Question about Lands Phones
No charger recognition
My phone has been working perfectly until recently when i plugged it in and the charger fell out. when i replugged it in the phone didnt say ''charging'' or even power on. now it wont work and is loose in the charger port, how do i solve this?
  • Jamacorman Apr 19, 2009
    ive tried all sorts of different chargers and none will work. and the few that worked didnt even properly charge the phone.
  • 88 Answers
Hopefully you have damaged the charger and not the phone. Go to Best Buy or Radio Shack and attempt to plug in another charger, if that works, just purchase the charger. If not, you have damaged the phone itself and can only be fixed by an authorized repair center!
Posted on Apr 19, 2009
  • Bati99
    Bati99 Apr 19, 2009
    Then it is definately the phone itself. Only solution is an authorized repair center.
My phone was working place it on charger went back and the phone is dead will not come on
The same thing happened to me. It's probably your charger porter. did you somewhat yank the charger out sometime or did it fall of a table or something and the charger yanked itself out when it fell (if it fell). If that's the problem, try putting the charger in the phone & hold the charger up, worked for me. You could also try a different charger or buy a battery charger like I did. There's the link if of the battery charger if needed. I hope this helps!
http://onepluswireless.com/products/universal-external-cell-phone-battery-charger-charges-most-brand-phone-batteries
Dec 03, 2015 | Blu Studio 5.0 Mobile Phone
When I connect charger with my laptop 30 sec show battery is charging after 30 sec one message show:- QuickSet The Ac power adapter type cannot be determined. your system will operate slower...
del recognition circuit may have failed in charger , or could be fine central pin on charger plug or laptop plug has broken connection,it is used to tell laptop that this is genuine dell charger.If you remove battery will laptop work off charger.if does then definitely one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed. If either of last 2 can repair but need to pull apart repair broken connection ,or open up laptop and check power connection and repair connection . If you remove battery will laptop work off charger.if does the definately one of the three problem possible . for first only soln try another dell charger first,often has to be one to suit your model ,common dell problem ,if then work and charge battery ,you will need to replace charger as recognition circuit failed.
Oct 27, 2013 | Dell Inspiron 65W PA-12 1525 LAPTOP
I have a 12v automatic battery charger that works normally and it cuts off when the battery is full but when the battery is empty again it doesn't start until i unplug and replug the charger...what's the...
well most likely is the way the system is programmed. You have to probaly unplug and replug to reset it. If not it would stay charged constantly and would make no sense to have the auto shutoff
Sep 09, 2013 | Computers & Internet
Dell Inspiron 6000 won't charge
Since you have already replaced the battery and the laptop works with the AC charger, then probably the charge circuit in the system board (mother board) is bad. I have rarely seen an AC charger that will power the laptop but not charge the battery. 99% of the time, if it is not the battery, it is the system board.
May 05, 2010 | Dell Inspiron 6000 Notebook
S9 HD GREENLIGHT
The Headphones suffered a short, likely when you were plugging them in or off the charger. The easiest fix is to connect the headphones to your charger cable and then flicker the power...
so if you plug them into a usb charger cable to your pc, then quickly disconnect and reconnect the cable from your pc's usb port... this might not work due to the slowness of recognising the drivers.
if you have a wall charger for this unit, connect it up and then unplug it and replug it @ the wall multiple times. Or use a switched outlet/power strip to cycle the power to the charger quickly...
Worked perfectly for me!
Sep 20, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Samsung charger
Have you tried taking the charger and phone back to the vendor to see if they will replace either the phone or the charger (whichever is defective)? If you have had the phone outside of the 30 day period, you might buy a replacement from the cellphoneshop.com. They are inexpensive and prompt.
Jul 27, 2009 | LG KU990 Viewty
MY PHONE WON'T CHARGE!
Justt Get A New Battery From The Dealer. & It should work.
Jun 19, 2009 | Samsung BlackJack II Smartphone
Battery will not charge
Through this in to gabbage
May 28, 2008 | Pantech Duo Smartphone
W300i fell into the washing machine
hi i juz bougth my new sonyericsson j220i and i want to decode it but it is not respondin to the software on the internet when i connect to the net with the cable
Jan 02, 2008 | Sony Ericsson W300 Cellular Phone
Lands Phones Logo
170 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
