Question about Sewing Machines
Presser foot Pfaff 1473 presser foot will not stay locked in the down position.
    New Friend:
Acetone polish remover on a qtip clean the shaft real good up inside where the lever moves it up and down. Once all the old grease and dirt is removed it should work like a charm..
Posted on Dec 16, 2013
  • 1 more comment
  • Kimberly Fisher
    Kimberly Fisher Dec 16, 2013
  • Kimberly Fisher
  • Debra Greene
    Debra Greene Sep 10, 2014
    just how to get it to clean it ?
I have the same problem with my machine. Did you find a solution?
Posted on Jun 11, 2013
To drop the bottom feed open the bobbin area--there may be a switch to the right
Posted on Mar 09, 2010
Pfaff Expresions 3.0. Using my zipper foot with 3 teeth. But can not get the needle to position to sew close to zipper
Um, not sure what presser foot you are using--there are several.
If it is the invisible zipper foot, there is a groove in the bottom of the presser foot that straddles one strip of zipper teeth which positions it close to the needle. Zipper foot #4 snaps to either side to enable the needle to be close to the zipper teeth. The Narrow Adjustable Zipper/Straight Stitch and the Non-Stick Zipper Feet are moveable left or right.
Pfaff Presser Feet
Oct 01, 2016 | PfaFF Sewing Machines
Pfaff 7550 presser foot will not go all the way down after using darning foot and returning to regular sewing.
By chance, do you still have the darning foot on the machine? If so, it is shorter than a regular foot which allows space to manually maneuver the fabric.
Also check that the presser foot pressure is activated and the feed dogs are in the up position.
Sep 06, 2016 | PfaFF Sewing Machines
Can the presser foot be raised slightly on pfaff tiptronic 2030 to facilitate free motion quilting? There is not enough clearance with feed dogs down to freely move material to quilt. Thank you.
You need a special foot for free motion quilting--it is slightly shorter in height than a regular presser foot, which essentially provides space between the presser foot and the needle plate to manually move the fabric. Sometimes machines came with a standard darning foot accessory. Your Pfaff dealer probably has at least one style in stock. But there are other specialty feet you can probably use, ie Big Foot, clear free motion foot, C-shaped, oval, etc. You can also purchase a shank adapter (verify it is the correct shank for your machine) and use it with a kit of snap-on presser feet so you can have a variety of presser feet for different functions.
Pfaff Presser Feet
Pfaff Big Foot Free Motion Quilting Foot
Pfaff Free Motion Guide Presser Foot
Pfaff Free Motion Open Toe Quilting Foot
http://www.sewingpartsonline.com/snap-on-sewing-machine-presser-feet.aspx
May 07, 2016 | PfaFF Sewing Machines
Presser foot level on pfaff 1540 will not go down?
Hi Donna. The lube in your pressed bar had gone gummy. There is a spring inside the bar and it gets stuck. You will need to have a pfaff service tech clean and relube it. Could be included in a standard machine service.
Dec 22, 2015 | PfaFF Sewing Machines
Can I use modern presser feet with my Pfaff 130?
It all depends on your particular model machine.
Found on the internet, Low Shank vs High Shank:
"When presser foot is down, measure the distance from the bottom of foot to screw-hole that holds the foot onto the presser bar. Singer slant is for slant needle machine only. A high shank machine measures approximately 1 1/4" from the screw to the bottom of the foot."
http://www.sewingpartsonline.com/sewing-machine-presser-feet.aspx
http://www.sewingpartsonline.com/pfaff-sewing-machine-presser-feet.aspx
Pfaff Presser Feet
You may be able to use snap-on feet if you can first buy the shank adapter for your machine. You can buy a whole kit of 10 or more different snap-on feet that you would be able to use with the adapter shank.
Buying brand-name accessories could get very expensive. Some believe the generics or snap-on are inferior, but that is a matter for the owner to determine after deciding how much the accessories will be used. Personally, the snap-on feet I've used serve their purpose. If I am using a foot very frequently, I will consider buying the brand-name because the quality is usually better.
You'll need to determine what shank your machine has and whether these feet will work on your machine. Frequently, you can find accessories on eBay.
Here's an example of an adapter for low shank:
Generic Snap On Low Shank
http://www.thecolorfulworldofsewing.com/Pfaff-Presser-Feet/
11 Piece Snap On Presser Foot Set
15 Piece Presser Foot Set with Walking Foot
32 piece: http://www.thecolorfulworldofsewing.com/32-Piece-Presser-Foot-Set-with-Bonus-Needle-Threader.html
In case you need it, here is a manual for your machine:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CCIQFjABahUKEwiL_5_30pDIAhXRBpIKHSP2Bas&url=http%3A%2F%2Fwww.voiles-alternatives.com%2Fdocuments%2Fvoilerie%2Fmachine%2FManuel_pfaff_130.pdf&usg=AFQjCNGAJ_-_R3MN_5aa1L1yRJ38-FrUVQ&bvm=bv.103627116,d.aWw&cad=rja
Sep 23, 2015 | PfaFF Sewing Machines
The presser foot lever keeps falling down when set in the up position on my Pfaff Performance 2056. How do I fix it?
The presser foot return spring needs to be replaced, it's a inexpensive repair.
This sounds like a job for a repair shop.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Nov 28, 2014 | PfaFF Sewing Machines
PFAFF sewing machine: How do I attach the gathering foot on the PFAFF 1473?
usually a gathering foot or ruffler fits on like one would fit an old style foot. Unscrew the thumb screw that holds the snap on foot holder.... and place your foot making sure the needle holder thumb screw holds the lever on the other side. And tighten the thumb screw to hold on the foot.
Good luck.
Aug 02, 2012 | PfaFF Sewing Machines
Pfaff 2144 presser foot lift
sounds like something has come loose or is broken, the machine needs to be serviced
Mar 18, 2012 | PfaFF Sewing Machines
Pfaff Model 1222. The drive belt seizes up and
Try lowering the presser foot lever one click down (needle down presser foot up position). You maybe in the bobbin winding mode that is why it is locked up for your safety, you don't want to puncture any body part while winding the bobbin. It locks up the needle and the balance wheel while it allows the winder to spin.
Jun 15, 2010 | PfaFF Sewing Machines
Fabric does not move forward
Either the presser foot does not have enough pressure on it or it is not lowering all the way to the fabric.
Remove the fabric.lower the presser foot.If the presser foot has no or little pressure look for the pressure regulator on top the machine or on the left side and see if you can make it tighter. Not all machines have this.Look to see if there is space between the foot and the teeth when you turn the handwheel. If there is space then the machine needs an adjustment.
sewman7
Apr 27, 2009 | PfaFF Hobby 4260
Sewing Machines Logo
225 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
