Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Hot water enters tub very slowly
The water hoses are not clogged I tested them.The cold water goes into the tub at the normal speed.
TAKE OFF THE HOSE AND THERE IS A LITTLE SCREEN, PULL THAT OUT AND CHECK IT. THE HOLES IN THE SCREEN ARE VERY SMALL, AND IF SEDIMENT GETS UP IN THERE, IT WILL EASILY CLOG, HOWEVER THE HOSE WORKS PROPERLY. THE SCREEN IS ON THE WASHER SIDE. MINE IS A WHITE PLASTIC SCREEN.
Posted on Apr 21, 2009
Water flows constantly during the spin cycle
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced.
Dec 08, 2011 | GE WBVH6240F Front Load Washer
Tip
How to service water valves
If the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
- Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
- Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
- Tap the solenoids with a screwdriver. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
on Jan 16, 2010 | Washing Machines
Hot water connected but does not fill into the drum? The machine will provide us with a cold wash but on the warm and hot settings the hot water dies not pull through the connection
Turn off the water valves which supply the water to washer hoses. Switch the hot and cold water supply hoses and tighten. Turn the water valves back on and try to run a wash cycle using cold. If hot water only is entering the wash tub the water supply is ok. If this is the case you can unplug the washer and turn off the water valves. Remove the washer back cover and follow the water connection for the hot water. The water solenoid valve will have two electrical wires connected to it. Interchange the hot water solenoid wires with the cold water solenoid connection. Connect the water supply hoses hot to hot and cold to cold then plug the unit then test the washer on the cold wash. If the problem persists it could be a water hose restriction or the timer circuit could be defective. If you have hot water at the normal pressure purchase a new hot water solenoid valve. With the electrical cord unplugged be sure to restore the correct wire connections on the hot and cold water solenoid. To replace the hot water solenoid remove the hose clamp and hose to replace the old valve. Connect the unit to the water and electrical outlet. Turn on the water and test the unit for leaks being careful not to touch any electrical and moving parts. If all checks ok and the correct temperature work, unplug the unit and reassemble.
Jun 21, 2010 | Admiral AW22 Top Load Washer
Cold water trickles in tub. Hot water fine.
remove the cold water hose from the machine that is your service line feeding into it.
a screen in the inlet were the hose attaches to is probably clogged up
May 28, 2010 | Washing Machines
THE TUB OF THE WASHER GETS REALLY LOW WHEN IS FILLED WITH WATER. NOW, ALSO THE WATER DOSENT COME IN WHEN I TURN IT ON
All top suspend tub washers drop down when they fill with water. And they rise again when they have pumped the water out. This is normal.
What is not normal is water not coming in.'
check following:
Water is turned on
Remove inlet hose and run water to see if it is blocked.
Clean the inlet filters.
If you hear a buzz but no water goes in the inlet valve needs replacing.
If yu use only cold water try swapping the cold hose onto the Hot inlet. Then select Warm Wash.
Then only turn on the Cold Tap.
This will allow you to fill the machine and do a wash.
Watch out though when it comes to the Rinse position......some machines only do a cold rinse, and because you have swapped the hose over to hot it will not fill to rinse the clothes. Until you can get a Tech to do the repair you can just use either a bucket to add cold water for the rinse or use the garden hose to fill the tub with cold water for the rinse.
Have yu got all that?
Oct 25, 2009 | Speed Queen AWS75NW Top Load Washer
Why is there only hot water going in the washing machine?
the cold water valve is stuck shut inside washer.
Servicing Water Inlet ValvesIf the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
Step 1: Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
Step 2: Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
Step 3: Tap the solenoids with a screwdriver handle. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
Oct 14, 2009 | Kenmore 24032\24036 Top Load Washer
The cold water will not run.
©2006 Publications International, Ltd.
If an inlet valve is faulty, check the water connection and the
valve screens. Try gently tapping the solenoids;
if this doesn't work, replace the inlet valve assembly.
Aug 24, 2009 | Maytag MHWE300VW Washer
Kenmore 80 series model #110.26882503 fills slowly
Yes, the only other thing I would do and you may have done this is to put the hose directly over in the washer tub and turn the water on to check the flow. If that's good then replace the water valve.
Dec 08, 2008 | Kenmore 24032\24036 Top Load Washer
GE WHRE5260E1CC NO HOT WATER
hi If the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
Sep 13, 2008 | GE WHRE5260E Top Load Washer
Washing machine wont fill
hmmm...wool requires cold water...I'm guessing that first the hot water and now the cold water solenoid valves have become clogged with sediment. test by turning off water. then loosen the hose connection to each inlet in back of washer. then slowly open water valves and let water pour into wash tub if hose will reach, otherwise pour into a bucket. if water comes out of hose, then look for metal screens at hose connections to washer and clean those. if still no water through solenoids (after re-connecting water hoses) then may need to disassemble solenoids and clean those too.
Oct 19, 2007 | Washing Machines
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
