Question about Dryers
Getting heat but not drying clothes in the dryer. no blockages in the exhaust and the lint trap is clean.
  • 3 Answers
I also have written in with the same problem as you. I haven't received any input at this time. I have a Whirlpool and I do not know the model #. However there is a toll free number inside my dryer that I am going to call. I think it is possible that there maybe a moisture sensor that could be going out in our dryers. I thought that it could be the thermostat as well. Even though it is heating up, maybe it is not producing enough heat to pull the moisture out. Good luck to you and I will watch this site to see if we get a semi intelligent response:) kraemer_k@yahoo.com
Posted on Apr 20, 2009
DRYER NOT DRYING CLOTHES ALL THE WAY FILTER IS CLEAN AND CLEANED OUT THE LINT TRAP AND COVER. NO CODE GIVEN. HAVE TO RUN TWO CYCLES.
Clean the exhaust duct. The ENTIRE duct, from where it attaches to the dryer to where it exits the house... Failure to dry clothing when you have heat is an air-flow issue
Jun 05, 2016 | Electrolux EIED55H Dryer
Bosch condensation dryer when on heated dry clothes come out steaming hot not dry
Sounds like something's blocking the hot damp air being removed from the drier. If you are confident enough, go through the drier vent system looking for a blockage. If not get a good DIY neighbour or appliance engineer. Silly question, is the drum turning?
Jan 05, 2015 | Bosch WTE86300US 24" Axxis Series...
My 1993 Maytag Clothes Dryer heats up, turns but does not dry the clothes unless I place an absorbent towel in with the items. It sweats water from the bottom of the dryer. What is going on?
To dry clothes, we need 2 things:
1-heat to evaporate the water from the clothing
2- adequate air flow to exhaust the moist air, thereby drying them.
Your heat seems to work.....if you stop the dryer mid-cycle, the clothes should be hot.
It sounds to me like you have a lack of air flow through the dryer. If you can get to the exhaust vent grill outside, then see if you get a large volume of air coming out of it. If not, then look for the louvers stuck closed on your outside grill, or any kind of blockage in your ductwork.
Perhaps undo the vent at the back of the dryer TEMPORARILY
Mar 20, 2013 | Maytag Dryers
My dryer heats up but does not dry clothes. I check ventilation and lint trap, there is no buildup. what could cause it to take forever to dry clothes?
If the drum gets hot to a real degree it has to be a blockage between the drum to where the air exits the home.
They do make a brush designed to go into the area where the lint trap is and be long enough to come out the rear of the unit---A lot of places will come out and professionally clean from trap to vent outlet
A blockage can be dangerous as hundreds of fires happen each year from the lint catching fire in the dryer.
The tube to the outside may seem clear but if blockage anywhere from lint trap to it, that will cause this problem and present a possible fire hazard.
Its not unlike having your vac not pick things up very well...except there is rarely a fire with that.
Dec 16, 2012 | Kenmore Dryers
Dryer putting out hot air but clothes not drying
You have some blockage between lint trap and where the unit vents outside.
Dec 16, 2012 | Kenmore Dryer Sears Elite
My dryer is heating up but it takes a long time to dry.
If the clothes are coming out wet and hot after the first cycle then there is a blockage in the exhaust. This blockage could be at the lint trap or at the exhaust tube leaving from the back of the dryer. You need to check the lint filter area by removing the lint filter and with a flashlight look into the area where the lint filter was to see if there is any build up of lint. If so, you will need to clean this area. Also at the back of the dryer there is a hose that comes from the dryer to an outlet to the out side. This hose could be clogged with lint or possibly kinked to where the proper amount of air flow is not allowed to leave the dryer therefore causing the clothes to have to dry longer. Check these two areas first before going any further due to these checks are simple and may solve the problem.
Good luck hope this helped
Dave
Mar 30, 2010 | GE DVLR223 Dryers
I have a whirlpool dryer and it heats up but dosent dry clothes
you have a blockage in the vent system. If the clothing is hot and wet when you remove them then there is a lint blockage either at the lint trap in the machine or at the exhaust hose on the back of the drier
Dave
Mar 17, 2010 | Dryers
Heats but doesn't dry
If your clothes are coming out hot but still wet you have a vent problem Either the lint trap at the dryer is clogged or the vent coming out of the dryer to the outside has a build up of lint. If you don't clean the blockage it will burn out the heating elements and cause you more problems. A shop vacuum will take care of both problems in cleaning out lint trap and dryer vent
Good luck hope this helped you some
Dave
Jan 28, 2010 | Dryers
Model DLE7177RM, takes about 3 hours to dry a load of clothes. Dryer is NOT overloaded.
Does the dryer heat up or is it just cool air drying the clothes ? If it does actually dry the clothes eventually then it sounds like it is heating up. First thing to check would be exhaust hose. Is warm air blowing out of it ? If warm you got heat. If cool then your heating element isn't working. It should be fairly strong current of very warm air. If weak but warm, then somewhere between lint filter and end of hose you have a blockage caused by lint buildup or hose is bent and blocking air flow. Check hose first. You can disassemble lint trap and go beyond the lint screen into metal duct within dryer and clean with a long brush and vacuum. You can also disconnect exhaust duct flexible hose at back of dryer and work through metal duct from that end too. If you notice increased air flow then it should solve problem,
Aug 05, 2009 | LG Dryers
Gas dryer heats fine but shuts down before the drying cycle is over taking longer to dry clothes. Lint trap and exhaust tube cleaned out.
You are going to most likely need a vent cleaning. The dryer is getting too hot and shutting off because it is not exhausting good.
Apr 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Dryers Logo
61 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
