Question about NEC MultiSync P1250 Plus (White) 21" CRT Monitor
NEC P1250+ hisses and scrren blips intermittently
Hi, My NEC MultiSync P1250+ has two symptoms: 1. At start up it emits a high frequency hiss from the back. After it warms up a bit, the noise stops. 2. Intermittently, the picture will blip off for an instant and come right back. Pleas Help, Thanks.
  • sekess Sep 26, 2007
    Thanks TechWizard. I was hoping this might have been a common issues with these monitors and that maybe there was just a cap or two that I could replace myself. I will probably end up getting a new monitor. But it's too bad -- the picture on this guy was real nice.
    Thanks again.
    Scholar:
  • 68 Answers
I had the same problem. Your monitor is warning you of failure. The hissing sound is the picture tube powering up. The momentary blank screen is when the power supply for the monitor has become hot. Your monitor is getting ready to quit. My suggestion is to buy a new monitor. To have a tech repair it would be more expensive then buying a new one.
Posted on Sep 20, 2007
Loud hiss on one channel
could be a bad cable or could be the high frequency control is turned up too high and the speaker without the hiss has a blown tweeter (high frequency driver), and you're trying to compensate for the lack of highs on the bad speaker by turning up the high frequency on the EQ, which makes the other speaker hiss.
Jun 05, 2012 | Audio Players & Recorders
The Motherboard
Hello Pedro, Hi, the hissing sound comes from the power supply box. try another one, make sure connection are tight and secure.
Dec 20, 2011 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
I have a set of two JBL Prx525 that I use in my local band. From the time we got them, they have emitted a hiss sound. The hiss is not present if no sound is being put through them, though. Say a keyboard...
The hiss is caused by the autooscillation of the internal amplifier. To fix that you will need to install some additional filtering capacitors on the power lines, a high frequency filter at both the input and the output of the amplifier (basically just a 100nF capacitor put in series with a 10ohm resistor between the in/out and the ground) and a new routing of the internal cables. Also check a ground loop on the cables.
Jul 11, 2011 | JBL PRX525 Speaker System
6505 +112 has a bad hiss with nothing plugd in
Some hiss at high gain settings is normal. If you get objectionable hiss at 1 o'clock settings of gain, that is too high. Electronics has noise that is "statistical" in nature due to physics that we can't get around in design. Most hiss is created in the preamp area and swapping tubes in the first stage might help. By varying the volume controls and observing the level of the hiss, we may be able to analyze the offending staage of amplification. ALso turning up the treble controls will increase the hiss, as it is mostly in the higher pitches.
Jun 26, 2011 | Peavey 6505 Plus 112 60w All Tube Combo...
Hissing sound intermittent on a ionic pro. hisses on levels low- med,-high.
my ionic hisses after we clean it and won't stop what can i do to stop the hissing?
laurie K
Jan 16, 2009 | Air Purifiers
Speakers have hissing noise coming out of them
Hook a graphic equalizer between the piano and speakers, and turn down all sliders above 8 kHz. Since the highest note of a piano is 4186 Hz (4.186 kHz), you'll still hear all the notes but cut the hiss. If the hiss is coming from the speaker's power amplifier (in which case the equalizer won't help), turn down the speaker volume and turn up the piano volume. Live instruments generally need some doctoring to sound good through high-quality stereo equipment, as they only produce a limited range of frequencies whereas good speakers reproduce a lot more - including hiss.
Dec 25, 2008 | Onkyo GX-D90 Main / Stereo Speaker
Loud hissing through rear (souround sound) speakers
I have the Sony Bravia KDL-46S4100. The high-picthed hiss drives me insane. I have a work around but not a fix. Go into your TV's menu and find BACKLIGHT. Adjust it from 1-9 with the house quiet and find what frequency of the hiss is the least annoying.
Sony Bravia high pitch hiss hissing sound high frequency
Nov 22, 2008 | Audio Players & Recorders
1988 Suzuki Samurai Hissing Sound Under Hood
hi its definatley an air leak if you have replaced the hoses i suggust the next thing you try is see by tighting the carburrettors nuts that hold it to the manifold as these come lose and **** air do the same with the manifold bolts i suspect you will find them loose if not then change the gaskets one at a time with the cheapest first the carburretors then the manifold you may want to go to your car shop and ask for an air leak spray or they may use some other kind of method but basicly you spray it round the carb/manifold and watch to see where the leak is yates210456
Aug 05, 2008 | 1988 Suzuki Samurai
PEAVEY djs4 speaker QUESTION
If a speaker is "blown", there is normally an open-circuit in the voice coil, therefore it emits no sound at all. Can't discount a loose wire, but blown HF drivers are very common.
Dec 31, 2007 | Audio Players & Recorders
NEC MultiSync P1250 Plus (White) 21" CRT Monitor Logo
235 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
