Question about Legacy 12'' 1200 Watt Red Series Subwoofer Car Speaker
2 dual voice coil 12" 1200 watts subs
How do i wire them and how do i hook them up to a 2/1 channel amp thank you
  • Anonymous Mar 24, 2014
    How to wire crunch mono 1500 watt amp
  • 752 Answers
Are they dual 2 ohm or dual 4 ohm?
Posted on Sep 22, 2007
Wiring a crossfire vr602 at 4ohm
OK what you are saying now is that your speakers are dual voice coil; models? 4 Ohms per Coil? I have always used single 4 Ohm Voice ciol speakers since amps are mostly based on 4 Ohm outputs. but you can get 8 Ohm dual voice coil subs also. With 8 Ohms per coil you can get 4 Ohms if you parallel the wires. What is best for you and will get you the most stable power and still will be in the specs of that amp is to run the amp in BRIDGED MODE running each subs voice coils in series with each other then run those 2 subs in parallel to the amplifier giving it a 4 Ohm load. So, your will have two sets of wires from your amp 1 for each speaker. Then you will take a short piece of wire that will connect the + to the - of each voice coil then hook up the wires from your amp to each sub What it will be is 4 Ohms + 4 Ohms = 8 Ohms per speaker the 8 Ohms in parallel each speaker to the Bridged amp output using just the + from one channel and the - from the other will give you a total of 4 ohms and power out put of 600 Watts so that ends up being 150 watts per voice coil or 300 watts each speaker
Apr 04, 2013 | Crossfire VR602 Car Audio Amplifier
I have to hook up 4 amps in my car. 4 channel 700 watt ken wood, 2 channel 800 watt Sony, 4 channel 740 watt Jensen ,and a 2 channel Rockford fosgate. Which is best way to hook them up so I'm not ki
Pace posted on Saturday, March 05, 2005 - 01:08 GMT Your subs are dual 4 ohm voice coils so if you want to bridge your 2 channel amplifier to your two subs then wire them parallel, meaning the + to + and - to - ( Do this to both subwoofers), Then run a wire from one positive and one negative on each sub and bring the two positives together and the two negatives together and hook both positives to the far positive connection on your amp and connect both negatives to the other negative on your amp,
This will create a 4 ohm load on your amp.
Although if it's a two channel and you have two subs it's usually pointless to bridge them because if you use one channel per subwoofer its going to be the same as if both subs were bridged. example) 800 watts x 1 bridged power of your amplifie (4 ohms) is the same power as 400 watts x 2 at 2 ohms.
Nov 26, 2012 | Computers & Internet
I need to see a wiring diagram of an MPX 210 speaker box. My brother-in-law bought one from a friend and someone completely jacked the wiring. I just need to see how it should be wired. Pictures would be...
It really depends on what subs you are mounting in the box. If you are mounting single voice coil subs, it's easy. positive of the sub goes to positive on the inside of the box and the negative of the sub goes to the negative of the box. Then you would repeat the process for the other sub. Then wire the box to the amp using the push or screw terminals.
Now if you have dual voice coil subs, that's where it can get tricky. You really have to know what amp your using and what ohm load it can handle, and how many channels you will be using.
I'm going to give you an example that has two dual 4 ohm voice coil subs. Let's assume you will be hooking them to a 2 channel amplifier that is 2 ohm stable.
wire the positive of both voice coils to the positive post of the box. then wire both negatives of the voice coils to the negative of the box. Repeat the process with the other sub. This is called a parallel set up. Two 4 ohm voice coils wired this way will produce a 2 ohm load. since your amp is 2 channel, you will hook the positive and negative to the positive and negative of one side of the box, then repeat with the other channel to the other side. This will allow the most power to come out of a 2 ohm stable amplifier.
If you have something other than the equipment I gave you an example of, repost with your equipment specs and I will walk you through it.
Sep 09, 2011 | Dual QPower 10" Square Slot-Vented...
I have 1 audio bahn eternal series awes15p 15inch subwoofer.I'm having problems hooking it in my vehicle,I don't have the wiring manual.I would appreciate if you can tell me or give me a...
There are some things to think about when you install this.
1. Is the sub a dual or single voice coil?
2. What ohms are the voice coils?
3. Is your amp 2 channel or mono?
4. What are the ohms loads allowed by your amp?
I am going to assume your sub is dual 4 ohm and you want to get as much power out of your amp as you can. I am also assuming the amp is a mono channel amp. (if it's a two channel amp, you can bridge the channels)
Go from the positive of your amp and wire to both positives of the voice coils. Then go from the negative of the amp to the negative of both voice coils. You will have 2 sets of wires to your sub. This is called a parallel set up. This drops the load of one dual 4ohm sub to a 2 ohm load. The lower the resisitance, the more power is able to flow from your amp, giving your more sound. Make sure your amp is 2 ohm stable.
