Question about Hotpoint Aquarius WF210 Front Load Washer
My door is stuck in the closed position and will not open. I can here some clicking like it is trying to unlock, what should I do?
Ironically I just had this happen. Pull the bottom panel off, remove the bottom two screws on the face plate and pull the latch release down (little white plastic Piece under the latch). This bypasses the electronic latch. To drain the washer, remove the plastic cover from the trap and the water will drain. Caution, this is very messy. Make sure you have a bucket and towels!
Posted on Apr 20, 2009
Driver rear door stuck closed on 2002 Santa Fe Hyundai. Any ideas on how to fix it?
It's usually the lock that is stuck in lock position.Roll down the window,grab a rubber hammer and as you reach inside and unlock the door,HIT THE DOOR at the locking area with the rubber hammer.Now try to open the door.It may take a few tries but works to open doors 90% of the time.DO NOT lock this door until you have lubed the internal locking mechanical parts and are sure they work.
Jun 22, 2017 | Cars & Trucks
How can I open a Chevy door latch which is closed while the door is open
that would happen to me and my sisters almost regularly when I was younger. Simply pull the greasy latch open with your finger while operating the door latch that would normally open the door. If its too tough for a finger, which it should not be and never was for me then you could use a screwdriver to pry it, but obviously nothing will happen if you do not pull the door latch at the same time.
May 22, 2014 | 2005 Chevrolet Astro
Rear latch lock stuck in the open position
use a round bar ( a screw driver ) and place it under the latch and pull the latch out as you press the button to unlock as if you were opening the door.
Jan 06, 2014 | 2008 Chevrolet Uplander
Drivers side sliding door won't close
check mechanism on working doors. In my car if I move the catch on the door(click it like in closed position)like it was closed,then when I open the handle it releases open;this shows me closing/opening. Spray penetrating fluid on the metal/mechanism,possibly rusty and prevents smooth actions. Hope this helps.
Jan 01, 2014 | 2004 Nissan Quest
My drivers side rear door will not open from the inside or outside
I had exact problem Santa Fe 2007 2008 lock was stuck in locked position and door would not open from inside or out. All other doors would unlock with auto key remote. Carefully work the inside lock towards the open position as you lock and unlock the door with the remote. As you press unlock try to assist the lock to open. I did this a few times and the lock became free to the open position and all worked perfectly after this.
Feb 02, 2013 | 2007 Hyundai Santa Fe Limited
1990 Honda Accord CB. When I shut the door I locked it at the same time. The door is now stuck locked but the popper is in the unlocked position. So it thinks it is unlocked when it actually isn't. Then...
You'll have to use a screwdriver. Stick it inside the locked latch on the door itself, the hole that holds it closed against the car body, then pry on it while at the same time pulling the door handle up to open it. The lock piece should swing open and your door should close and open normally again.
Jan 16, 2011 | Honda Accord Cars & Trucks
Cant get back door to stay closed . The lock is stuck in locked position I think and the door is open. When I go to close it, it is'nt staying closed. Had to duck tape it to stay closed. LOL! I keep...
It sounds to me ( correct me if I'm wrong ) like the door latch on the side vertical edge of the door is in the LOCKED POSITION. In order to unlock it perform the following. First electrically with the LOCK button UNLOCK the locks. Now with one hand hold the OUTSIDE DOOR HANDLE IN THE OPEN POSITION, while at the same time FLIPPING OPEN THE LATCH. All Done . Now you can close the door. Hope this helps
Jun 27, 2009 | 1997 Chevrolet Lumina
My door on my n01 grand am gt 2 door will not close. the thing in the door is like stuck locked? what can i do
Manually push the lock button into the UNLOCK position. Now HOLD the OUTSIDE DOOR HANDLE in the OPEN position while at the same time, moving the DOOR LATCH into the open position. Hope this helps
Jun 15, 2009 | 2001 Pontiac Grand Am SE
Doors won't close
Manually UNLOCK the door button or slide. HOLDING the OUTSIDE DOOR HANDLE in the OPEN position, with your other hands finger, LIFT OPEN the latch, and close your door. Hope this helps.
May 24, 2009 | 1994 GMC Sierra
Hotpoint Aquarius WF210 Front Load Washer Logo
101 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
