Question about Frigidaire Dryers
Frigidaire gas dryer - moisture sensor
When I use the auto dry setting on my frigidaire gas dryer, it is no longer sensing that the clothes are dry. It is stopping the cycle when the clothes are still damp. I had this issue with our dryer at our previous home, and I was able to clean the sensors on the inside of the dryer and all was fine again. The man who had come to install the dryer at that home warned us that if we used fabric softener that we could expect this to happen so we should clean the sensors regularly. Unfortunately, cleaning the sensors does not seem to be working this time. Does anyone have a good solution for how to address this problem? Perhaps there is a more thorough way to clean the sensors that I'm not aware of that someone could share? Are there other sensors in the dryer in addition to the two near the lint trap that I'm maybe not seeing? I'd appreciate any suggestions. Thanks!
catriver
  • 878 Answers
SOURCE: Whirlpool GEW9200LQ0 Gas Dryer
Andeb, 90% of the time long dry times are caused by blocked vents. If you are sure that this is not the case there are a couple of things to check. First check the sensor; press the more time button and less time button 4 times until 88 shows in the display.(more time,less time, more time, less time). Open the door and you will hear a beep and a see a code. On the inside just below the vent screen is the moisture sensor. Moisten your finger and lay it across the sensor strips covering both. If you hear a beep, the sensor is good. Sometimes they build up with fabric softner and need to be sanded lightly. Another issue might be the burner coils. Remove the bottom panel and check to see that the burner is igniting and remaining lit. Sometimes these coils become week and will not sustain the flame. I will attach a diagram, look at number 13 and 14 on the picture. These are the coils. Catriver..post back.
Posted on Sep 18, 2006
SearsTechToo
  • 261 Answers
SOURCE: Whirlpool Dryer LGR7646EQ3 - Auto Dry is not working
I went over the part list and I didnt see a sensor, if it is there it will be two silver wire bars either on the back bulk head or at front right just below the door, possibly your timer has gone south too.
The only item I saw was a dryer cycling thermostat that shuts off heat when a certain temp is reached, here is a link;
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=2893&PPStack=1
Posted on Sep 16, 2008
huuum
  • 750 Answers
SOURCE: We have a Frigidaire Gallery
mamch,
You said,We have a Frigidaire Gallery dryer with a moisture sensor. I've had this model in the past with no concerns, but our current model doesn't seem to work as well. When set to an "automatic" cycle (where the moisture sensor is used) the clothes don't always come out dry and it has to be turned on again. Would there be any reason for this?
What's the model # and the age?
There are two types of moisture sensors.
One has to strips of metal on a black disk looking thing on the dryer rear wall and the other works on steam rather than contact!
Could be you had the better on before that was the contact one rather than the steamm sensor!
How long to dry a load of clothes ?
Posted on Sep 19, 2008
  • 198 Answers
SOURCE: clothes still damp after running a cycle on auto moisture setting
Clean the vent hose and vent outlet
Posted on Dec 04, 2008
  • 212 Answers
SOURCE: dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Posted on Jun 24, 2009
Frigidaire affinity dryer takes long to dry
it could be the tempature of dryer is low but more likely the clothes are not spun dry as used to be .
Mar 05, 2015 | Frigidaire Dryers
Gas dyer not staying on, all the light are flashing
Does your model have sensor strips inside? Wash them with windex to remove any moisture barrier on them. They sense wetness and if they don't feel any wetness they make the control think them clothes is dry and it shuts down the dryer thinkin them clothes is dry.
Jul 09, 2012 | Frigidaire Dryers
Whirlpool gas dryer (WGD9450WR1) not drying on auto-cycles
try cleaning the 2 silver senser bars located inside the dryer drum on the door side with isopropyl alcohol and lint free wipes,these bars sense moisture and control timer speed,and when they get coated with the chemicals in dryer sheets they become coated and can no longer sense the damp clothes (these sensers use capacitance to sense moisture)
Feb 18, 2012 | Dryers
Broken lint screen, what are the 2 wires attached to lint screen housing?
the red wires go to the sensor,this is used for the auto dry where it might say more or less,when the clothes spin they rub up against the sensor when the clothes start to dry it senses this and advances the timer until the clothes are dry and then the dryer will shut off automatically.go here to see the part
https://www.repairclinic.com/PartDetail/Moisture-Sensor/131845801/823088
Nov 20, 2017 | Frigidaire GLGQ332A Gas Dryer
I have model # crgr7900A31 gas dryer front end loading. The dryer will not shut off. It continues to run.
Hi, If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Apr 14, 2010 | Frigidaire FGQ332ES Gas Dryer
Blinking AD
AD is auto dry you may need to clean the sensor or you may have a fauilty one ...Auto Dry Loads dried using the Towels, Heavy Duty, Normal, Perm Press, and Delicates cycles will dry automatically at the selected temperature to the desired dryness level. The dryer uses sensing bars to sense the moisture level of the load as it tumbles through heated air. Auto Dry cycles save time and energy and protect fabrics. The estimated drying time will be displayed for about 5 minutes, then the outside of the display will light up in a circular track to indicate the drying time is automatically being determined by the sensors. When the load has reached the selected dryness level, it will continue to tumble, unheated, during a Cool Down period. This helps reduce wrinkling and makes items easier to handle during unloading. The estimated Cool Down time will be displayed. Drying time varies depending on size and dampness of load and fabric type. If the load is too small or almost dry, the sensing bars may not detect enough moisture to continue the cycle and the cycle may end after a few minutes. Select a Timed Dry setting to dry such loads. Room temperature and humidity, type of installation and electrical voltage or gas pressure can also affect drying time. For cycle selection turn the knob on the front of the dryer control panel. The light will illuminate next to the cycle selected. The following is a brief description for what cycles should be chosen for certain items and materials to be dried.
Sep 18, 2009 | Frigidaire GLEQ2152ES Electric Dryer
LED display on dryer reads AD???
All this is doing is letting you know that the Auto dry sensors are kicked in and checking to see how dry the clothing is.
Mar 29, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
We have a Frigidaire Gallery dryer with a moisture sensor. I've had this model in the past with no concerns, but our current model doesn't seem to work as well. When set to an "automatic" cycle...
mamch,
Sep 18, 2008 | Frigidaire Dryers
Dryers Logo
159 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
