Question about Frigidaire FEQ1442ES Electric Dryer
My Frigidaire FEQ1442ES1 dryer has started to beep 3 times during drying...It still works but it doesn't seem to dry as well as before...It is only a little over a year old...It just periodically beeps 3 times when drying...None of the other lights flash and it continues to run...What exactly is the problem? I have take off the lint vent and vacuumed all of the lint out of the dryer...I have checked the tube and it is clear...Any help would be appreciated!
  • 2 more comments
  • nymase Apr 23, 2009
    I just wanted to add that I noticed that all the lights now flash when the 3 beeps occur...The dryer continues to run but it periodically beeps 3 times with the lights flashing...Again, any help would be appreciated!
  • khalil_lakha Apr 24, 2009
    It beeps all lights flash and if the dryer is made to run it stops and start beeping- what seems to be the problem?
  • nymase Apr 27, 2009
    My dryer doesn't stop...It continues to run and just beeps 3 times with the lights flashing...It doesn't matter what cycle it is in, it just beeps 3 times and continues to run...I assume the 3 beeps are a warning code for some problem with the dryer...
  • ICYdev
    ICYdev Oct 20, 2017
    search
    Random / Continuous 3 Beeps from Dryer **FIXED**
    Problem Solver:
  • 6 Answers
Your answer is HERE!!! seriously!!!
Appliance Repair Forums
Posted on Oct 20, 2017
When I read to manual, it said it was the lint. I use a paint brush to brush the lint off and usually the beeping stops.
Posted on May 05, 2010
  • foxytrot May 05, 2010
    Also, mine was just beeping like yours. I had two quilts in it. I took one quilt out and the beeping has stopped. Also, I only use the timed dry (~45 min per load). Hope this helps.
2009 Kenmore Dryer. Wondering why it seems to only work on 1 drying cycle? Everytime I try to put it on another cycle all the lights flash and beep...and nothing...
sounds like the washer might not be spinning the water out of the clothes good enough . 1 60 minute cycle should dry them more than dry enough .
Oct 18, 2015 | Kenmore 8804 5.8 cu. ft. Electric Dryer
My frigidare laundry center, FFLE2022MW will not fill with water at all.
I have a Frigidaire Landry center model # FEX831FS4 I washed a small but heavey rug in it and it quit during the spin cycle and now wont do nothing but the dryer still works...can you help me out?
Aug 21, 2014 | Frigidaire FFLE2022MW Electric Laundry...
How to get the error code test on Frigidaire affinity model FARE1011MW
Good Afternoon Friend,
I understand you are receiving an error code on your Frigidaire dryer, model# FARE1011MW. I see that when you press the start button, your dryer beeps and the drying light begins flashing. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Dryers
My frigidair affinity dryer wont start it just beeps
I understand that your Frigidaire Affinity dryer, model# FASE7073NW, will not start and just beeps. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best regards-
WP
Jun 01, 2014 | Frigidaire Affinity FASE7073NW 27"...
Why does my frigidaire dryer beep while drying?
How often does it beep and does it flash any error codes at all?
Aug 14, 2012 | Frigidaire GLEQ2152ES Electric Dryer
E 01 display and beeping
Hi
Check for the following if you get "E01" error message 1. Check for the vent hose whether it is clean which is less than two feet (to outside). 2. Check for the temperature sensor probes one in back at heating element and one in front by the lint filter for the temperatur rises resistance increases on both of them and visa versa. 3. Check whether the unit has been grounded. 4. Check for the element that turns off and on during drying process. 5. When first starting and dryer is cool it will dry one load of clothes, it also seems to work for at least the first part of the cycle, until clothes began to get dry then it over heats. display shows E01 and will not run until it has set for about an hour.
Thank you!
May 09, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer not drying
MAYBE CHECK UR GAS VALVE
Aug 18, 2009 | Frigidaire FGQ1442ES Gas Dryer
Frigidaire FEQ1442ES Electric Dryer Logo
2,392 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
