Question about Garden
Looking for wiring diagram for toro el-6+ sprinkler timer controller
SOURCE: adjusting toro Super 600 PC-2.5 sprinkler heads
Try this. Should work.
www.mickman.com/irrigation/tips/toro600.html
Posted on Jun 25, 2009
protek480
  • 1723 Answers
SOURCE: Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
Posted on Jul 02, 2009
  • 243 Answers
SOURCE: Bought a Intermatic sprinkler timer. need help.
reading the specs i should say its a timer for only one zone. you can use it for one zone switching or for the pump. sorry.
Posted on Feb 14, 2010
SOURCE: I have a Orbit 57161
Manual:
http://www.orbitonline.com/lib/media/57114-14%20rF_Eng.pdf
Website:
http://www.orbitonline.com/products/Timers/02/01/19/671/
Tech service 1-800-488-6156
Timer has 4 year warranty
The manual has troubleshooting
Looking through the manual I can see potential trouble areas:
-Water pressure too high > 60 psi is ordinary household pressure > order Brady BTG pressure gauge that connects to hose
-Overlapping times are 'stacked' by timer ... but 'more than one start time' is listed as cause of stations turning on when not supposed to >> reset and re-program timer, make chart of on-off times
-Weak or missing AA batteries >> clean terminal inside timer and replace batteries
-Hard water deposits or unfiltered water clogging water valve (water softeners frequently have this problem) >>> see if vinegar or CLR cleaner can help flush water valve >>> add sediment filter in front of timer
-Fuse blown
-Bad solenoid
-A combination of problems listed above with sediment -or- solenoid as main suspects
Posted on Oct 06, 2010
taran_2005
  • 10515 Answers
SOURCE: need a manual for a
You could download the manual from :-
http://www.ais-ne.com/sprinklermanuals/gk212.pdf
You need to have acrobat reader to view the same.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Apr 22, 2011
I have an older Toro residential irrigation timer. I don't know the model number. How do I find the model number?
Call Toro Tech. help and describe the timer to them and they should be able to guess the model. Sorry, don't have Toro's number because I will not use anything made by Toro. If it was me I would replace the timer. .
Mar 28, 2014 | Toro-Irrigation 53794 Ecxtra 6 Zone Timer
Wiring new sprinkler timer one wire on my old
Just cut the common wire and put one end in each of the 2 pins. The rain sensor just interrupts the signal to the valves when wet.
Nov 04, 2013 | Orbit Underground 57896 6 Station In/Out...
Is there a video on programming a toro lawn master II timer
I have found these timers to be the most difficult for a homeowner to master. I suggest going to Toro's web site and downloading the operating instructions.
Sep 30, 2013 | Toro 53805 Lawn Master II 4-Zone Landscape...
Toro Visiion Sprinkler Controller Troubleshooting
There are two Toro timer manuals posted:
Copy following links, for ez word search for each manual:
http://waterheatertimer.org/pdf/Toro-53794_UserGuide.pdf
http://waterheatertimer.org/Toro-53794_UserGuide.pdf
http://www.toro.com/en-us/homeowner/do-it-yourself-irrigation/timers/Pages/default.aspx
The timer can be reset to factory defaults by 'clearing program memory' following steps in manual.
Warranty period is 1 year protection against defects in workmanship, which is standard for timers from Woods to Intermatic to GE etc.
If the display is not working, and zone does not show, then that implies internal defect, or lack of power. Resetting timer might repair problem.
The timer has electro-magnetic relays, and not an internal solenoid.
The timer turns ON or turns OFF electric power to the water valves.
Water valves have solenoids that open and close when power from timer arrives at each zone.
The solenoid can make the sound you describe, but the timer relays with make small click sound as the electromagnetic relay opens and closes.
In addition to resetting timer to factory defaults, and then reprogramming you might try changing wires to different terminals.
Also the timer works on 24Volt AC transformer that plugs into outlet. It is possible to get display errors on timers when voltage is incorrect, or outlet and transformer are not connected well. Test outlet with circuit analyzer. Change outlet because outdoor outlets get corroded. Clean blades on transformer plug.
Power surge and other events can damage timers. Nearby lightning strike. Power outage causes surge when power resumes.
There is 24-hour backup battery, but the battery does not appear to be replaceable type and instead is rechargeable or capacitor type backup. So the battery is probably not the problem
Jun 17, 2012 | Hardware & Accessories
How do you wire a Toro Rain Sensor 53769 to Intermatic Timer T8845PV
The rain sensor only connects to Intermatic sprinkler timer IF the timer has the rain sensor terminals.
Not all Intermatic sprinkler timers have that connection.
For example R8815P101C and R8816P101C have rain sensor terminals
I think the rain sensor terminals are located to the right of main wiring terminal block.
There are two screw terminals.
The rain sensor plugs into a power source, and then sensor wires connect to the timer.
Apply no voltage to the sprinkler timer terminals.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
May 01, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Looking for wiring sequency
1) Intermatic has manuals for each product. Manuals have wiring diagram, but you have to identify product number. Look for product number and wiring diagram inside timer door.
2) If you know product number, and are still confused by wiring, then repost question providing as much information as possible. You also need to post what voltage wire you are putting timer on.
3) Here is link to manual page:
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
4) Here is link to product page: for example sprinkler timer: Click on product number to access manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/sprinkler%20irrigation%20timers.aspx
Sep 18, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Garden Logo
969 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
