Question about Kenmore 53701 Dehumidifier
Running but not collecting water
My model #580.53701300 is running but not collecting water. Is there some part that needs replacement or does something need cleaning. I have vacuumed it over once alread.
  • brucelang09 May 03, 2009
    model #580.53701300 has defrost function. I have the same model worked fine until recently. I saw evaporator and tube frost up. even temp >70, humidity >65%, the water bucket has only a few drop of water. the fan work fine.
    if the coolant leaks, where is the coolant located?
    is there anything wrong with sensor or control box?
Your coils are probably frosted up. This can happen from the basement temperature being too cold if you dont have the automatic defrost type of dehumidifier, or it could be low on coolant from a pinhole that leaked it out. Mine did the same thing and I had to buy another one. I bought one thats operates down to 41 degrees Fahrenheit and it is an automatic defrost type. It works good for my basement because I have central air which makes the basement even cooler and harder to dehumidify without freezing the dehumidifier up.
Posted on Apr 30, 2009
My machine is running but no water is being collected. The model number on my machine says DE N 500 P
Several things can cause your problem:
Dirty or clogged air intake filter. Remove and clean the filter according to the Owner's Manual instructions.
Dirty coolant coils. Clean and dry the coolant coils.
The humidity extraction level is set to high. Lower the level to 35%
Not enough free air space around the unit. Maintain at least 12" of air space around the entire unit.
The ambient air temperature at floor level is to cold (between 40 - 60 degrees F). Raise the unit up off the floor onto something sturdy enough to handle the weight (including a full tank of water) and the vibration during operation. This happens frequently in basement applications.
Depending on the age of the unit, the refrigeration coolant may need to be recharged.
The humidity sensor has failed and needs to be replaced.
All of the above are where you start troubleshooting and hopefully solving the problem.
Jun 01, 2011 | DeLonghi DE500 Dehumidifier
My humidifier runs, but no water is collected. It will start and just keep running. Could something be clogged. The filter has been cleaned. It has sat not running through the winter.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Apr 21, 2011 | Haier Dehumidifiers
My dehumidifier is running but not collecting any water. I have cleaned the filter and it still wont collect water. Is it broken?
First, make sure the humidistat isn't set too high by adjusting it to the lowest humidity setting and running it again. Next, test the dehumidifier by placing it in a closed bathroom with a hot shower running. If you don't see water collecting in the unit after several minutes, turn the unit off and clean all dehumidifier filters and coils. If, after adjusting the settings and cleaning the unit, you still don't see water collecting, you may have a refrigeration issue. This situation will have to be addressed by a qualified technician.
Good luck.
Aug 15, 2010 | LG Dehumidifiers
My Maytag Model number M7DH65B2A is not collecting water
Take care.
Aug 12, 2010 | Maytag M7DH65B2A Dehumidifier
Dehumidifier runs but does not collect water
I have dehumidifier Whirlpoot Gold Model #39R171E Serial #H/XE11M1K 6203A it was working fine last year, but this year it is not collecting any water, it is running for day. I opened it, cleaned the filter (which was mostly clean) & it still has not water in bucket. What is wrong & is it possible to fix it by myself.
Jun 10, 2009 | Haier HDN655E Dehumidifier
I have a Whirlpool dehumidifier that doesn't collect water
I have a Whirlpool dehumidifier model AD50LJ0: the compressor starts but then appears to trip out. The fan keeps running. It does not condense and water. Can you help?
Jun 08, 2009 | Whirlpool Dehumidifiers
Not collecting water
I am still unsure here if your saying that the fan motor is running with the compressor or not? can you clear this up for me.
Jun 02, 2009 | Kenmore 54501 Dehumidifier
No cowater collecttion
I have a goldstar dehumidifier model #dh2510a. It runs but does not collect any water in the tank. I have pushed the tank up to the red button in the back. Is there a fuse or something else I can do.
Sep 04, 2008 | LG LHD45EL Dehumidifier
Water collection
the unit is iceing the coil ck for air flow clean coil or its a more serious poblem like refrigerant or compressor capacity dan
Jun 15, 2008 | Dehumidifiers
Kenmore 53701 Dehumidifier Logo
802 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
