Question about Canon PowerShot SD100 / IXUS II Digital Camera
Focus problems Hi, my camera is not focusing clearly. We just used it recently and can look at clear pictures on the display screen but now when we go to actually take a picture it's blury (on the display screen and if a picture is taken). I also notice that all these different setting menu's come up on the display screen when we are in take picture mode. I took it in today and they said the lens could have been bumped or that their is something wrong with the focusing inside. So they would have to open it up to take a look. Problem is I'm 9 months pregnant and can't wait the 2-3 weeks turn around. I'm wondering if we should just bite the bullet and buy a new camera. Any advise?
  • Canon Master
  • 4,738 Answers
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110
Posted on Nov 19, 2007
SOURCE:
Fuji finepix s3100has no power even with new batteries
I have this problem also with Fuji Z90 model.
Problem is fixed and focus now working ok.
Camera is fall down and after when camera was started giving sound click click from focus big motor and error on screen Focus error
Focus ( lens ) was open ( small cover on top bellow sticker ) Small "snail" gear is taked out . Two sliding segment adjusted for focus ( upper full up and lower full down - beware about spring inside below this focus pins )and snail is inserted back. Camera started and focus start working. I need to make small adjustment . Reason when camera is started picture is not clear and before using camera i need to do full zoom in and back zoom out. After this picture is crystal clear and all working ok.
Dec 17, 2012 | Fuji FinePix S304 Digital Camera
The problem is its having difficulty in focusing on objects.If your going to take a picture its so blurred and hazy but if you are gonna see the stored pictures its so clear.
Blurry picture could be caused by insufficient lighting or constant camera vibration. Try increasing the ISO to max and fixing the camera so it doesn't move. If the picture itself is focused, than maybe you have a problem with the cameras' screen. If the picture is still not focused (nor camera screen or stored one) than maybe you have to clean the lens. Use a dry smooth cloth. If that doesn't work, than maybe you have a sensor problem. For that you'll have to contact the company for warranty.
Dec 27, 2010 | Cameras
My Canon SX210 IS is brand new. Just bought it on yesterday. The problem I'm having is that the LCD screen does not look sharp and clear when focusing on a subject. It looks grainy. Can you tell me if...
Some cameras display a grainy picture in low light. Do you have the camera set to the highest number of megapixels and fine image or do you have it set to a lower resolution to get more pictures on the card?
Dec 03, 2010 | Canon PowerShot SX210 IS Digital Camera
With camera on the AUTO setting, I can't seem to take clear, focused photos. Nearly all of them are out of focus or blurry. Does not matter if it is in the day time or at night. Also, when using the...
Try resetting your camera back to factory defaults. Press the MENU button, select the middle tools tab and scroll down to RESET ALL. Press SET, select OK and press SET. Hope this helps.
Nov 09, 2010 | Canon PowerShot S5 IS Digital Camera
My connon xti 10.1 mp takes many out of focus pictures even though its on auto focus how can i solve this problem
I think its reqiure to do the focusing adjustent or you can try to clear all camera setting from menu option four. clear both settings and try to take picture and check out of focus problem.
Dec 29, 2009 | Canon Digital Rebel XTi 10.1MP Digital SLR...
Viewfinder of Sony DSC-H2 does not work anymore
Viewfinder has focus lever at bottom, please adjust viewfinder internal focus as per your eye sight looking on-screen display. Every thing will be fine after that.
Feb 04, 2009 | Sony Cyber-shot DSC-H2 Digital Camera
The focus on the NIKON COOLPIX P80
some cameras have a choice in menu as to monitor or continous autofocus-monitor or continous means camera always seeks a focus which hurts bat life but makes focus quicker-single means camera won't focus untill button pressed halfway-make sure you are not in macro mode-flower icon on screen-this will screw up focus except for close up work-good luck-check menu settings for your type of focus
May 12, 2008 | Cameras
Viewfinder focus
Mickykay,
Have you tried focusing the diopter? The focus wheel is just left of the viewer. If you know all this then consider one more thing. There is a plus and minus setting for your eye so roll the wheel slowly to not miss the sweet spot for your vision. goodeye
Jan 13, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Blurred Picture in the shooting mode
one of the possible cause of the said problem can be a defective or broken flex ribbion cable carrying signal to the focus motor. the replacement of the flex will solve the problem. othe may be friction in the focus assembly. cleaning of the same will do the job. but in both the cases you will need the help of repair shop.
Sep 13, 2006 | Canon PowerShot A75 Digital Camera
Focus Problem
I have the C740, which I believe works very similarly if not identically. Unless you have the camera in full time auto focus, I don't believe it actually focuses on the subject until you've pressed the shutter button half way. Until then, the subject may look in focus in the viewfinder, but is not. When you fully depress the shutter in one motion (rather than pressing half way first), the camera will attempt to focus before it takes the shot. If you are not careful about camera movement, you may inadvertently be focusing on something other than what you intended. My camera (and it seems all digicams) has trouble focusing in low light, so you definitely want to use the half press in such situations. Even then, I don't always get the focus correct. Thank the digital Gods for instant feedback! Personally, I almost always use the half press method. To get the 740 in manual focus, you hold the "OK" button down until you see the viewfinder display a focusing scale. It takes a second or so. You should also see "MF" and "AF" designations in the lower left corner of the viewfinder when the scale displays. Use the left and right arrows to select the focus mode you want (i.e. MF or AF), then use the up and down arrows to adjust the focus distance. You'll notice that the area you are focusing on is enlarged when you use the up and down arrows.
Sep 13, 2005 | Olympus Camedia C-750 Ultra Zoom Digital...
Canon PowerShot SD100 / IXUS II Digital Camera Logo
67 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
