SOURCE: English Subtitles
I don't think it can be done. Might make a good suggestion for the manufacturers to add to their future sets though.
SOURCE: dead remote = no dvd access?
Try a RCA universal remote with an input button. Try the codes for Orion , Sansui and RCA. Access the menu by holding down both volume buttons on the front of the set. There is no access to the jacks on the front of the set without a remote. If all else fails get a RF Modulator. This will allow you to watch your dvd by using the antenna jack on the back of the set.
SOURCE: Hi, Having problems with my grandads Technika LCD
by subtiles, you mean close caption. on your remote you should have a CC button. That is all you have hit
SOURCE: how do i turn off the subtitles on my toshiba
The subtitles in dubbed videos VCD/DVD the process to follow are :-
The closed caption feature has two options:
• Captions—An on-screen display of the dialogue, narration, and
sound effects of TV programs and videos that are closed
captioned (usually marked as “CC” in TV listings).
• Text—An on-screen display of information not related to the
current program, such as weather or stock data (when provided
by individual stations).
To view captions or text:
1. Tune the TV to the desired program.
2. Press MENU, and then press x or • until the CUSTOM menu
appears.
3. Press z or y to highlight CC.
4. Press x or • to highlight the desired closed caption mode, as
follows:
• To view captions, highlight C1, C2, C3, or C4 (C1 displays
translation of the primary language in your area).
Note: If the program or video you selected is not closed captioned,
no captions will display on the screen.
• To view text, highlight T1, T2, T3, or T4.
Note: If text is not available in your area, a black rectangle may appear on your screen. If this happens, turn the Closed Caption feature OFF.
To turn off the Closed Caption feature:
Highlight OFF in step 4.
Note:
A closed caption signal may not display in the
following situations:
• when a videotape has been dubbed
• when the signal reception is weak
• when the signal reception is nonstandard
PS: If you do not want to set these function & their commands can be entered via the buttons on the TV set. Using the remote is much easier to operate............ sodeep
