Question about Buffalo Technology Buffalo AirStation Broadband Router AP Wireless (WBR-G54)
CAN NOT FIND SOFTWARE TO INSTALL HARDWARE
Hi Just purchased buffalo wireless-g broadband modem router [model WBMR-54 ] with usb adapter [WLI-U2-KG54]when installing the usb adapter i select install wireless drivers from cd then plug the adapter in to usb port then found new hardware wizard window opens then click next a window opens which says can not install hardware because wizard can not find software needed to install device can you tell me what i am doing wrong THANK YOU
  • Anonymous Mar 18, 2014
    im using dwa 132 b1 wireless usb adapter and after i install the usb driver everything i download from the internet became corrupt and i cant installed anything
  • 71 Answers
Here, read this - you should use an ethernet cable to install the router - it is alot easier but here is the manual that will tell you exactly what to do - http://www.buffalo-technology.com/support/getfile/?WBMR-G54+Manual.pdf
Posted on Sep 20, 2007
How do I change from wired hookup to wireless? Bob
Instructions
Things You'll Need
Broadband modem
Router compatible with modem
Internal or external wireless network adapter
Phillips screwdriver
Suggest Edits
  1. Prepare the Network
  • Purchase and setup a wireless broadband router by interfacing it with your wired computer. Choose a router that is compatible with your broadband modem and that supports the wireless network type you desire.
  • Enable WPA or WPA-2 security, and change your router's default password. Give your SSID or wireless network a memorable name.
  • Connect your modem to the WAN (wide area network) port on your router.
  1. Install an Internal Card
  • Purchase a wireless network card that is compatible with the router you purchased and with your computer. For example, if you bought a 802.11 b/g router, do not purchase an 802.11 n adapter.
  • Shut down your computer. Remove all cables and peripheral devices.
  • Remove the left side panel while facing the front of the case. You may need to remove screws or to manipulate latches and notches. Consult your case or computer manufacturer's documentation if you are unsure of how to remove the panel.
  • Clip the metal part of the anti-static wrist bracelet to a metal object, and ******** the bracelet.
  • Locate an available PCI or PCI-Express slot. Unscrew the screw that secures the slot cover that corresponds with the slot, then remove the slot cover.
  • Line up the wireless adapter's pins with the slot. Insert the card until it clicks into place. Do not force the card into the slot, or you may damage the card's connectors. If you feel resistance, remove the card, line up the card with the slot again, and reinsert.
  • Secure the card with the slot cover screw. Reattach the side panel, and replace any screws you removed earlier.
  • Reinsert all cables, and plug in all peripherals. Boot the computer.
  • Allow Windows the opportunity to detect the card. It should automatically install the drivers for the card. If you have updated drivers, insert the disk and install according to on-screen instructions.
  1. Install an External Card
  • Boot up your computer.
  • Insert your external wireless adapter into the appropriate slot. For example, if you purchased a USB slot, insert it into a USB port.
  • Complete Setup
  • Double-click the network icon in the task bar.
  • Highlight your wireless network. Windows will display the name you entered when setting up your router
  • Click the "Connect" button.
  • Enter and verify the security key you created when setting up the router. Click on "Connect."
If you have further query then try to let me know. Thanks for using FixYa.
Aug 27, 2011 | Cisco Linksys Wirelessn Router Black...
I've had a new laptop but require my security key, model WBMR-G54 to access the security enabled network, from my old laptop.
If you've forgotten the wireless security key you entered when you set up the router you can reset it by connecting to the router directly with an ethernet cable instead of the wi-fi. Plug a cable into the router and then laptop and access the setup page for the router. See the manual (or download one from the buffalo site) for setup instructions.
Dec 27, 2010 | Buffalo Technology Buffalo AirStation...
Hello I have just the other day purchased a Linsky broadband router(model WRT300N) with it I purchased 2 USB keys model no WUSB54GC-EU,on my seconary pc(next door)I have susessfully installed the software...
Are you using Windows XP on your primary PC? If yes, you dont need to install the wireless LAN monitor of the usb adapter because Windows XP has a built-in wireless monitor. Start with a clean slate by uninstalling it from Add/Remove Programs. Next, to install it properly, just plug the wireless adapter into your computer, and when Windows XP finds it, it will either look for the cd to get its driver or it will install it automatically (verify this by right clicking on My Computer >> Properties >> Hardware >> Device Manager. You should see the adapter under Network Adapters) and it should say something like "it's working properly). Once installed, go to Control Panel >> Network Connections. Right click Wireless Network Connection, click View Available Wireless Networks. Connect to your wireless router from here.
