Question about Kenmore Dryers
My kenmore dryer dont work the motor dont move
  • 43 Answers
First check your breaker. Next I would check thermal fuse.
Posted on Apr 25, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
I push start button sounds like running but dryer dont go
send the model number,do you mean the motor is running but the drum isn't moving?if so broken belt
Jan 10, 2014 | Kenmore Dryers
Kenmore 500 series dryer won't start. Only 2.5 years old.
turn the drum with your hand,if it feels hard to move you could have something stuck in the blower wheel that is below the lint filter and behind the duct that the filter slides into or the belt could be jammed,if it moves try starting it it might start you could have a flat spot on the motor and most likely you'll need to replace it,if it'shumming it's the motor making the sound
Feb 14, 2010 | Kenmore Dryers
I just replaced the motor in my Kenmore Series 90 dryer, When I'm running the dryer with no heat it runs as quite as could be expected for a ten year old dryer, When I run with heat the dryer starts making...
It could be possibly your rear roller bearings expanding with heat causing them to not spin as freely? Im not really too sure but its an idea you dont have many moving parts on the unit. Just your idler pulley, blower wheel, and rollers. Hope this helps.
MJ
Feb 14, 2010 | Kenmore 659 Electric Dryer
Combo Kenmore dryer buzzes when turned on. Dryer
Your dryer motor is being told to turn, but cannot. One possible reason is due to lint build up on the motor shaft.
Here is how it works: the motor has a set of starter coils, and a set of running coils. There is a momentum actuated sliding switch on the shaft. When the motor starts from the normal rest position, the spring loaded switch on the motor shaft makes contact with the set of starting windings on the A/C motor. When the motor reaches a certain speed, the momentum of the motor causes weights on the collar to try to move outward. Through this outward movement, the force is directed through a mechanism which moves the collar on the shaft to the other set of contacts for the running coils of the motor.
In some cases, lint builds up on the motor shaft and can cause the sliding switch to lock into place instead of being able to slide back and forth. If the collar is locked into place over the running contacts, you could get this buzzing noise. The motor is trying to run, but doesn't have enough torque to start, and therefore will sit and buzz....
Jun 24, 2009 | Kenmore Dryers
Kenmore dryer timer will not turn.
Bad timer motor if you are using timed dry.
If using auto dry probably a bad sensor.
Verify by using any time dry or air fluff cycle and see if the timer moves.
Mar 03, 2009 | Kenmore 64902 Electric Dryer
Dryers Logo
32 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
