Question about Roper REX4634KQ Electric Dryer
Roper dryer the roper dryer i have makes a thumping noise when it is running. I have narrowed the sound down to a belt issue, however i can not figure out how to access the area where the belts are located.
  • 709 Answers
Hi Stefan71, The lid or top part of the dry is just snapped together with clips. All you do is pry up on the lid like a hood on a car. it will pop free and tadah, theres your belt. You do need to look at the rollers for something on them, The thump is more than likely coming from the rollers . Hope this helps
Posted on Sep 28, 2007
SOURCE:
Clicking noise
Genarally a belt will have a thumping noise does it have a slow sounding pattern or a fast one, could be in the drum support system
Dec 01, 2013 | Roper Dryers
Dryer making a grinding noise when turned on. How do you get the top off to check the barrel motor?
Clanging Sound
1. If the noise coming from your dryer can be described as a clanging sound, the solution is probably well within your grasp. This common sound is typically the result of loose debris accidentally put in with the load of laundry. Change may be left in pockets of pants or other objects may be dropped in the laundry basket by children --- perhaps a toy car. The objects may not be noticed when put into the wash, and the water in the washer may have dampened the sound. Simply remove these items, and restart the dryer to resolve the issue.
Sometimes the clanging is from snaps or buttons that are actually part of the clothing. If you are drying a jacket with metal snaps or another garment with metal attached, you should expect this clanging sound as they tumble and strike the inside of the dryer tub.
Humming or Whistling
2. Many Roper dryer models are equipped with a safety feature known as a lint signal, which is usually a light that often accompanies a warning signal, telling the machine owner that the lint trap has become clogged. When the dryer cannot pull adequate air through the lint filter, it can overheat and become a fire hazard. The warning alarm may sound like a hum or whistle to get your attention. Look at the lint signal light, clean out the trap and the noise should stop.
Thumping or Grinding
3. If the noise you are hearing can be described as a thumping sound or a metal grinding sound, the device that turns the dryer drum, known as the drum rollers or glides, can be worn out. As the drum turns, there may be a constant and rhythmic thump each time the drum rotates. A severely worn or broken roller could cause the metal of the drum to rub against the metal housing of the machine, causing a louder grinding noise. The rollers will need to be replaced to remedy the problem.
Squeaking or Squealing
4. Most dryers work by using belts to turn the rollers, which in turn make the drum rotate and tumble the clothes dry. When these belts get loose, a worn belt or a malfunctioning tensioner spring may keep the belt tight. In either case, belt slippage may occur and will produce a squeaking or squealing sound that is easily recognized. The problem is likely to be the tension on the belt since most belts will break before wearing out to this degree.
Feb 24, 2011 | Whirlpool Dryers
My Roper dryer was making a strange rattling noise for a couple months. Then it started not drying my clothes completely. Not it just won't start at all. Its only 3 years old...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 25, 2010 | Roper Dryers
Dryer making sqeaking noise
greetings,
the most likely answer is the belt pulley..the rollers can also make noise,but they usually will make a thump thump noise..remove belt pulley and lubricate and see if this helps
May 17, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
When the dryer runs even with nothing in it it , makes a thumping
check the inside of the drumm make sure none of the fins are loose,
but sounds more like the wheel rollers are bad, sometimes is loud when it starts then seems to go away a little after the dyer get hotter, is the heat that makes the metal bearings make less noise. u can replace the wheels,the belt an tensioner at the same time is cheaper to pruchase the kit an have it all done the first time! bad wheels put more stress on belt an eventually will break apart so just order the entire kit
Feb 02, 2010 | Maytag SDE3606A Electric Dryer
I have a Roper Dryer Model REX3514PQO. The dryer
Sounds like you have a broken drum belt.
If you have to replace your drive belt and if you have a front loading machine.
First you will need to unplug your dryer from the electric.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley.
While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
If the belt is not broken, then I would check to see if the timer switch is working properly, if not then you may need to replace it.
Good luck,
I hope this helps
Oct 06, 2009 | Roper REX3614KW Electric Dryer
Dryer drum making thumping noise
My dryer just started making this noise. So I opened the back up to try to figure out what it might be, and when I opened it I saw something. It was part of the belt that drives the dryer. There are grooves vulcanized to the belt, and a small section of grooves or cogs I think is what they are called had come apart from the belt and what laying there on the floor of the dryer. But I ran it and timed the thumps in my head to get it to stop right on the "thump". Sure enough there was a small 1/2'' appx. of belt Cog missing, so the "thump" came from when the belt came around to the motor and the pulley hit a divit in the belt, "thump". So needless to say I need to replace the belt soon before it breaks completely. I figure that it looks like someone may benefit from knowing what the noise is. Now its off to find the proper belt and look up how to change those things...Good luck to those reading this.
[email protected]
Jan 16, 2009 | LG DLG3788W Gas Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Roper REX4634KQ Electric Dryer Logo
99 people viewed this question
Top Roper Dryers Experts
Marvin
Marvin
Dennis Boxerman
Colin Stickland
Colin Stickland
Are you a Roper Dryer Expert? Answer questions, earn points and help others
