Question about Freezers
Kenore freezer running constantly
Freezer has been running constantly, I bought a new defrost timer. It still runs. Everything I have read says to get ice off the coils. How do I get the back off? There are no screws. There is also no water in the pan. So I am assuming that the line might be blocked.
  • babybear Sep 21, 2007
    It' a frost free freezer. Kenmore 253 9280212
    I did get the back off and there was no ice so it is still running. I had to take the insides apart to get to them. Any ideas now what to try.
  • 291 Answers
Need a model #.. is this a frost free freezer or a refrigerator ?
Posted on Sep 20, 2007
  • Mike Johnson
    Mike Johnson Sep 21, 2007
    should of been a light layer of frost on all the tubes from top to bottom of cooling coils when u had the back off. Not ice but FROST.
    Check freezer...
    for Frost build up and if Fan is blowing,
    Check condenser...
    To make sure clean, and the fan is blowing by compressor.... IF no condenser coils on back
    Check Recirclating Vents in Freezer... to make sure theres no blockage,
    If you frosting up on the evap. cooling coils.. ur heater or defrost therostate needs replaceing.. u said alread replaced d. timmmer
This kind of Food Service Commercial grade freezers have many product protections against excesive heat from a defrost subsystem failure, these protections include a defrost precision timer and/or a digital pcb (control board) composed by many electronic ic's and components.
A common failure is on the relay contcts that energizes the compressor and in many cases the relay nergizes a contactor to energize the compressor if one or this two (Relay and Contactor fails (keep contacting stacked or not released) the compressor continues running with no cut except when by ovrheated ands the overheat protections disconect the compressor until the temperature lowes to safe working temperature locating the trouble on the relay or contactor. But in some cases the control board fails at circuit level and not cut by temperature or defrost program then the control board could be the responsible.
Narciso González Palomera
Posted on Jan 27, 2009
SOURCE:
What do I need to fix when my freezer's condenser is solid ice? The door seal is OK. The fan runs constantly. Nothing stays frozen.
there is 2 componnets you must check inside the freezer, 1defrost heater,2defroset bimetal. check both for resistence (bimetal must be checked cold, should read ok ohms. so the defrost heater. if it has a timer good idea to put a new one too
Sep 18, 2014 | Freezers
Frigidaire freezer runs a lot. Located in garage. In summer runs almost non-stop. Currently outside temps are below 0 deg F and freezer still cyles frequently. Have replace the freezer tstat. Defrost...
Yup, these timers have a tiny clock motor that can get lint on them, causing motor failure, should be simple replacement. Refrigerators in cold garages run more to regulate their temperature below 45 degrees.
Jan 29, 2014 | Freezers
Small chest freezer, running but not freezing, cold inside, everything defrosted
the freezer has a defrost timer and relay. if either is bad, it may get stuck in defrost mode(depending on what position the switch failed in). The fan will run constantly if this is the case. You may choose to follow the wiring diagram on the back of the service panel or hire a technician. If you do it yourself, unplug the unit for your safety
Nov 19, 2009 | Freezers
My admiral fridge/freezer runs a lot but does not get down to temperature
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 14, 2009 | Freezers
Not recovering
Make sure the fan in the freezer is running circulating the air.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 03, 2009 | Freezers
Food thawed, freezer running. I moved packages from in front of air ways and turned thermostat to coldest setting & it didn't change anything, freezer still at 32-33 degrees. help
Aug 30, 2009 | Freezers
Upright frigidaire freezer not running properly
Sounds like your defrost timer has packed it in you need to fit another timer to it and everything will be as good as new.
by turning the timer you have forced it to run nothing to worry about. It has just stopped in the defrost position. What you have done is the first diagnostic test a tech would have performed. I hope this has helped you out.
Jun 30, 2009 | Frigidaire 14 cu. ft. / 396 liter Upright...
Upright freezer not cold enough
IF THE FREEZER IS AUTO DEFROST, DO YOU SEE A FROST BUILDUP ON THE BACK WALL? IF SO, YOU NEED TO DIAGNOSE THE DEFROST FAILURE. THERE ARE THREE ITEMS TO THE DEFROST CIRCUIT. THE TIMER, HEATER, AND BI-METAL. FIND THE TIMER, USUALLY ON THE BACK OF THE FREEZER DOWN IN THE CORNER NEAR THE COMPRESSOR. IT WILL HAVE A CONNECTOR WITH FOUR WIRES ATTACHED TO IT. IT HAS A KNOB THAT CAN BE TURNED TO PUT IT INTO A DEFROST CYCLE. WITH THE FREEZER RUNNING, START TURNING THE KNOB UNTIL THE COMPRESSOR STOPS. THAT WILL BE THE DEFROST CYCLE. THEN WAIT 5 MINUTES AND LISTEN IN THE FREEZER FOR A SIZZLING NOISE AND LOOK FOR A GLOWING FROM THE BACK BOTTOM. IF THE HEATER IS ON, THE TIMER IS THE PROBLEM. IF THE HEATER IS NOT ON, THE HEATER OR BI-METAL IS AT FAULT.
IF THE FREEZER IS NOT AUTO DEFROSTING, CHECK TO SEE IF THE COMPRESSOR IS RUNNING. IF IT IS, ARE THE SHELVES ALL FROSTED? IF NOT, YOU HAVE A SYSTEM FAILURE. IT COULD BE A LEAK, RESTRICTION, OR FAILED COMPRESSOR.
Apr 02, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Freezers Logo
704 people viewed this question
Top Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
