Question about Samsung TXK2754 27" TV
Samsung TXK2754 27" main board cracked after fall
Would like to know if and where I could get a replacement board. Tks
  • Allain Sep 19, 2007
    Thanks Shuttle83,
    A shop charges over 300.00$ to do the job, I can get the TV for cheaper.
    I was just wondering if someone had a board for sale that I could replace.
    Thanks again
    Al
    Genius:
  • 1,139 Answers
You would have to contact the manufacture. a better solution would be to take it to a shop and have them repair the board. It would involved using acitate glue and the bridging the wire traces back with wire bridges (jumper wire soldered to the traces). If you are not able to do this on your own a local shop could do the job.
Posted on Sep 19, 2007
SOURCE:
This is Frank La Marca. I received an answer to my original question from Karl W. regarding "no video" on my Flat screen. I replaced the original card with BN81 04368A which was recommended - but stil
Hello, that set is an LED set a Samsung UN55C8000 if I'm correct, and there have been issues with the power supply the provides the voltage to light the LED's but then I had one that the main board was preventing one set I had the other day. Take a flashlight and shine it across the screen and see if you can see a faint image while you have sound working. If you do, then you will know it's a LED issue. Let me know....tks
Jan 30, 2015 | Televison & Video
I have a Samsung LN40C530F1FXZA and the problem is that it will not turn on after watching it for any period of time. It will turn on if I let it sit for 15 minutes or more. Able to watch as long as I want...
Hello, that's funny, I just had the same issue with that model, and the main board is bad, their hard to find, but there's a place on e-bay that will repair it for $55......tks
Jan 30, 2015 | Samsung Televison & Video
Purchased in 12/2012, LCD panel/screen replaced 8/2013. Four months later--no picture, no sound, no OSD, backlight still workingLCD panel is intact--not cracked. Don't know why it doesn't work.
No Picture/No Sound issue is either related to a power supply or main board issue. I'm willing to guess main board, it's where the video and audio signals are generated!
Apr 05, 2014 | Samsung Televison & Video
The volume button onmy samsung s4 is not working, it is dented in the middle and now its not working right. The reason it is like " DENTED " it fell off my bed which was a fall of about 3''foot onto carpet...
I just opened a S4 mini and replaced the SIM carrier, so got a good look at the way these are made. You may be able to replace the volume key, or it could have simply slipped out of position with a very unfortunate landing. There are ten screws and 4 ribbon cable connectors plus another one between the main board and the display board. You have to decide if you have the appetite to take on a repair like this and if the part is available. You might also look for a unit that had a cracked screen but the rest is OK for swapping parts. Another possibility to be sure of is that the fall broke one of the volume switches on the motherboard off.
Feb 20, 2018 | Cell Phones
Black screen
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
Sep 10, 2017 | Samsung LN32A330 32 in. LCD TV
MY PSP HAD A FALL NOW IT KEEPS CUTTING OFF
Possible that the main board is broken. So you might had to open up for sure and look for cracks in the power section, the main board or the connectors.
Use a good light to look aided with the help of a good magnification lens. Solder bridge the cracks.
Sep 11, 2010 | Sony PlayStation Portable (PSP) Console
Printer is making clicking sound after dropped to the floor
Possible that you would have damaged the printer harware inthe fall. So in the first place remove the power supply and check for crack inthe board. If the power output is showing the required DC, the checck the main mother board for cracks, checck using magnifier and resolder suspected joints.
Sep 08, 2010 | Lexmark X2600 InkJet Printer
Ihave a 1999 saturn with a cracked chain case cover.Is this hard to replace or can it be welded .Just wondering about time estimated to replace cover.TKS.
It may be welded by someone that knows what they are doing, but covers done just crack, you need to know WHY it cracked. plus its a big job, replace all timing chain components. while its apart. Plan on at least 700.00
Mar 12, 2010 | Saturn SC2 Cars & Trucks
Sony CFD-E100 now only powers up on batteries
The AC inlet needs to be replaced, there are bad solder connections on the PC board for the inlet, or the traces are cracked on the board. I have seen all of hte above over the years for these types of units. The power board can be puirchased for $28.11 using part number: A-1124-986-A from tritronicsinc.com.
I don't have the part number for the actual inlet at teh moment, but I'll try to locate that number for you as well. Check for poor solder connections or a cracked trace first and update this with the results.
Dan
Nov 01, 2009 | Sony CFD-E100 Boombox
Cracked lens on Samsung Pro 815
As it would mean the replacement of the entire lens assembly, even if repair is possible it would not be financially viable.
Sep 27, 2017 | Samsung Digimax Pro 815 Digital Camera
Samsung TXK2754 27" TV Logo
51 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
