Question about Acer NSK8458AN Keyboard
The W key
Please can you advise me of the best way to refit the W key as it has fell off. non of the fixing look broken.?
  • James Gallombardo Aug 24, 2013
    For the Logitech diNovo wireless bluetooth keyboard, key replacement is a challenge, but possible. Although Logitech will state it is a non-user serviceable keyboard in which keys cannot be replaced, it is possible. It does require patience and a delicate touch, both challenges for me, but I didn't want to spring for another keyboard since I like this one so much and everything works well. This keyboard uses a scissor spring which attaches to the keyboard via two open ended hooks. The springs attach to the key via male pegs on the spring and female clips on the back of the key. These clips are in each of the four corners. Step 1: Gently remove the spring from the key, taking care not to break any of the clips. You can use a small screwdriver or a stiff paper clip. Step 2: Insert the scissor spring onto the keyboard body with the pegs that go into the key up. Step 3: With the key perpendicular to the keyboard, insert ONE SIDE of the spring's pegs into the key's clips. Step 4: Carefully pivot the key towards the other side of the spring. GENTLY snap the other side into the clip's pegs by pushing down on the key.
  • 661 Answers
There is usually a scisor hinge or rubber column spring.if this is undamaged you should just be able to push the key back on, however there are usually tiny pegs which clip into the key which tend to break off, if these are broken you may be able to order a replacement from the manufacturer, you can order a replacement keyboard (complete) either from the manufacturer or from a spares company
Posted on Sep 19, 2007
  • 3 Answers
Yes, that plastic mechanism actually creates the problem. If your key is working properly then you can use this video tutorial to fix it back in place, but if the key itself is broken then you can also buy a replacement keys. Its really not a big deal. You can buy new replacement laptop keys at , for $4.99. Check it out. Helped me fix my "R" key last month.
Posted on Jun 29, 2010
Plastic hinge brokeand screws fell out need replacement
Hi Carol....what exactly is it that you need a hinge for? Please
advise product, make and model and we will do our best to
help you.
Oct 12, 2014 | Televison & Video
I removed harness to wash and have refitted shoulder straps but adjustment ******** Viaggio Primo SIP wont thread through and under buckle . can you advise please
To figure out how to do this with the Peg Preggo Viaggio Primo SIP, I think it's best to contact their customer service:
1-800-671-1701. Customer service hours are Monday - Friday 8am - 4:30pm Eastern time.
Feb 10, 2013 | Baby Gear
My screen has gone blank. It fell on the floor a few days ago, but only this morning it began to go "funny" and now it is completely blank (black). Any ideas how to fix it please?
bad sign... when the CP turns black, the CPU IC maybe damaged... an expert cellphone technician may fix it but it have a 50-50 chance or best to buy a new CP... sorry for your broken CP... but still hope that it can be fix or if you can afford a new one...
May 25, 2010 | Samsung SGH-G800 Cellular Phone
After 2 months of use my "V" key just fell off. No prying, no dropping and this laptop is immaculately clean. Just a broken "V" key. It will not snap back into place. How do I get this fixed?
usually if you push the key back then put a little pressure in it. it will snap back to the keyboard. if nothing happens. i advised you to contact your manufacturer and have your laptop repaired if it is still under warranty
Mar 27, 2010 | Acer Aspire 5500 5570-2609 Laptop
N73 camera switch problem
n 73 camera swich not working problem plz help me
Aug 24, 2009 | Nokia N73 Cellular Phone
Non working driver side power window 2003 Nissan Sentra
I had a similar problem, window fell down one day while driving. Screw was loose at bottom of window that connects to track. Was hard but fixed it and worked great after. Hope it helps u out.
Aug 08, 2009 | 2003 Nissan Sentra
One key fell off
You should be able to place it on the retainer and press it on, you may need to move it around a bit. If it just flat won't snap back on, check the retainer to make sure that the pins that fit into the clips on the back of the key aren't bent or broken, and check the clips on the key to see if the sides are bent or broken. If the pins or sides of the clips are bent, take a small flathead screwdriver and straighten them. If they're broken it will need to be replaced.
Aug 09, 2008 | Toshiba Satellite A85-S107 Notebook
Broken key
Your best solution would be to buy a new keyboard for the laptop. Look on eBay for a replacement.
Nov 11, 2007 | Computers & Internet
O2 XDA II mini fell down
your unit experienced shock. due to fragility of the phone, your LCD might be broken, if not, the LCD connector needs to be refitted to its slot. If the problem is still the same, you need to replace ur LCD.
Oct 25, 2007 | O2 Xda II mini
Acer NSK8458AN Keyboard Logo
618 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
