Question about Toshiba Tecra M2V-S310 Notebook
PHYSICAL IP ADDRESS NOT RECOGNIZED, IT JUST SAYS FF-FF-FF-FF, AND DOESN´T RECOGNIZED THE IP ADDFRESS FOR THE INTERNET CONNECTION?? PLEASE HELP, DO I HAVE TO FORMAT MY COMPUTER OR I JUST NEED A DRIVER?
SEEMS LIKE A DRIVER IN MY LAPTOP, THE IP PHYSYCAL ADDRESS IS NOT RECOGNIZED IT JUST SAYS FF-FF-FF-FF-FF, AND IT DOESN´T RECOGNIZE THE ADDRESS FOR THE INTERNET CONNECTION. HOW CAN I FIX THAT, DO I HAVE TO DOWNLOAD AN SPECIFIC DRIVER OR DO I HAVE TO FORMAT THE COMPUTER?? I´LL APPRECIATE YOUR HELP..
  • Richard Camp
    Richard Camp May 11, 2010
    The computers IP address is like a phone number. 192.168.1.1
    The computers MAC address is the address of the network card inside the computer. 00:0f:a6:d5:ff
    It sound like you have lost the cards MAC address in the configuration. We would need to know the OS you are using, the connection type for the internet you are using, what is the connection type from the laotop. Thanks, RAC
  • 385 Answers
Update the O/S first
Check the connection is DHCP
control panel,network connections, right click your connection to the internet, properties,
TCP/IP VER4, highlight this in grey, click properties,
should be set to
( obtain I.P. automatically ) tick this box.save it.
Reboot the system.
hope this helps
Regards
Posted on Apr 19, 2009
D link router connection Hi I have recently bought a D link Dir 615 router and cannot connect to internet on my vista laptop. I have set up wireless on another laptop, PS3 and blackberry phone and they...
Everything looks normal:
Description . . . . . . . . . . . : Atheros AR5007EG Wireless Network Adapter
Physical Address. . . . . . . . . : 00-1D-D9-44-F8-15
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::1c05:824a:4808:dd81%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.102(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 21 February 2011 13:48:48
At the command-line prompt, try: ping www.ucla.edu
If it responds, then you *DO* have a good Internet connection.
Feb 21, 2011 | D-Link Computers & Internet
What are the static ip for leased lines
You have not provided enough information to answer this definatively. However, one possible answer exists, if this relates to leased lines from a service provider or telephone company. Leased lines involve a physical connection and a network layer logical connection. At the physical layer, there are no assigned IP addresses, just devices that transform analog to digital signals (and vice versa).. The installation person should have checked signal conductivity as part of the service. The next layer up (TCP/IP), has IP addresses, either given to you on some paperwork, or via dynamic IP Address assignment request. If the service promises a static IP address, then your paperwork (for example, setup instructions) contains any access authentication (required); a group of 4 or 6 numbers, separated by periods; and at least a 2nd set of 4/6 numbers designated as your default route IP. Otherwise, you may have to turn on DHCP and let your external router port retrieve your assigned (static) IP address from the network device at the other end of your network connection. The returned IP address is your assigned static IP address. Just make sure it is not 10.x.x.x, or 127.0.x.x, or 192.168.x.x. Those address ranges are not routable in the larger Internet space.
Feb 08, 2011 | Dell Computers & Internet
Cannot connect to the internet on the Toshiba Netbook. Has very strong network signal.
Troubleshoot the issue by identifying the ip address that your computer has. May it be wireless or local area connection. Check IP Address thru command prompt or DOS.
· press <windows key>+<R>
· type "cmd"
· press ok button. a black box will appear
· type "ipconfig /all" then press enter key
· locate wireless connection and local area connection group by scrolling up/down.
NOTE: ignore highlighted physical address.
If the ip address is 169.xxx.xxx.xxx, this is an invalid ip address. Contact Internet Service Provider. If the ip address is 192.xxx.xxx.xxx, click start and open control panel. then open internet options. click on connections tab. click on lan settings. Make sure no tick box checked. All set your anti virus' firewall settings to default. Then try browsing.
I hope this works for you. KINDLY REPLY IF FURTHER ASSISTANCE NEEDED. Good Luck!
Mongkey
"Understanding explains better..."
Jan 27, 2011 | Computers & Internet
Router connection
1. Please check your computer have a static IP address.
2. Please put your computer's IP address shout be automatic.
Mar 13, 2010 | Linksys WRT160N Wireless Router
NIC Connection question, Manual in XP, Automatic in Linux
Its depend on your LAN Card Configuration, something it obtain or directly detect your internet connection but sometimes its not. That is why to make sure that you can connect you manually put IP Address on it. Uncheck the limited or no connectivity on the Lan Setting to make that when you are using Obtain IP Address then it shows and detect your Router or Hub with internet provider.
Jul 29, 2009 | HP PAVILION DV4000 AND V4000 SERIES...
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
Acer 3000 builtin Wireless adapter says disconnected
update the drivers and run the wizard again to set up fresh settings
are you networking this unit or direct of the modem
Feb 11, 2009 | Acer Aspire 3000 Notebook
Please Help! My IP is driving me crazy!
modem only transmits signal.
router talks to your provider and gets IP address from them, depending on your subscription, you may have a static or dynamic IP.
your computer gets internal (home network) IP from the router, you don't have to worry about that since it is the router's IP address that is seen on the internet (router splits / shares a single internet connection in home networks).
about wireless connection from computers/wi-fi gadgets to the router, must configure the router with the ff:
wireless network name (aka SSID)
security type (WPA/WEP) and password/passphrase/security key
channel (1-12)
the above info must be then set to the connecting computers/gadgets
about wired connection: a working ethernet cable (looks like a phone cord but fatter) and a working computer/gadget ethernet port.
Wii will work - check Wii's website for connectivity options / instructions.
Dec 18, 2008 | NetGear WGR614 Router
2wire 1800hg random no internet/random access, repair/wait fixes
It seems that you said your computer gets the ip address from your router,, which means thru DHCP of the router but if you look at the DHCP settings of your wireless card inside your computer ---the DHCP is OFF -- check your ipconfig/all command as shown in your problem too,,, your wless card does not accept the new IP which comes from your router --as DHCP is OFF on your wless card and sticks with the old ip address whereas the router maintains a new ip for your computer in its table and a mismatch occurs and you loose the internet connection ,,,,thats why repair works and then again the IP changes in the router for your computer and your computer's wless card lags behind and use the old ip adress ..... DHCP--- IS DYNAMIC , WHICH MEANS IT RENEWS THE IP address after some time and you computer gets stuck to the old one ,,, hence mismatch. "you make the DHCP -ON on your wless card too. it will be fine."
Mar 06, 2008 | 2wire 1800HG Router (RG1800HG00)
Toshiba Tecra M2V-S310 Notebook Logo
167 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
