Question about Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum
Soap need to see how soap dispencer goes into machine. Thank you
  • 3 Answers
Your best bet is to grab a copy of the user's manual from http://www.bissell.com/Products/UserGuides.asp . They're free, but you need Adobe reader (also free) to view them.
Posted on Sep 30, 2007
SOURCE:
Nilfisk 150.2 willnot dispence soap when jetting
i have some bad news for you. when using soap not recommended by the manufacture, and you use the machine and use another type of soap or cleaner after you do not run water through the machine to clean the tube and sprayer out of soap the soap drys up and kluges the tubes and the sprayer, and you have to take it to be repaired or buy a new machine. i can test to that the hard way i loaned mine out and it was returned dirty and soap was dried up inside the tube and jets, look at the tube if you see dried up bubbles than the machine needs to be repair and service, service center , sew and vac one place vacuum dealer
Feb 28, 2015 | Nilfisk Vacuums
Bissell cleanview carpet cleaner
There are a few things that can cause a Bissell carpet cleaner to not dispense water. First thing to check is the belts if your machine is a Pro Heat. The flat belt goes around the motor shaft and the pump. As the motor runs it spins the pump. This is a stretch belt and stretch belts should be replaced at least once or twice per year to work properly as they will lose elasticity even if the machine has never been turned on. The first thing to check is to see if water will spray from the upholstery tool. If it sprays but you still get no water at the floor jets then check and clean the jets to insure they are not clogged. Getting water from the upholstery tool means the pump is working ok. If not, make sure the water tank and soap tank are not empty. Even if the water tank is full make sure the soap tank is full too. I would suggest NOT putting any soap in the soap tank because that is what causes most of the problems. Put plain tap water in the soap tank and try the machine again. Hold the trigger down giving it plenty of time to flush out any air bubbles and/or soap from the pump and the lines. If you still can't get any water from to the floor jets the most likely problem is the heater is clogged with mineral deposits or soap gunk. When a machine sits in the closet for months the soap in the lines coagulates and will clog things up. Which is why if you want the machine to work for a long time NEVER put soap in it. To do a better job of cleaning put your soap and hot water into a sprayer and use this solution to pre-condition the carpets. Pre-conditioning gives the soap and hot water a chance to dissolve the gunk in your carpets, then use fresh hot water in the machine to flush the soap and dirt from your carpets. Your machine will last longer and your carpets will be cleaner and stay clean longer because you rinsed out the soap. If you try this method you will be amazed how much cleaner your carpets will be.
If you need to clean the heater you will need to separate the handle assembly by removing all the screws. First make sure the machine is unplugged. You'll have to figure out which screws need to come out, it's not too tough. The heater is inside the handle. Look at how it comes apart so you will know how to put it back together. The heater is the silver metal thing with wires and hoses. Remove the screws that hold the cover on being sure not to lose any of the tiny red gaskets. Remove the cover and clean the soap or mineral deposits from the heater core, put the cover back on and put it back together and it should work fine. To keep it from getting clogged again simply make sure you use soft water if minerals were the problem and never put soap in the machine.
Oct 22, 2013 | Vacuums
It is not dispencing water or soap
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Sep 28, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell carpet machine model 1640-6. I don't reme...
you put the soap solution, in the plastic gallon jug, in the sink next to your faucet...then jsut guide the short hose down into the jug.... the long hose goes out to the machine... and the whole assembly screws into your faucet.
May 18, 2010 | Vacuums
Water will not come out when i push on trigger button. So water does not come out. I have taken it apart and cleaned it. The problem seems to be in the triggerI push on the handle to release the water.
order the part from bissel see if that fixes sound like you know what wrong just need get part number from bissell.
Could be some kinda pump also thats bad not pushing out the water.
I got bissle heated one black it only problem the seals rot out the soap dispencer. if you want be cheeper on washing things you can water down dish soap ore laudry deterget on there unit and cost allot less 17 bucks for bottle soap water
Jul 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Not dispersing water all I need is a manual.
I had the same prob. If you have water/soap solution at the upholstery handle, and no water/soap at the front jets, then the jets are clogged. remove the water tank, and you'll see the 2 jets (mine are red) at the front of the machine. Carefully release thw jets by squeezing the 2 tabs on top and lift out. Remove the hose that goes to the jet and clean out the jet (I used a toothpick) and rinse well. I also flushed out the system (hoses) by leaving off the jets and replacing the tanks (water and soap) I filled the soap tank with water too. Then I turned on the machine and let it run for a few minutes (I taped open the lever on the handle) to make it easy on me. Then replace the jets where you took them out, and all should be fine now. I suggest that when your finished using you machine to do your carpets, rinse out the lines with water in both tanks, to prevent soap from drying in the hoses.
Apr 06, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
My first time using this..I just want to know where the water goes and where the soap goes..I don't have directions..I was looking for the directions on here but don't see it.. This is a bissell proheat...
hi,
okay the under the lid of the big tank has a place for regular hot water theres a flexible inner bladder inside the main tank- fill that with hot water. When your shampooing the dirty water fills in around it, also between the back wheels theres where the resolve/bissell detergent goes. we use regular washing machine liquid diluted 50/50 in the soap dispenser , its cheaper and does the same thing..also, if you have pets, the bissels have a brush roller mechanism that gets clogged with pet hair quickly and will self destruct, every few rows stop and see how much pet hair is around those rollers and remove it.
J
Jul 11, 2008 | Bissell Vacuums
I'm using way more cleaning fluid
i am bisell dealer and i would reccomend mixing soap in the clean water tank and place just water in soap tank to get more accurate dispencing because there is no other adjustments on the unit
Mar 26, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
My bissell proheat 2 soap disspencer dumps soap to fast
1699 Series - Had it fixed twice already. Everytime we go to use it, the sprayer will not work. It has cost us $50.00 each time to have it fixed. This time the place told us just to get rid of it, as this is a continueus issue. It has to do with the heating element lines getting clog up.
Can you et us some instructions to fix it ourselves. Hat to throw all this money down the drain.
Is it possible to get a pictorial view of the internal parts.
Thanks,
Wally
Oct 27, 2007 | Bissell 1699 ProHeat Clear View Upright...
Bissell 7901-1 ProHeat Scotchgard Upright Wet/Dry Vacuum Logo
47 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