Hope this helps
Aug 25, 2011 | AudioBahn AW1500 Car Subwoofer
I have two different sets of hook ups on my Power Aucoustik 10" Sub. Do I hook up both sides?
Depending on the PA FUBAR you have. The voice coil on those subs are DVC. Dual Voice Coil. You need to know a couple things. What kind of amp are you going to run on it. And what is the resistance (OHM) rating of each voice coil. MY two 12's are dual 4 ohm. Meaning that there are essentially 4 speakers to hook up. My amp currently is not 2 ohm stable in bridged. So what I did is run each speaker in parallel (red2red,black2black) then run to the box terminal. So now the dual 4 ohm voice coils are basically 2 ohm. I have 2 speakers. Now I hook the box up in series. To bring the now two 2 ohm speakers into one 4 ohm speaker. This is called series/parallel setup. My amp sees this box as 1 channel @ 4ohms. The downfall to this is the output of the amp is divided up into each speaker. So instead of sending all 1400 watts to one sub. I will send 700 to each sub. But here is a catch. even though each speaker is half the total wattage it will still be 3db louder. Meaning it will be as loud as 1 sub running 1400 watts. To conclude i need to know how many of those subs you are going to run on the amp.. And the model number of the amp so I can match up your wiring.
Jun 06, 2011 | Power Acoustik FUBAR-12W Car Subwoofer
What would the best way hooking up a 15" memphis dual voice coil sub ran with a 1000 watt memphis d amplifier??
If the amp is a 2 channel I would hook up each voice coil to a different channel. Also, make sure you hook your amp up as close to the sub as possible. With a sub that size you need to eliminate any delay in signal transfer because the sub is so larg.
May 02, 2011 | Car Audio & Video
How do I hook up my 10 inch visonik sub woofers? they have 2 connections?
this is a dual voice coil sub. either have a 2 channel amp hook up to it. or have your mono amp have to sets of wires going out of it to your 2 connections. i dont suggest it but i have had one connection hooked up at a time played it when it blew hooked up the other connection as a back up. just make sure you have the right watt level for each voice coil.
Apr 14, 2010 | Visonik V10DV6W Car Subwoofer
Why does the kenwood kac-9103d has two sets of terminals if its a one channel amp so how do i hook up a dual 12 phoniex gold 1200 watt sub to it
Hello damasogrizzl,
The 2 sets of terminals are connected internally. Having 2 sets just makes it more convenient when wiring multiple subs. The amp is rated for 900 watts RMS into a 2 ohm load. The specs claim that it is stable at 1 ohm but does not give a power rating.
The Radial SD competition series from Phoenix Gold are rated to handle up to 600 watts RMS. If you have the model RSdC124 with dual 4 ohm voice coils, it would be best to wire the voice coils in parallel for a 2 ohm load and connect the sub to one set of terminals on the amp. If your sub is the model RSdC122 with dual 2 ohm voice coils, you should wire the voice coils is series for a 4 ohm load and connect the sug to one set of terminals on the amp. Wiring the voice coils in parallel will result in a 1 ohm load. And, while the amp may be stable at 1 ohm, the sub will be seriously overpowered.
Hope this helps.
Sep 23, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Bridging 800a4
That all depends upon whether or not the sub you are running has dual voice coils or just a single voice coil. The 800a4 is a four channel amp; thus the only way you can bridge it will be 3 channel or 2 channel. If you are running a dual voice coil sub then you can wire the amp two channel and get 400 watts x 2 @ 4 ohms. Make sure that you sub can handle this kind of power though.
Here are the specs:
4 x 100 @ 4 ohms (13.8V - <0.05% THD)
4 x 200 @ 2 ohms (13.8V - <0.10% THD)
2 x 400 @ 4 ohms bridged (13.8V - <0.10% THD)
Fuse: External 60A
Manufactured in 1999 - 2001
Jun 18, 2008 | Rockford Fosgate Punch 800a4 Car Audio...
Amp Will Not Stop Overheating
You say you have 2 p312d2 subs. Ok so the d2 stands for dual 2homs (2 X 2homs voice coils per sub) , conecting in parallel the 2 voice coils of only one sub will create 1hom load to the amp, and if your amp is 2homs stable per chanel that means you are lowering too much your homs causing the overhwating to it.
Sep 25, 2006 | Ultra Linear UL-2200D Car Audio Amplifier
Legacy 12'' 1200 Watt Red Series Subwoofer Car Speaker Logo
254 people viewed this question
Top Legacy Car Audio & Video Experts
Putter71
Level 1 Expert
Robert Little
Level 1 Expert
xxxxxx xxx
Are you a Legacy Car Audio and Video Expert? Answer questions, earn points and help others