Jun 27, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
NINTENDO WII CANT FIND ACCESS POINT (BUFFALO WBMR-G54)
defenately call nintendo, i hooked up ours and i think the access point or brand is not compatable with the wii, something with the mgz, they will let you know.....wii has problems with an estimate of 6 or 7 diffrent models.....and make sure it's on the wek setting tho it's a bit picky, then again with all it does on line it's just trying to protect you.....shia
Apr 16, 2009 | Buffalo Technology WHR-G54S Wireless...
Im a computer dummy ive just bought a wbmr-g54 and i havent a clue what to do
1. Install Software that Came with The Product. Usually it has on-screen instructions.
2. Hook up wbmr-g54 to your computer. ( Ethernet Cable to Modem, And Ethernet Cable to Computer. If you have a wireless thingy majig for your computer then that would detect your router already.)
3.Set up Internet Security, and Firewall.
4. Get up onto internet and Surf it like its Teahupoo.
Feb 03, 2009 | Buffalo Technology WHR-G54S Wireless...
I have cable modem along with the Linksys wireless - G Broadband Router. Added another PC to my home. Purchased Linksys compact wireless-G USB adapter. Installation went fine and able to connect to the...
You should have an RJ-45 cable connected from your ADSL modem to your router's internet RJ-45 plug then download network magic or similar software to input your user name and password on the router. this way you'll have internet even if your computer is turned off.
Nov 29, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
How to connect wireless router, Netgear WGR614, to my computer?
4 steps to set up your home wireless network
1.
Choose your wireless equipment
The first step is to make sure that you have the equipment you need. As you're looking for products in stores or on the Internet, you might notice that you can choose equipment that supports three different wireless networking technologies: 802.11a, 802.11b, and 802.11g. We recommend 802.11g, because it offers excellent performance and is compatible with almost everything.
Shopping list
• Broadband Internet connection
• Wireless router
• A computer with built-in wireless networking support or a wireless network adapter
A wireless router
The router converts the signals coming across your Internet connection into a wireless broadcast, sort of like a cordless phone base station. Be sure to get a wireless router, and not a wireless access point.
A wireless network adapter
Network adapters wirelessly connect your computer to your wireless router. If you have a newer computer you may already have wireless capabilities built in. If this is the case, then you will not need a wireless network adapter. If you need to purchase an adapter for a desktop computer, buy a USB wireless network adapter. If you have a laptop, buy a PC card-based network adapter. Make sure that you have one adapter for every computer on your network.
Note: To make setup easy, choose a network adapter made by the same vendor that made your wireless router. For example, if you find a good price on a Linksys router, choose a Linksys network adapter to go with it. To make shopping even easier, buy a bundle, such as those available from D-Link, Netgear, Linksys, Microsoft, and Buffalo. If you have a desktop computer, make sure that you have an available USB port to plug the wireless network adapter into. If you don't have any open USB ports, buy a hub to add additional ports.
2.
Connect your wireless router
Since you'll be temporarily disconnected from the Internet, print these instructions before you go any further.
First, locate your cable modem or DSL modem and unplug it to turn it off.
Next, connect your wireless router to your modem. Your modem should stay connected directly to the Internet. Later, after you've hooked everything up, your computer will wirelessly connect to your router, and the router will send communications through your modem to the Internet.
wireless_chart.jpg Next, connect your router to your modem:
Oct 29, 2008 | Computers & Internet
Wireless router
hi frank its a new thing to have to go out and decide what router to purchase and install i use a linksys and have had good luck with the wireless connection quality . does his laptop have a wireless lan card installed most new laptops do have one but its worth a look to make shure it does. depending on how much you want to spend how far away does his laptop sit from location of router ? if not more than 10 ft go ahead and purchase a cheaper one 60.00 now if you want a better quality one go with the twin antenna linksys for about 130,00 and please make shure that he installs the security software that comes with the router and make a password and secure it for shure .i hope ive helped you decide on what router to purchase they all work fairley good .
as far as how they work they are all plug and play install the cd software first then follow instructions carefully and set up is 10 minutes away good luck by for now
Jul 03, 2008 | Linksys Wireless-G WRT54G Router
Wireless router installation
Please see my response to this question. Your university's connection is most probably a LAN connection, so you'd need to follow the instructions as if you had a cable internet connection (unlike DSL, a LAN connection and cable internet connection don't require authentication with the ISP).
Jan 07, 2008 | Linksys Wireless-G Broadband Router
Buffalo Technology Buffalo AirStation Broadband Router AP Wireless (WBR-G54) Logo
250 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
