Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi 52725 52525 Red Light turns on
When I power up my 52725 everything appears normal. The fans start and the bulb turns on. The sound comes on then the picture comes on. After a few seconds the set shuts off and the red light is on constant. Prior to this situation the set would not come on. We would unplug and try it again. Most often it would start up and be OK. As a point of reference I swapped out the bulb, no change. I swapped out the power supply board, no change. I swapped out the entire main chassis, no change. I would have swapped out the lamp ballast but I don't have one. Is it possible my problem might be the ballast? Any other suggestions would be appreciated. Thanks for any help.
  • 1 more comment
  • ken_lucas Apr 19, 2009
    I have a complete light engine still in the box. What does the thermal sensor look like and is it removable from the unit?
    Thanks for the suggestion. I appreciate your help. I found the sensor. Removed it from the new light engine and installed it. I have the same result. The set powers on, sound comes on, the screen stays on for only a few seconds then goes off. The "lamp" indicator lights solid red.
  • ken_lucas Apr 20, 2009
    I was able to read the blinking light code. It appears to be 3 4
    I checked my service manual and I believe it is "lamp abnormality". It is real puzzling to me. I'm more determined than ever to find a fix for our set. There is a big void in our family room where the TV used to be.
  • 41 Answers
The problem might be the thermal sensor on the light engine. with all the work you have done on this i would suggest taking a look at the thermal sensor. these are known to go out.
Posted on Apr 19, 2009
  • 1 more comment
  • ZaneD
    ZaneD Apr 19, 2009
    The thermal sensor is on the back of the light box. it is a white rectangle part. If you remove the small screw and pull it up it will come right out. very easy to change.
  • ZaneD
    ZaneD Apr 19, 2009
    when that happens press and hold the menu and device buttons at the same time. the lights will start blinking. what is the blink code?
    it will blink like 2 times and then 3 times and that will be the code.
  • ZaneD
    ZaneD Apr 20, 2009
    the other thing that it would be on an error 34 would be the light engine itself. if you have one change it out. you might be missing what mitsubishi calls the lamp enable signal. the lamp will turn on and then shut off.
Tv will power on not picture
I would have the power supply checked for the screen and then have the power button checked it may be faulty.
Sep 20, 2017 | Panasonic WD65638 Mitsubishi WD65638 65""...
I have an optima hd180 that will not power up. The projector was indicating a bad bulb, so I replaced that with a new one. Now it still will not power up and the fan does not come on either.
Problem w/ OEM bulb, it causes a lot of issues from my experience. Your ballast might have gone bad, hopefully it's just that. Check the voltage output of the ballast, make sure you're getting the proper amount.
Aug 14, 2015 | Office Equipment & Supplies
73" Mitsubishi DLP. turned on the tv and got only sound, no picture. after a minute it would shut down and red light would pop on the front. replaced bulb and hooked it back up. now it turns on but af
Try cleaning the little fans that keep the bulb cool, the temp sensor will shut it off so not to damage the bulb , the winning sound may be the fan going bad or not working like it should.
Mar 07, 2013 | Televison & Video
The red light was on solid, and the manual said to replace the lamp. I bought a new lamp and put it in, but still no picture. The fan comes on, it tries to power up and then in about 20 seconds the red...
these TV's have lots of problems. Don't waste your money on repair. But towards new one or you will be constantly replacing parts.
But anyway sounds like a power supply or light eng problem. If all measurements are good then the chassis needs to be sent to Mitsu for repair (approximately 140 updates to it).
Feb 26, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Have a Mitsubishi WD-62327 DLP projection TV. It is a few years old. Would not turn on. Blinks red - 3 short red blinks then 1 longer blinks - and repeats. We have disconnected everything, unplugged,...
if you hold the input and menu button for 5 seconds it will flash you a code 36 is the lamp fan / dmd fan has gone bad. pretty common. not hard to change but will cost 100 in parts and whatever labor may be
Jan 18, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Replaced bulb in Mitsubishi WD-52525 and it still does not work
Press the input/device button and the menu button at the same time. Green LED will blink a two digit code blink 1st digit short pause blink 2nd digit longer pause and repeat. Any number of problems can cause this same symptom.
If the red LED your refering to is the Status LED and not the Lamp LED then you have big problems. A red Status LED indicates no communication from the Format board to the DMD board (light engine). 1/2 the time caps on the format board itself the other 1/2 must send entire electronics package to Mitsubishi.
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv Shuts off occasionally 1min upon power up shows red lamp light
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi wd-52525 no picture or sound
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Jan 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Red light stays on
First before a reset the set must turn on, if the set just sits there with the red LED on you have further problems, so does the set display anything?
Oct 08, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
339 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
