Question about Whirlpool AWM6120 Front Load Washer
FLASHING LIGHT(WHIRLPOOL AWM6120 FRONT LOAD WASHER)
WHEN I PUT MY WASHER ON AND START IT YOU CAN HEAR THE PUMP WORKING THEN IT STOPS AND THE GREEN LED LIGHT THAT LETS YOU KNOW THE DOOR HAS BEEN UNLOCKED JUST KEEPS FLASHING AND THE WASHER COMES TO A STAND STILL .I CLEANED THE FILTER,I CHECKED THE INLET PIPES,AND WHEN IT COMES TO A STAND STILL WITH THE DOOR LIGHT STILL FLASHIN THE DOOR IS STILL LOCKED I HAVE TO TURN THE CYCLE PROGRAM TO "O" TO OPEN THE DOOR
  • currang2 Dec 30, 2007
    I have the same problem. Closing the door more carefully doesn't help. There seems to be a switch inside the catch mechanism, but pressing that in doesn't fool the machine into thinking the door is locked. I suspect the switch is broken or a wire is loose. I don't know whether that is fixable DYI.
  • Anonymous Mar 29, 2014
    NO LED LIGHT ON
    Problem Solver:
  • 4 Answers
This happens to me every time i put a load in, try giving the door an extra nudge to close it, just give it a firm push where the handle to open it is. hope that helps!
Posted on Dec 17, 2007
Stops mid cycle and the 400 and 0 spin lights flash
According to the service manual ( which you can download ) it is the fault code 05 which means NTC failure. This is the water temperature sensor.
Feb 17, 2013 | Whirlpool AWM6120 Front Load Washer
Flashing lights on Rince, Start & 0 speed.
washer think there water over fill to clear this u need ruin a diagnostic test. think of timer knob light a clock straight up being at 12 oclock an one click at 1oclock to enter the test first rotate knob to any postion except postion 6 staight down press start and fs button at same time wait 3 seconds an rotate knob to to postion 6 wait 3 second then release both button , all light should blink . you should now be in test , rotate knob to various postion to test wash cycle an rinse an spin postion 9 an 10 are the waster valve onces the test finish tun the knob to another postion to turn test off an unplug washer an plug bach in this should clear it . if still have a porblem call a applince service ok
Dec 13, 2017 | Whirlpool AWM6120 Front Load Washer
Just water pump start
Check the water supplies at the back, if the valve is opening, and the water is getting into the machine, it can be a faulty water level switch, or membrane sensor, depending on the model.
A faulty or clogged inlet valve can also close few seconds from opening the valve, usually becausu of a faulty solenoid.
If valve and water level switch are ok, then this is a faulty control.
Have valve and water level switch checked first.
Dec 10, 2008 | Whirlpool AWM6120 Front Load Washer
When i start wash. machi. pump starts and few sec.later led flash
Whirlpool AWM8121 stops working mid cycle. Bottom two lights flashing on spin speeds.
Fault code 3 = Drain failure or not detecting empty drum.
Check pressure switch, blocked drain, drain pump.
See link below for service manual.
http://www.user-manuals.com/advanced_search_result.php?keywords=857081253000&forward=plist
Oct 24, 2008 | Whirlpool AWM6120 Front Load Washer
Whirlpool AWM 8103/S Problem
Oct 07, 2007 | Whirlpool AWM6120 Front Load Washer
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
May 10, 2007 | Whirlpool AWM6120 Front Load Washer
Cleaning depends on use. 8 years is a bit over the top! When your water does not drain, check the outlet filter first, then the pipe from below the tub to the filter. Your washer wont spin 'cause the pump/filter is blocked.
Jul 24, 2006 | Whirlpool AWM6120 Front Load Washer
Whirlpool AWM6120 Front Load Washer Logo
348 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
