Question about Steinberg Cubase Studio 4 Full Version for PC, Mac
Setting up audio playback and recording in Cubase 5
I'm not getting any sound in cubase 5 through my audio speakers that are routed through a compatible ASIO driver, which is linked into a compatible external soundcard.
I've followed the instructions provided in manual. For example: device set up/ choosing the correct driver/ setting up audio buss inputs and outputs. I seems to have all the right drivers and hardware available but nothing's coming out of my audio speakers.
Any advice greatly appreciated...Many thanks.
Richard
5 Suggested Answers
  • 75 Answers
SOURCE: firebox and cubase se not workin
https://www.steinberg.net/1069+M52087573ab0.html, If u have purchased the software,just go to this this link,register ur product. U will get the steinberg cubase customer care, just try contacting them and rectifying the problem, because this is too specific and technical.BEST OF LUCK!!!! THANK U!!!!
Posted on Jun 22, 2008
  • 4 Answers
SOURCE: usb mic in cubase sx3
you have a pci audio card so maybe you can add an extra input device by going to devices panel or press F4 shortcut.
and choose your usb mic.
also you can check your wavelab audio inputs. they must have the same config so if you can record woth your usb mic and your poci card in wave lave you must be able to do so in cubase sx
hope it works
Posted on Jul 26, 2008
  • 4 Answers
SOURCE: Cubase REcording/Playback Problems
check first the sample rate maybe its to high like instead of 44k. its in 48 96 or something like that so the buffering isnt catching with the recoding . alogn with your lattency configuration must devices are ok in 512 latency.
and also be shure not to be recording directly to tyour external hard drive
in case of plugin overload issue it would not stop recording suddenly it would slow down first with some crackles and then stop or must shure freeze.
so impretty shure its somethin else.
hope it works
good luck
  • 13433 Answers
SOURCE: cubase audio problem
the settings in the cubase le - devices - device setup are not set properly or the driver has been removed from the computer.
Id suggest you remove both the cubase le and the hardware device you use with it, then reinstall the cubase and your device. you may need to set the setting again in the device setup and it should work fine.
Posted on Jan 03, 2009
Further clarification is that alyhough i can download the drivers and get playback I can't find anywhere that will download the cubase software to allow recording and sequencing etc on my lexicon lambda as...
It looks like you are trying to download Cubase from Lexicon site . .
You can use any software . .
Here is a link for free Audio Recording Software.
http://audacity.sourceforge.net/download/
Or you can buy a new license for Cubase . .
All the best . .
Sep 13, 2013 | Steinberg Cubase Studio 4 Full Version for...
When i import an instrumental into cubase it will playback but will be very distorted, if i change the device settings in cubase and dont use the io2 it will playback fine so im assuming its something to...
In order for an imported file to sound correctly in Cubase, the bit rate and KHz must be the same or you will create garbage when going through your interface. For instance if you have ripped something from a CD it will be in 16 bit 44.1 KHz format. If you were to pull this into Cubase at 24 bit with 48 KHz selected as your projects rate you would encounter this problem. (I'm guessing this is what is causing your problem.)
Please open up cubase and click import, a window should pop up asking if you want to convert formats, please select the check boxes for conversion for the bit rate and KHz (depending on what version of Cubase it will be something similar to this.) An alternate solution is to go to the project preferences and select the rates that match the imported material before importing and no conversion will be necessary. (Although, I recommend always working in 24 bit and 48 KHz if you're machine can handle it.) A final possibility is that you have the latency set really low and the converters can't handle the speed at which the information is being processed. If the above should for some reason not work, check in your preferences box in Cubase if possible or through software that came with your interface and increase the latency. This can cause an audible delay between the time you hit a note and hear it back so make sure to decrease it before recording and increase it while mixing since you won't being recording new material and can use that processing power that would have gone to making sure you hear your live audio quickly can be steered to use plug-ins and get crackling free playback. Remember, with latency, even if get crackling from a low latency you will not hear that crackling upon mixdown! However, I'm quite sure your problem is with conversion rates, but if never hurts to know or get a reminder on things like latency. Cubase is a high quality product and I hope you enjoy using it. Thank you and I hope this helps.
Feb 25, 2011 | Alesis iO | 2 Sound Card
Problems with yamaha mw10c usb mixing desk i have a signal on desk but cubase is not picking it up and i can find no option in any cubase menu to read the usb audio
Make sure that in the control panel of Windows, "Sounds and Devices" under the "voice and recording" tab, the Yamaha mixer is shown as the device for both voice recording and playback.
Feb 04, 2011 | Yamaha MW10C 10-Channel USB Mixer
How do i get my samson c01U mic to work with windows vista and cubase le?
plug your condenser microphone into your computer before starting up the cubase program; then after you plug it into your computer start cubase; when cubase loads, press the [F4] key, then that will bring you to the audio configuration menu, there will be a speaker option and microphone option or what ever that stuff is; go to the microphone option and choose the microphone that you are using, then after you choose your microphone setting click close; then after that make create a [audio] then on the audio tab you will see a red button, by pressing that it will allow you to record, but there is another button beside it called a [monitor], press that button then it will allow you to hear your voice while you record your vocals. hope this help.
Apr 21, 2010 | Samson Audio C01upak C01u Microphone and...
Will this work with cubase le4?
cubase le is a learning series. you can try in cubase sx or nuendo for good result.
Apr 06, 2010 | Steinberg Cubase System 4 USB Audio...
I am totally lost!! All I have is the lambda lexicon and cubase LE4 on my desktop.Apparently it is not set up correctly. I want to record guitar and voice I have sound on lambda through mike and guitar but...
All it needs is a USB connection. You'll need to go into Cubase device setup and make sure your lambda drivers are selected. Then create the audio channels in cubase with the inputs set as the inputs you're using for guitar and mic. There is a monitor button right next to the record enable button that needs to be enabled if you want to hear playback from your computer.
Feb 20, 2010 | Lexicon Lambda Usb Desktop Recording...
Recording with cubase problem
Need to set it to stereo. There may be a switch on your mixer, and you will also need to change the settings in Cubase to record in stereo, not mono.
Jul 30, 2009 | Lexicon Omega Desktop Recording Studio...
No sound in playback (but can hear click track)
This might seem simple, but just to check: you have switched off the monitor on the track when you go to playback? With track monitor engaged, you will not hear playback, but will continue to hear the live monitor.
Sep 26, 2008 | Tascam US-144 Sound Card
hope it works
good luck
May 10, 2008 | Steinberg Cubase SX3
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
Steinberg Cubase Studio 4 Full Version for PC, Mac  Logo
511 people viewed this question
Top Steinberg Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
 Grubhead
Grubhead
Are you a Steinberg Computer and Internet Expert? Answer questions, earn points and help others
