Question about Microsoft Xbox 360 Pro System Console
DVD Rom replaced
I have a xbox 360 and the dvd drive went bad. I replaced the drive now i get "to play this disc, put it in an xbox 360 console. the drive I had a Hitachi rom ver. 0078fk and now have a Hitachi rom ver. 0079fl
  • mentzer4 Apr 19, 2009
    where is the logic board?
    did it thanks works great
    Sniper:
  • 50 Answers
When you switch the original dvd rom to a replacement. you MUST remove the logic board from the original drive and put it into the replacement drive for it to function
Posted on Apr 19, 2009
  • kiel123 Apr 19, 2009
    when you open up the dvd rom drive its the only greenish looking board in the unit. Example: here
    no problem glad it worked out. please rate, thanks
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
Error msg: to play this disc put in xbox 360
the Laser In The DVD Drives Failed.
Try a CD/DVD to see if it will read A single Layer DVD, Rather than the 360 Dual-Layer Disk.
You might try a laser head cleaning CD Disk.
Or requires drive replaced et,c. ** This is not swappable And should Be caried out by """ An Xbox 360 Drive Replacement Specialist, As the dvd drives logic board is paired to the Motherboard, And therefore have to be re-matched.
Mike @ Compurepair.
Nov 05, 2009 | Microsoft Xbox 360 Console
I put a new disc drive in my xbox 360 but it dosent read games
Why you replaced the dvd drive i do not know, The problem is if you have installed a non microsoft xbox dvd driver it will not work! If your original dvd driver is broken as to why you have replaced it, contact microsoft or your local games shop for another xbox 360 or drive. You can also by a addon driver, you can see it here
http://www.amazon.com/Xbox-360-HD-DVD-Player/dp/B000JHO4L0
Jul 19, 2009 | Microsoft Xbox 360 Console
My xbox 360 wont play my games
if it tells you the disc is unreadable then the laser maybe bad or dirty.
try a cd lens cleaner and see if it solves the problem. if it doesn't then your dvd rom will need to be replaced
Apr 21, 2009 | Microsoft Xbox 360 Console
Won't read disc's
HI. this is being caused by a damaged optical lens assembly. you have two choices here. you can opt to replace the entire DVD-ROM drive or, you can replace the optical assembly.
we recommend replacing the entire DVD ROM drive. this is much easier and, its just plug-n-play.
Mar 27, 2009 | Microsoft XBOX 360 ARCADE Console
Bought a Replacement Samsung TS-H943 DVD-ROM Drive for Xbox 360
Hello. The pcb board is "married" to the motherboard with a certain firmware. If you didn't flash the new drive with the correct firmware it will not work. The best thing to do is just replace the laser if you have DVD drive problems. I hope you still have the old one! Good luck to you. Thanks!
Jan 17, 2009 | Video Game Consoles & Games
Installed new Xbox DVD ROM, but cannot read games
The DVD drives must match the motherboard that it came with. Unless you go through a very complicated re-flashing process. If the motherboard and DVD drive do not match, it will not play 360 games
Dec 04, 2008 | Microsoft Xbox 360 Console
Xbox 360 says to play disc put it in an xbox 360 console
The box isn't loading the decoder softwarer for the Disc. The Xbox discs are encoded HD DVD-ROM discs, and the box needs to recognize them so it can load the decoder software. It probably says "play dvd" on the xbox dashboard right?
Apr 22, 2008 | Microsoft Xbox 360 Console
Loud grinding, spinning noise with game in console.
Even if it is still playing dvds it might be the dvd-rom drive, usally it spins a game faster than a dvd. Or it could be the harddrive if it was trying to save something. try to download a demo or something to check the hard drive.
Mar 17, 2008 | Microsoft Xbox 360 Console
Message "To play game put game in xbox 360 console"
Pick up in the DVD is bad or weak and will need replacing.
Or replace the whole DVD unit.
Make sure the disks are clean and not too scratched up
Check here for more things to try
Nov 07, 2007 | Microsoft Xbox 360 Console
Open Questions:
Microsoft Xbox 360 Pro System Console Logo
102 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
