Cannot find the second memory board
I have a packard bell i power 5305 laptop and need to upgrade the memory, I have removed the bottom cover next to the battery and can only find 1 memory board. Where is the second one as all the websites state there are 2 and I need to increase the RAM to 1 gig.
  • Steve Apr 20, 2009
    I have removed the one memory board but there is no sign of another hidden below, on the website for packard bell there is a comment that if you can see only one board you are looking in the wrong place! where else could they be?
  • Steve Apr 21, 2009
    It is a Packard bell i power 5305 which is a 5000 series 2 on the packard bell website,
    Sergeant:
    Novelist:
  • 192 Answers
Hi there. On laptops, the memory slots are normally on top of each other. Though the bottom one would stick out a bit more. When you look at your memory stick, you will see a bit of plastic on each side that holds the stick in place, just look for the other bits. You may need to take the current stick out to see properly.
Hope that helps.
Tim
Posted on Apr 19, 2009
  • Timothy Farley Apr 20, 2009
    Can you tell me the make and model of the laptop, and motherboard (if known)?
Packard bell easynote mit gha20 M5284 - memory upgrade
Hello Wallace.
http://www.crucial.com/store/mpartspecs.aspx?mtbpoid=9B9F5310A5CA7304
Try this, i think that`s it.
mfg Gue.
P.S.: Do you know Gooooogle ?
Feb 28, 2013 | Computers & Internet
Packard bell 6700 outer cover removal
I would suggest going to the Packard Bell Support web site then select your country followed by selecting your model of computer which will then give you access to any available documentation to help you with upgrading memory etc.
Jan 12, 2012 | Packard Bell iMedia 6826 (P481000502) PC...
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
How to install memory for Packard Bell Easynote s4
open the cover at the back, be sure no power adapter is connected and battery is remove.
Feb 18, 2011 | Packard Bell Computers & Internet
Packard bell easy note tj65 will not power up
the short cable running from the power button to the main board has probably snapped where it passes over the RH hinge. remove the screen surround to gain access to the power on switch area and check. it would seem to be a common fault with the packard bell
Mar 07, 2010 | Acer Computers & Internet
How do i replace the bios battery on an easynote mv35-202 mit-sable-c laptop?More specifically, where is it?
The battery is going to be inside the case in most cases. You might have to remove the covers on the back of the laptop, there should be one for your system memory and probably one for your hard drive. But in most cases you will need to remove all the screws on the bottom of the laptop and carefully remove the cover, you will see the battery plugged into the board. It should be a batter with red and black wires.
Nov 17, 2009 | Packard Bell iMedia SL 9553 (P660401806)...
Ram change on Packard Bell easyone 2120
Memory Upgrade Instructions
128 MB SDRAM on-board, max. 256 MB upgrade (384 MB total), PC-133
Remove the memory module according to these steps:
1. Turn off system power.
2. Remove the battery and disconnect the AC-adapter.
3. Open the top cover.
4. Press the locking latch downward to unlatch the Easy Start panel.
5. Then push it leftward and lift it up from the left side.
6. Slightly lift up the keyboard and disconnect the cable from the system board to free the keyboard.
7. Pull the retaining clips outwards (1) and remove the SO-DIMM module.
Keith Stoffer
Comptia A+ Certified Technician (20+ years)
Oct 30, 2008 | Packard Bell Easy One Silver 2120 Notebook
Memory upgrade for packrd bell Easy One Silver 2120 DVD
The best site to get the info on what memory you need is here at Crucial.com, run the tool and it will tell you what memory you have and the max and type you can fit
Sep 22, 2008 | Packard Bell Easy One Silver 2120 Notebook
Upgrading Memory on Packard Bell MIT GHA20
If you look along the top edge of the escape/function/del keys, there are several small plastic tabs that hold the keypad in place. Use a very small flat head screwdriver to push these back from one corner across to the other, gently lifting the keypad as you go. When you press back the last tab, the keypad should just pop out but take care as it's connected by a cable at the bottom edge of the keys. The RAM slots are located under a thin metal cover under the keypad. You'll need a very small philips head screwdriver to undo this. After installing RAM, replace the metal cover then pop the keypad back in, bottom edge first and just press down the top edge and the plastic tabs should snap back into place. Hope this helps!
Mar 08, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
