,all lights work except the headlight,(checked bulb-good), checked, starter , starter relay, battery, ignition, on switch, start switch, electrical connections, no...
You either have a broken/disconnected wire or you have a bad starter button. The starter button is a two position switch. Push it in half way and the headlight turns off. Push it in all the way and the solenoid engages the starter. The button is either dirty or broken.
Aug 30, 2010 | 1993 Honda VT 600 C Shadow
Jus bought a 91 ninja 600 and wont send any power to the starter
Lets start with the basics...
1. be sure your battery is in good shape and fully charged ( at least 12.6 volts)
2. starting procedure- ignition key to 'on', tranny in nuetral, right hand kill switch to 'run', pull clutch in fully and hit starter button.
3. does it do anything? clicks?... If you get nothing then the problem is likely in the clutch switch, kill switch, or the starter button. You will need a wiring diagram and volt meter to trace down where the power is lost. If you are getting 12 volts to the starter but its not engaging then you can suspect the starter/ solonoid.
PS... My clutch switch has been going bad for a few years now ( Im too lazy to replace such a trivial thing as a safety switch ;). Sometimes I need to hold the start button and work the clutch till the starter engages.
Jan 04, 2010 | 1991 kawasaki ZZR 600
93 FZR 600 RAN BUT WHEN i SHUT IT OFF IT WONT CRANK AGAIN
check your fuses first should be one under seat and maybe by head light then battery connection make sure it si tight leave key on the whole time you do these tests then try to jump off the starter with rubber ended screw driver touch positive to a ground then check connections to key switch with test light if u are getting power to the key switch and nothing happens order a new key switch bike will not fire unless switch is making contact with battery good luck let me know how it goes
Jun 23, 2009 | 1993 Yamaha FZR 600
Suzuki 600 bandit won't start
It could be the starter, or it could also be the starter switch or more over have you first checked tht engine 'kill' switch? If its on 'off' (Kill) position the starter won't operate from the button!
Other way is to short circuit the starter throught the solenoid switch and see if it works.If it does work thn the switch (button) is faulty you may hve toreplace it or sometimes a good cleaning can revive it due to carbon deposits at the contact points.
Thirdly, I hope the battery is at its top performance too!
Hope this helps.
May 11, 2009 | 1997 Suzuki GSF 600 S Bandit
Just Won't Start :o(
Hi and welcome to FixYa,
The click is significant. This indicates that the starting relay is engaging but for some reason, the starter motor is not cranking. This could either indicate a faulty starter relay (particularly the contacts) or a faulty starter motor (specifically, the carbon brushes). To determine which:
  • with the side covers off, expose the starter relay particularly the 2 large terminals;
  • have somebody start the bike normally using the key and button start switch;
  • determine if indeed the clicking is coming from the starter relay;
  • while the start button is still pressed, jump the 2 big terminals;
  • if the engine cranks, then the internal contacts of the starter relay are corroded or burned;
  • if the engine will not crank, then the starter motor is faulty.
Good luck and thank you for using FixYa.
Feb 22, 2009 | 1999 Suzuki GSX-R 600
My bike wont start up, fuzes are good, oil good, new battery. Bike wont turn over to star.
Initially, determine if there is a clicking sound when the START button is pressed. The click is significant. If there is, this indicates that the starting relay is engaging but for some reason, the starter motor is not cranking. This could either indicate a faulty starter relay (particularly the contacts) or a faulty starter motor (specifically, the carbon brushes). To determine which:
If there is no click, you may want to check the alarm/security/immobilizer if your bike is so equipped. others to check would be side stand switch, clutch switch and neutral light indicator.
Feb 21, 2009 | 2004 Yamaha YZF 600 R thunder cat
John Deere 6300,6300l,6400,6400l Tractor Radiator Logo
357 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
