Question about Samsung VR8460 VHS/S-VHS playback VCR
We get "NO SIGNAL" when attempting to operate the Samsung VCR.
The Samsung VCR is model VR8460. We have a Sony Vega TV and a Pace HD-DVR cable box. Everything was working fine including a Sony DVD player. The VCR is about one year old. We replaced a power strip recently. Any suggestions where the problem may be? The VCR is getting power and the DVR and DVD players seem to be working properly. Thank you.
    Genius:
  • 1,148 Answers
CHECK THE RCA JACKS AND ALL CONECTIONS
Posted on May 15, 2009
I have purchased Samsung 550 - series L5 - I don't seem to be able to hook up the VCR to it to record. I have cable on it and I would like to be enable to record programs. Television ask if I want to...
You don't record from TV, you record from cable so cable needs to be hooked up to input on VCR.
If you don't use cable box you would hook cable to VCR then out of VCR to TV. If you use cable box then you need to connect Video and Audio outputs on cable box to Video and Audio inputs on VCR and switch input of VCR to Line input.
Feb 28, 2011 | Samsung Televison & Video
Connect lifestyle 48 to plasma and dvr
You need to buy a Bose VS 2, video enhancer. Your cable/sattelite, vcr and aux connect to the VS 2 and the VS2 connects one HDMI cable to the TV. The VS2 then upconverts DVDs played on the lifestyle through the VS2/HDMI.
Sep 10, 2009 | Bose Lifestyle 48 System
Taping to vhs from digital cable
You do not need to leave the TV on. To get the clearest picture you should connect the AV cables (yellow, white, red) from the cable box to the VCR, and from the VCR to the TV. There should be a setting on both the TV and the VCR to set the input to VIDEO so you don't have to use channel 3. You can shut the TV off while recording if you want. Also be careful because if you use the channel guide or info button while recording, it will show up on the tape.
May 20, 2009 | Samsung VR8460 VHS/S-VHS playback VCR
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
VCR will not record
yes your hook is all correct...but still will not work......unless this is a d-vhs recorder...(and the other way to record hd is dvr)....(note dont throw the standard vcr away) it might and can be use later down road
Jan 15, 2009 | Proscan PSVR73 VHS VCR
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung VR8460 VHS/S-VHS playback VCR Logo
239 people viewed this question
Henry  Thomas
Henry Thomas
