Question about Onkyo TX-DS494 Receiver
No audio my Onkyo dv-s353 DVD player played great with my tx-ds494 Reciever for over 6 years. Recently all I get is video with s-video cord and no sound with av cables? I've conected the dvd player (dv-s353) strait to the tv and got sound and video.I've conected another dvd player to the reciever(tx-ds494) and also got the same results of no sound on the tv. Everything else on the reciever works fine. It appears that the issue is in the reviever. Do you know what to do to fix it or what to look for? (thanks)
  • estephens10 Dec 19, 2008
    No sound is coming out of the speakers and the click I normally hear when the receiver turns on isn't making the normal sound.
    Genius:
  • 1,153 Answers
Most of the time its the amps that are bad and need changing. This will be transistors on heatsink in the reciever. Part number should be on the amp.
Posted on Sep 19, 2007
  • Robert Riemann May 01, 2014
    My ONKYO receiver stops working every once in awhile. The secret is to hold down the power button and the video button at the same time. I think it is video button but it could be the DVD button. Try them both. Somehow this resets something and turns on the sould. You can do it with less effort if you still have your remote. I lost mine some time ago.s
Is there a way to reset onkyo tx-ds494 receiver
HI Preshay, to reset the tx-ds494 first press and hold Video 1 then also press and hold Speaker A, the display will show Clear then the unit will shutdown. Please note that everything will revert back to factory defaults so it will be like taking the unit out of the box for the first time. If you need further assistance please contact our Product Support Team at 800-229-1687, Thanks, JT
Apr 16, 2015 | Onkyo Audio Players & Recorders
Would like to connect onkyo TX-DS494 to my television to play the television sound thru the receiver
To get the sound into the Receiver you don't need to go from the TV. On the back of the cable box there are a pair of audio outputs. Connect those to the inputs on the Onkyo. When that is done you need to select the input on the Onkyo to match the input that you have wired it to. You will then have audio come through your system.
Jan 08, 2015 | Onkyo Audio Players & Recorders
I have a TX SR 606. I have the unit connected with a HDMI cable to my TV. At times it will take several minutes to get a signal to the TV when I turn on HD format. I am also using HDMI from the DVD player...
This is one of many reasons I recommend against routing ANY video through a receiver if the TV/ monitor has enough connections for all of the video sources.
Bypass the receiver andsee what happens, then isolate a cause.
Dec 28, 2010 | Onkyo TX-SR606 Receiver
Remote doesn't operate reciever
Hello Fixya customer,
Thank you for your question.
Please determine if the "Audio" button is actually working.... after pressing the audio button, can you still control the DVD, if not then the remote has switched to the Onkyo. Although, this is not 100% conclusive, unless you have a 2nd remote to test the Onkyo with, it provides a sound basis to proceed.
Assuming the remote is transmitting and the IR receiver on the front of the Onkyo is not otherwise blocked, likely faults include the IR receiver, input to the Micro processor, and the Micro processor.
The most probable fault is the IR receiver.
Thank you for using Fixya, and if I can help you further, please let me know.
Apr 29, 2010 | Onkyo TX-DS575 Receiver
No audio from pc connected using hdmi
Are you not getting audio to the television speakers and the onkyo reciever speakers when connected HDMI thru the reciever or just the television. If it is just thru the television then it is because the reciever is grabbing the HDMI audio signal and converting it so it does not reach the TV. If it is both then try changing the HDMI signal output from PCM to DOLBY DIGITAL on the computer. Your reciever may not be able to process the PCM signal of the computer. Does the reciever show a PCM or DOBLY DIGITAL display when HDMI is hooked up to it?
Oct 03, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Jun 01, 2008 | Onkyo TX-SR702 Receiver
Onkyo HT-R501 7.1 reciever issues
i have the same problem with a onkyo tx ds494
Jan 05, 2008 | Onkyo TX-SR605 Receiver
Video on game and dvd seem to work
DO you have hdmi monitor turned on?
Onkyo TX-DS494 Receiver Logo
293 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
