Question about Car Audio & Video
Capacitor for a car
Im having trouble charging my cap... i found diagrams online and followed those but the cap wont go past 5.8 volts. i used a 1k ohm resistor in place of the fuse in the fuse box and connected the positive to positive and negative to ground and used a voltmeter to monitor the cap to 12v. when it hit 5 volts the cap blinks 0.0. We then connected the cap to a bettery charger and it shot up to 18 v and then started counting down to 0.0. when it got to 0.0 it blinked for a few mins then shut off. is it charged? or is there another way to charge it?
  • 197 Answers
I think one side of the cap has blown - they are separately coiled so id say a throw out job and buy a better one unless you pull it apart and locate the problem but if its not charging how you normally charge it then its pretty much bugered! just like a drill battery not charging any more...
Posted on May 04, 2017
  • 1066 Answers
SOURCE: 10A fuse NOT blown in Daewoo Matiz.
the car stereo had a security reset when the batterry died (it thinks, since the power was disconnectedf and then reconnected, that it was stolen and reinstalled in a new vehicle). you may not be able to fix it unless you remember a particular code or "key" cd that is to be used in such a situation.
Posted on Mar 07, 2009
  • 30 Answers
SOURCE: boss 3.5s capacitor?
something in the order of 120 ohms. If you use a 1/4 watt size it will get extremely hot.
Posted on May 18, 2009
  • 55 Answers
SOURCE: 35 Farad hybrid power capacitor not charging
Yes you certainly wire the 12v+ wire directly to the positive post of the stiffening Capacitor, however if you have a one of those test light probes to check for current on a car? They are really cheap but what i do is clamp the one end on to the battery and than touch the probe to the + teriminal of your capacitor, when the light goes out your cap is fully charged. Now if the light does not go all the way out or stays on you have a bad capacitor, and might i ask why the hell are you driving to need a 35 Farad Capacitor anyway?? Damn.. We do show and competition cars here and sometimes use them. I like the BatCap way better, it's a Battery and a Capacitor all in one. Way strong like bull..... good luck... Mark
Posted on Aug 20, 2009
  • 360 Answers
SOURCE: Can I use a 5 amp 240v AC domestic fuse to replace 5 amp 12v fuse
No, that is not a good idea. You can get more than 12 volts DC out of a 240 V AC signal. This may destroy your 12 volt system. Plus, the 12 volt devices won't be supplied with a constant 12 volts DC, it would be going negative voltage, ect.
Posted on Oct 26, 2009
  • 170 Answers
SOURCE: For some reason my capacitor
get a small led or something that runs on 12 volts. i use my 5 dollar 12v test light and hold it to the positive cable thats gonna be hooked to my cap.
hook the other side to the cap, it will light up the test light and in a minute or two the light dims and then goes out, after its out , the cap is charged......JUST DONT LET IT TOUCH THE OPPOSITE WIRE WHEN YOU HOOK IT UP OR YOU DISCHARGE IT and its not funny
Posted on Jul 31, 2010
How do I install the Start Capacitor and Run Capacitor
the 30 uf side is for compressor run cap and 5 uf side is for fan motor. the other capacitor is for compressor start should be able to replace wire for wire.
Sep 23, 2015 | Heating & Cooling
XPS 600: Fans try to start for about 2s after power plug is inserted, then stops; dead. Amber light on MD on until unplugged. Has been this way since left in "sleep" mode for two weeks. Booted...
Unplug the power cord from the power supply for a good 15 seconds or so then press and hold the power button for another few seconds (5 or so). Plug back in the power and see if it boots up.
Jun 07, 2011 | Dell XPS 600 PC Desktop
I just bought a punch 500 a2 amp. i hook up my ground, then try to hook up the power cable and it sparks. my punch 250 was hooked up minutes prior to this so i know my wiring is good. what the heck is the...
The spark could be from the capacitors in the amplifier charging. Make sure the main fuse from your battery is still good and also check all the fuses on the amplifier. Verify all the wiring is correct and make sure none of the wires from inside the positive cable are poking out and touching the vehicle or amplifier chassis. If you have a 1k ohm resistor, you can put it in series with the amplifier power line to slowly charge the capacitors. You can do that by following the directions from the link below. After doing all that, remove the 1k resistor, hook it all up and try it again. If it still doesn't work, make sure your remote wire coming from the head unit has a voltage on it when the head unit is on. You can get a cheap volt meter from a hardware store or wal-mart.
May 21, 2011 | Rockford Fosgate Punch 500a2 Car Audio...
For some reason my capacitor wont charge, I've checked everything! I just bought a boss cap3.5b and I know for sure the fuse is working there is power coming from the battery and the cap is grounded...
Jul 31, 2010 | BOSS AUDIO CAP3-5B 3.5 FARAD CAPACITOR,...
How do i charge a capacitor for sound system?
Hello gradycusick,
I'm assuming that your cap did not come with a "charging resistor" and instructions, or you bought it from someone used.
The recommended way to charge a capacitor is through a 500-1K ohm resistor, at least 5 watts. Connect a DC voltmeter to the cap leads, connect the positive side through the resistor and to battery positive, and connect the negative side to battery negative (or grounded to the vehicle frame). Do not hold the resistor. It will get HOT. When the voltmeter reads 12V, the capacitor is charged.
If you do not have the resistor or a voltmemter, you can simply use a 12V automotive bulb. Just connect the bulb in series with the battery positive and the capacitor and connect the negative side of the cap to battery negative. When the light goes out, the cap is charged.
You can see an example of both methods here.
Hope this helps.
May 04, 2009 | Car Audio & Video
Resister burnt
Guest and Lesfix. RU83 located on the DRC8335 VCR PCB is a 51ohm 1/4 watt 5% tolerence resistor, color coded green-brown-black-gold. As to zener diode DU83, I haven't been able to determine it's value yet but am working on the problem.
Be aware when either or both these components fry, this indicates you need to replace the following two overheating capacitors on the power-supply board, which were directly resonsibile for knocking them out:
• C216 1000µf 16 volt (upgrade to 35 volts)
• C218 1000µf 10 volt (upgrade to 35 volts)
Could you email me regarding this problem when you have time. Mention Fixya and DU83 in the subject line so I realize it's from you. Thanks.
Oct 02, 2008 | RCA DRC8335
Bad Mits capacitors
You can get the full service manual at the following link that will show you how the chassis is removed and then its just reverse the proceedure. Heres the link.
Jun 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
electrolitic capacitors can be used in dc and ac circuits as long as you know how to use them. basicly a cap is a fast charging and discharging battery. it is designed to hold charges steady in a cicuit. they have a positive side and a negitive side. donot reverse the polls or you will have an exploding cap. the cicuit that these caps are in is a dc cicuit (24 volts to the panel).
the caps again are 2200uF 35 volt with a temprature rating of 105 degrees C.
you can get them at part number 31-5745. remember DONOT REVERSE THE POLLS!! there is a strip down the side with negitve signs in it that corespond to the negitive lead. the board will have the polls printed on it or at lest om of them.
Apr 01, 2008 | Philips Magnavox 27MS343S 27" TV
Car Audio & Video Logo
67 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
