Question about JVC DD-3 System
Doesnt work anymore!
Dear reader,
Last week my jvc dd 3 stop working.
I have it 1,5 year now.
No red standby light anymore on my tuner and no green control light on my subwoofer unit anymore.
It was playing on the background very low volume and sundenly it stopt.
I had a usb stick in it to play music from it. ( did that already alot of times)
I cant see any glassfuses or something like that on the outside of the machine.
Please help me fix it
Best Regards,
Milan Wopereis
bluenadas
  • 203 Answers
SOURCE: subwoofer not powering up
I could either be the sub or the main unit. The main unit actually sends a signal to the sub to turn it on so if that circuit is bad in the main unit the sub is never going to come on. I've also seen bad cables (You'd be amazed at how stubborn people can be when din connectors don't cooperate).
Posted on Jun 15, 2007
SOURCE: Our DVD/Receiver won't turn on and its not a power cord/pluggin in issue...
I had the same power problem with my th-c50. In fact, this is a common problem with this model Home Theater In a Box (HTIB). The issue truly is the fuse. All you have to do is take the cover off and replace the fuse. There are approximately 8 screws total to take the cover off and you can do it with a standard phillips screwdriver. Once the cover is off, the fuse you need to change is underneath and slightly to the right of the power input (if the box in on your lap with the front facing away from you). The stock fuse is a ceramic, white fuse and if you aren't familiar with fuses, it looks like a very small cylinder. The model number is T1AH250V. These numbers mean that it is a 1 amp, 250 volt ceramic fuse, 5 x 20 mm in size. The fuse is held together by four metal posts. Bend the posts back to take the fuse out. Go to Radio Shack or your local hardware store and get a replacement fuse with the specs above. The problem that I had is that none of my local hardware stores had a ceramic fuse with these specs, only glass. I bought the glass fuse anyway (T1AL250V) and it works beautifully. Be sure to buy a "slow blow" fuse instead of a "fast acting" as they are more durable. Insert the fuse into the slot, tighten the clamps, put the cover back on and your done! It doesn't take too long. Hope this helps.
Posted on Mar 11, 2008
I removed the cover from the receiver and check the fuse with a meter. It check fine. Reassembeled the unit, plugged it in, powered the unit and ALL IS FINE. I don't know if the fuse had worked itself loose (don't really think so) or just lucky.
jerryg50
  • 1667 Answers
SOURCE: SP-PWM505 subwoofer does not stay on
It is possible that the power supply, and or the internal amplifier has some components that have failed. The unit will have to be serviced.
Get in touch with JVC to find out if your unit is still under warranty, and to find out who is their authorised service rep for your area.
Jerry G.
Posted on May 15, 2008
SOURCE: Won't Turn On
Try reseting the system. Instructions below.
DVD reset procedure for TH-A10
1. Make sure there is no Disc in the tray.
2. Disconnect the power cord.
3. While Pressing "Stop" and "Open/Close" buttons together reconnect the power cord
4. Front display will show "TEST0".
5. Then the display will change to : "TEST1 JC2".
6. Press "Enter" button on the remote, display will show "EEPROM"
7. Press "Power" to shut unit off.
8. Reset is finished
Posted on Mar 01, 2009
A few weeks ago I turned on my Thomson Wysius Tuner 42WB02S and the red standby light flickered from red to orange then green before going back to a flickering red light. The TV screen then displayed a...
Dear Mrs Burger,
I have exactly the same problem with my Thomson, have you solved your problem yet? If so, what was wrong with your tuner?
Best regards
Sam
Dec 07, 2010 | Televison & Video
JVC PD35D30 Plasma won't turn on anymore...
Yeah, I was going to suggest power supply issue. Plasmas IMHO, are not worth spending the money to fix. Its the reason why they are so cheap these days in comparison to LCD's. I had a 50" Samsung Plasma that went out on me within 2 years (E Buffer board and XMain problem). Its not about the manufacturer but more about the Plasma technology. Do a few searches about plasma and you will find a lot of problems with these tv's. Id say cut your losses, sell the TV for parts and buy a more reliable technology
Jun 07, 2010 | JVC PD-42WV74 42 in. Plasma EDTV
TV switches itself off after 1 minute standby flahes red to green
there seems to be a possibility that your ballast might defective.. i recommend you replace it. It might not have enough voltage to keep up with the new lamp
Jul 02, 2009 | Sony Televison & Video
Cable went out yesterday, when came back their was no picture or sound. green light flashing on timer. jvc av 27230 27" tv
did the input line still work, for the cable input do an auto search channel to reset your tuner, if it didn't work stop right there your tuner is mabye out
Feb 20, 2009 | JVC AV-27230 27" TV
Ilo 32 lcd
I have the same issue. Here's a temporary solution, which is what I've been doing for the last couple of weeks, unplug the unit from the wall, just long enough for the red standby light to go out, then plug the unit back up. as soon that the red standby light comes on, press the on button the the remote or the unit. You may have to do this couple of time before it works. Somedays it works on the first try for me and then somedays I have to do it 3 to 4 time. I sure that at some point this will stop working too.
Sep 08, 2008 | iLO 3200 32 in. LCD Television
Turn on ty
Sep 06, 2008 | iLO 3200 32 in. LCD Television
Won't Turn On
Jun 01, 2008 | JVC TH-A10 System
Dead tv :-(
ai have the same fault on my tv will not swith on any help any1
Mar 22, 2008 | Televison & Video
Hyundai Lcd/Tv wont turn on (Lc-23y18)
my television is the same and has been like it for almost 18mths, still to find a cure
Mar 14, 2008 | Televison & Video
Bright green flash and red arching lines
You need to check the bulb in the back of the set as it could be on the way out . just check to see if the bar in the bulb has gone black as it is a good sign the bulb is on it's way out . the bulbs only last 2-3 years or 4000 hours . If thats ok you most probaly have dry joints on the tuner , they just need resoldering
Jan 29, 2008 | Sony KP-46WT500 46" Rear Projection...
JVC DD-3 System Logo
42 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
