Question about Texas Instruments TI-89 Calculator
Graphing radical functions
When I graph y = square root of x, or cube root of x, or any root of x, I get an error message saying undefined variable. I don't understand this.
  • Anonymous Mar 31, 2014
    need to multiply roots with variables and exponents and see them in the same way
I have a TI-89 Titanium and I have experienced the same problem. HERE IS HOW TO FIX IT:
Goto " MODE " and scroll down the options until you get to
" COMPLEX FORMAT " change that option to " RECTANGULAR " and press ENTER until you exit out of the " MODE " screen. (very important that you press ' enter ' until you exit because if you don't, it will not save your changes. )
Posted on Mar 15, 2009
I had the same problem, when the term under the root could be <0 the complex mode can't be polar. Changing to another mode graphed it.
Posted on Feb 14, 2008
D(x) = sqrt 3x/2
Posted on Nov 29, 2007
SOURCE:
Ti 84 plus wont graph
You might have used an inappropriate variable name.
For functional graphs y=F(x), the independent variable must be X
For parametric graphs, the independent variable in the x_t and y_t functions must be t.
For polar graphs the independent variable must be Theta, and for sequence graphs, it must be the special wiggly n.
Once you select the type of graph, the independent variable is entered by pressing the key marked X,T, Theta, n.
Dec 19, 2013 | Office Equipment & Supplies
Why does the TI-nspire not give complete graphs of cube root and other franctional power functions?
I do not see why it would do that. Maybe you restricted the domain to positive values of the independent variable.
Anyway, my CX CAS has the latest OS version and it draws cube root for positive and negative values of x.
By the way the cube root is made up of one branch only, not 2 like the square root.
Here is a screen capture.
Nov 05, 2012 | Texas Instruments Ti Nspire Cx Cas Graph...
Everytime I try to do powers and square roots I get an error message
An ERR: MEMORY is given when there is not enough memory to perform the instruction or function. To increase available memory by deleting the contents of any variable (real or complex number, list, matrix, Y= variable, program, Apps, AppVars, picture, graph database, or string), follow these steps. • Press [2nd] [MEM] to display the MEMORY menu.
• Press 2: Mem Mgmt/Del.
• Select a variable or data that needs to be deleted and press [ENTER].
• Use the arrow keys to move the cursor next to the item, and then press [DEL]. The variable or data should now be deleted from the memory.
When deleting programs or Apps, a message asking for confirmation will appear. Select 2:Yes to continue. To leave any variable screen without deleting anything, press [2nd] [MODE].
Jun 29, 2012 | Texas Instruments TI-84 Plus Silver...
Everytime I try to graph an equation my calculator says "error 14 undefined" i don't know how to fix it
Error 14 undefined may occur if you are referencing a variable that currently is not defined
Sep 12, 2011 | Texas Instruments TI-86 Calculator
Want to graph simple functions , like y = x and get error message:" undefined variable".
From the alpha keyboard type in NewProb and press ENTER.
This will clear the contents of all the one-letter variables a-z.
Open the Y= editor and type in an expression for the function to draw.
You do not have to enter a multiplication sign between a numerical factor preceding the variable x and x. If a factor is a letter you must explicitly use the multiplication sign.
Press the key sequence to draw the graph.
Aug 01, 2011 | Texas Instruments TI-89 Calculator
Just bought this Ti-89 and I can't graph a Diff Eq. I followed the directions from the manual on page 69 and get an error: undefined variable
Even though implied multiplication is accepted generally by the calculator when it involves a number and variable, it leads to errors when it involves two sybmols,
xsin(x) is interpreted as a function called XSIN not X*SIN(X).
Suppose you have a function y1, function of t and you write ty1 the calculator will generate an undefined variable error: It reads ty1 as a variable.To prevent the error message you should write t*y1, showing the multiplication explicitly.
Similarly if you write y1'=0.001y1(100-t) the expression y1(100-t) is interpreted as a function call: the function y1 is called with argument 100-t. If it is what you want you should explicitly express the multiplication and wrtite y1'=0.001y1*(100-t).
Feb 01, 2010 | Texas Instruments TI-89 Calculator
Can not display the graphs of functions
I have a manual in another language than English, so I do no know exactly or remotely what procedure you refer to, but I have recreated an instance where one gets the error you talk about. I give you the picts.8147bde.jpg When I enter [Diamond][Graph] I get the following message.
The graph independent variable is x by default, yet I entered cos(f). The calculator is expecting a function of x and I give it a function of some as other entity. Hence the error message. On the command line you cannot change the argument of Y1. It is x by default.
Hope it clarifies things.
Mar 11, 2009 | Texas Instruments TI-89 Calculator
How do I solve radical expression and equations using the TI89?
1. square of 12
2. cube root of 48 a raise to 5 y raise to 6
3. square root of 128 y raise to 5
4. 6th root of 9 y raise to 2
5. cube root of 24 y raise to 5
6. 10th root of 32 x raise to 5
7. 15th root of 64 x raise to 9
8. 4th root of 10000
9. cube root of 192 p raise to 5
10. cube root of 256 y raise to 12
Jul 04, 2008 | Texas Instruments TI-89 Calculator
Undefined variable
go to home and type Define x
Apr 13, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-89 Calculator Logo
1,464 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Steve Allison
Steve Allison
Ekse
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
