Question about Toro Lawn Mower With Toro Power Tools
Hard start and sometime stalls while engaging blade
My toro personal pace SR4 model 20056 has been in and out of the dealership three times in the past 2 years for the exact same promblem. I have the same dealership (where I purchased the mower) service the mower prior to every season. The mower is only 4 years old.
The problem is that when I can get it started it might run OK for a while but it will then start to run sluggish. Sometimes when i try to engage the blade it will actually stall out and then I will have an even harder time getting it started again. While trying to restart the mower I often have to use the primer more to keep it from stalling. I'm really getting tired of the same problem year after year. If you have any suggestions I would be greatful. I do really love this mower, but enough is enough.
During the Winter, the fuel was completely drained.
  • asommers4 Apr 19, 2009
    Thanks for the carb tip. I think I'll have to try this because the gas was fresh from the the station up the road a week earlier (87%). I never leave the gas sitting through the winter or even a couple months for that matter. Thanks again, I really appreciate the time and effort. Have a great Summer.
3 Suggested Answers
  • 2468 Answers
SOURCE: When engaging the deck mower
have you removed the sediment bowl located on the bottom of the carburetor and looked to see if there is a lot of dirt and gunk in the bowl,then while this bowl is off there will be a float (metal or plastic) make sure theres a good supply of gas running out of here where the bowl would normally be,if not,then it could be a plugged needle seat or port in your carb and will need to be cleaned
Posted on Apr 14, 2010
  • 6468 Answers
SOURCE: my toro personal pace lawn mower starts hard and have to pump primer button to keep it running
you need to open the carb and clean the jets
Posted on Jul 03, 2012
Toro personal pace mower will not stay started?
If ir starts and runs for only a few seconds it's a dirty carb/bad gas. Drain the fuel system and use FRESH gas; change out your fuel supply monthly to avoid "phase separation" issues. If it runs for several minutes and then dies it is possibly a sticking valve. Do a compression check cold and after it stalls to confirm. Hope this helps
Mar 08, 2015 | Toro 20372 Recycler Personal Pace...
Toro Personal Pace sounds like it is running at half power
got oil in it, or do you add oil. Left outside alot, fuel line clogged. Is the gas old. Check the blades and the exit portion of the clippings. Does it have a drive train for ease of moving. those can bog down a mower. good luck
Apr 30, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro 2009 personal pace mower transmission went out
You should post this question in the lawnmower section so the proper expert will see it..
Aug 29, 2012 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro 20056 engine runs but the cutting blade does not engage
you have a Toro and for whatever reason it is listed in the flat panel TV area.
Aug 29, 2012 | Televison & Video
How do I remove the blade of my SR4
This is from the Toro owners manual for SR4 euper recycler model 20058 serial number 250003464
The steps and picture are on page 18 of the manual 3352-864[1].pdf
You can enter those numbers on this page for a manual:
https://lookup3.toro.com/request/request.cfm
1. Disconnect the spark plug wire from the spark
plug. Refer to Preparing for Maintenance
2. Tip the mower onto its side with the air filter up.
3. Remove the
2 blade nuts (A)
and the
stiffener (B).
4. Remove the
blade (C).
5. Install the blade and the stiffener that you
removed in steps 3 and 4.
6. Install the blade bolts and torque them to 15 to
27 ft-lb (20 to 37 N?m).
The replacement blade part number is:
108-3762-03 (google / net search)
Thanks for choosing FixYa,
Kelly
May 20, 2011 | Toro Power Lawn Mower
How do you replace the belt
this is not easy you have to turn the mower on its side <make sure the carb is down > take off the blade belt guide and look at it the space is really tight and you have to hold the trans with two fingers and then walk the belt on. its hard because the trans is spring loaded to twist backwards to keep the belt tight
Aug 13, 2009 | Toro Garden
Toro Lawn Mower With Toro Power Tools Logo
428 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
