Question about Ryobi Garden
Ryobi model RCT2800B grass strimmer will not start
I would be most grateful if you could help me with this problem please. My Ryobi line strimmer is about 6 years old and has always been difficult to start. Now it will not start - the engine cylinder floods with fuel with only a couple of pulls of the starting rope: even with the choke OFF. When I remove the spark plug it is full of fuel.
Many many thanks
Bob Dalton
Alton, Hampshire, England
  • 37 Answers
Close your carb adjustment screw a bunch of turns... yours may even be missing.
Posted on Apr 19, 2009
Ryobi Li-ion strimmer
check that you are using the correct line in the head
if it is too thick , the load will be causing the thermo switch for the motor to stop operation until it cools down
Jun 16, 2017 | Ryobi Drills
When I try to strim the line on my ryobi 1830h13 keeps wrapping itself on the interior shaft of the strimmer, .and it's very difficult to get out
Your blade on the shield is either gone or dull and not cutting the string off to the right length as it turns.
Aug 12, 2016 | Ryobi Garden
Ryobi line strimmer hedge cutter attachment won't cut even though the blades are moving can you give any idea what he problem might be?
grass,string or vines can get wound around the motors shaft, you will need to take off the spinning head to remove debris from motors shaft
Jul 25, 2014 | Ryobi Garden
Purchased a gardentec petrol strimmer a while back from netto store...where can i get a spool replacment to fit my strimmer.
try Lowes or any Agway, and if that dowsn't work, try checking on line with your type of trimmer.
Apr 22, 2012 | Garden
How to replace my grass strimmer line
take the trimmer head apart feed line though the holes rewind the line around the feed slot and reassble the head go trim the grass !!
Mar 25, 2012 | Garden
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
How can i strimmer wire on a ryobi plt 3043ye
Hi alice louise
Try this method
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 02, 2011 | Ryobi 15" Electric Factory Reconditioned...
My ryobi cs30 gas trimmer (3 years old) has been difficult to start this year, has been getting worse all year and now wont start. What's up?
Most likely it is the spark plug, but could be a dirty fuel system. I'd start with the spark plug then go from there. you can also use a good quality fuel injector cleaner in your gas to help keep all your small engine carbs clean. If the problem persists there is a fuel filter inside the gas tank that plugs onto the end of the fuel pick up line that could be clogged. Worst case a carb kit can be gotten for them for about $20 bucks. Hope this helps. Please vote yes, thank you.
Nov 01, 2010 | Ryobi Gas Hedge Trimmer
I have a makita backpack petrol strimmer fitted with a line head can i fit a brushcutter blade instead i donot have the full model No it is a 41cc engine it is an early model
Hi Doug,
There are adapters for just about every combination of trimmer, brush cutter blade, grass gator, etc. you can think of.
One of the most handy purchases has been a non specific arbor adapter set. Not only does it have 2or 3 each of the most common nuts in both left and right hand thread, it has inserts that keep every blade, flail and brushcutter I've tried dead center.
It even came with a diamond shaped one for a skillsaw blade that I tried with my Ryobi 4 cycle. That thing turns thorny blackberry vines to powder.
So the answer is yes.
Best regards
Aug 14, 2010 | Garden
Garden Logo
992 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
