Question about Alpine CDA-7892 CD Player
Remote wire color?
Is the remote wire on the cda 7892 solid blue or blue with white stripe?
So the ground wire and the remote wire hook up i have a vr3 cd player in my car
Posted on Apr 22, 2010
    President:
  • 1,263 Answers
The remote wire will be a solid blue this is always the color no matter what deck you have
Posted on Apr 19, 2009
I put this in my car and the radio works but it dosent play the cds but it reads it
are you running the speakers through an amplifier? if so, it sounds like you are using the blue wire which is the antenna remote to turn the amp on. instead use the blue/white wire.
Nov 03, 2010 | Alpine CDA-7892 CD Player
Tell me the color coding of wall jack to connect cat6 cable to the switch
You can use either T 568 A or B providing that both ends of the cable are wired in the same format. If one side is allready ended thenI would try T568 B standard first.
Pin T568A Pair T568B Pair Wire T568A Color T568B Color Pins on plug face (socket is reversed) 1 3 2 tip 60px-wire_white_green_stripe.svg.png
white/green stripe 60px-wire_white_orange_stripe.svg.png
white/orange stripe rj45plug-8p8c.png 2 3 2 ring 60px-wire_green.svg.png
white/orange stripe 60px-wire_white_green_stripe.svg.png
white/green stripe 4 1 1 ring 60px-wire_blue.svg.png
white/blue stripe 60px-wire_white_blue_stripe.svg.png
white/blue stripe 6 2 3 ring 60px-wire_orange.svg.png
white/brown stripe 60px-wire_white_brown_stripe.svg.png
white/brown stripe 8 4 4 ring 60px-wire_brown.svg.png
Sep 09, 2010 | Leviton (102-5G108-RW5)
C/d plays no sound
are you running the audio through an amp?? if so, it sounds like you are using the antenna remote wire(solid blue) instead of the amp remote wire (blue/white stripe) to turn the amp on. when listening to cds the antenna remote turns off.
Apr 02, 2010 | Alpine CDA-7892 CD Player
Our Phone wiring is underground and the connector box on the outside of mthe house was done in1978. My problem is that I hit the wires and some of them were knocked loose from the terminal and now I don't...
green wires and red wires.......... that is line one. also solid blue and blue with a white stripe is also line one..... so tie the greens and blue w/white stripes together and tape off (if not screwed down to block), and do the same with the red wires tied together with the solid blues.
yellow and black is line two.....and so is solid orange and orange w/white stripe. then just fill in the blanks as stated above.
its simple, think of the wires as speaker wire in a way to simplify what you are looking at. multiple Pairs (+/-) wires color coded. if the wires came off of the screw down posts, just match up the colors like stated above on the posts and screw them back down.
Nov 13, 2009 | Uniden 5.8GHz 2Handset Digital FHSS...
Need wiring diagram for cda-7892
Hi and welcome to FixYa.
Below is the wiring diagram for an Alpine CDA-7892.
It was captured from the user's manual available here.
Good luck and thank you for asking FixYa.
Nov 10, 2009 | Alpine CDA-7892 CD Player
Is the CDA-7892 supposed to have a backlight when off?
Hello ckabee1,
The "illumination" lead on the CDA-7892 is ORANGE and terminated with a spade lug. It should be connected to the appropriate instrument panel light lead from the vehicle wiring harness. You can download a copy of the manual here with all of the wiring color codes. If you do not know the vehicle color code, you can probably find it at www.modifiedlife.com. Just click on "Car Stereo Wiring Diagrams" at the top and select your vehicle make, model and year.
Hope this helps.
Jul 11, 2009 | Alpine CDA-7892 CD Player
I just bought a used dual xd6210 stero deck for my car but i dont have the wireing manual for it. i need the wire color code sheet
there pretty simple red+ goes to keyed power wire. yello is the same keyed power wire.black ground. speake wire will be like two green two violet one will have black stripe that is the negitive solid color is positive green and green violet ant violet white and white blue and blue youll just have to figure out thr front and rear. blue wire is for amp remote turn on wire your speaker wires may be different colors but same idea
Jun 10, 2009 | Dual XD6210 CD Player
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
My wife bought a kenwood z828/uf4. there are wires in the back but none of them are labeled. can anybody help me
red - 12v ignition
yellow - memory 12v cont.battery
orange - illumination
black - ground
white- front right speaker +
white/black stripe - front right speaker -
gray - front left speaker +
gray/black stripe - front left speaker -
violet - rear right speaker +
violet/black stripe - rear right speaker -
green - rear left speaker +
green/black stripe - rear left speaker -
blue - remote, amp
blue/white stripe - power antenna
if you don't have a blue/white strip wire than the solid blue wire goes to power antenna, amp and remote...........
hope this helped you
Feb 26, 2009 | Kenwood Car Audio & Video
Alpine CDA-7892 CD Player Logo
537 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
